Request to add container label
I want to use traefik in container for easy access to multiple http services, but the current container feature lacks labels and using traefik is not convenient, can you provide container labels?
The fastest way to implement something is by creating a direct feature request on https://vyos.dev
I have made a feature-request T5531
Thank you very much
Next time I’ll visit vyos.dev to create the request
Will be available in the next rolling release.
Thank you very much
I’ll download and test it.
