Hello Everyone,
I am planning to set up a network using optical fiber and would like to use VyOS as my operating system. I need some advice on the hardware requirements and best practices for this setup.
Here are some specific points I’m looking for guidance on:
- Recommended Network Interface Cards (NICs): Which NICs are best suited for optical fiber connections and fully supported by VyOS? I’m particularly interested in 10Gbps or higher.
- Optical Transceivers: Are there specific brands or models of SFP/SFP+ transceivers that are known to work well with VyOS? Any compatibility issues I should be aware of?
- Hardware Configuration:What are the recommended CPU, RAM, and storage specifications for a VyOS router handling high-speed optical fiber connections?
- Switches and Other Networking Equipment: Are there any particular switches or other networking hardware that you would recommend for a robust and reliable optical fiber network with VyOS?
- Best Practices: Any tips or best practices for setting up and maintaining a VyOS router in an optical fiber network environment?
I appreciate any advice or insights you can share from your experiences. Thank you!
