I have been trying to build an image for Raspberry Pi 4B. I have used this github repo:
https://github.com/runborg/vyos-pi-builder/ with a few exceptions:
- I tried using the official docker.
- I had to change the build flavor to be ‘generic’ as ‘iso’ does not build.
- I’ve also had to add the following to stop the build from failing.
sudo apt update && apt install kpartx libgnutls28-dev uuid-dev -y
It seemed to build ok, I could get the img flashed onto the sdcard. But it didn’t complete booting. I got the following error messages:
- Begin: Mounting root file system ..
- cat: can’t open ‘/sys/block/*/removable’: No such file or directory
- (initramfs) Unable to find a medium containing a live file system
Would anyone know how to fix the build to make it produce an img that will work?
