not sure if this is a bug. I have had RC4 on this box for a week. today am changing out a NIC. Vyos sees the NIC but doesn’t seem to configure them properly. for example, eth15 should be set at 1gb, full duplex. when I configured eth15 to that, it says doesn’t support (it does) but it configures it anyway. and even still, the link does not come up. any ideas?
thank you
n$ sudo ethtool eth15
Settings for eth15:
Supported ports: [ ]
Supported link modes: 1000baseT/Full
1000baseKX/Full
10000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Advertised link modes: 1000baseT/Full
1000baseKX/Full
10000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Speed: Unknown!
Duplex: Unknown! (255)
Port: Other
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Supports Wake-on: g
Wake-on: g
Current message level: 0x00000007 (7)
drv probe link
Link detected: no
