The configuration works fine to an extent, with the only problem that is redirecting everything targeting the port in question.
For example, if I do an Hairpin on Port 80, filtered with source being my Lan network, it will redirect everything to my internal server that is sent targeting port 80, regardless if the initial target IP is my public IP or not.
I’m looking for a way to filter the Destination NAT “destination address”, where my public IP is being assigned dynamically via DHCP (from the ISP).
Is there any way or trick to achieve this? Essentially reference my WAN interface public IP on my Destination NAT rule dynamically, such as some sort of tag?
