The command to set a master to backup is gone in VyOS 1.2.0-rolling+201809050337
Is it a new way to force a master to backup?
Hi Arne0,
you could try :~$ restart vrrp
restart vrrp works for restarting vrrp, but not the same as reset vrrp master interface group as it is today. I’m using no preempt at in some routers I have more than one VRRP group on some interfaces. With the current approach it’s possible to move one group to have load balancing. With no preempt and using restart vrrp both groups will become backup.
The reason for not using preempt is to be able to move master controlled depending on need.
