After upgrading from 1.2.0-rolling+201811170337 to RC9, I notice a couple of major issues.
The problem I reported initially with BGP filters not being applied before bringing up a session (or shutting it down), is back. Multiple peers have tripped prefix filters.
VRRP did not come up…at all
I had a script setup to run on boot that shuts down peering interfaces initially to give BGP time to load. This was my work around of issue #1. However, it doesn’t seem to have run at all either.
set system task-scheduler task ShtdownInterfaceOnBoot crontab-spec ‘@reboot’
set system task-scheduler task ShtdownInterfaceOnBoot executable path ‘/opt/vyatta/etc/config/scripts/interfaceshutdown.script’
I need to revert this one back to the previously mentioned rolling build.
I have about 12 hours I can still test if necessary.
