Roling release 2024-11-02 - Remote syslog not working anymore
I juste update to the latest rolling release this morning, the remote syslog is not working anymore.
The is the configuration:
vyos@shieldgate# show system syslog
 global {
     facility all {
         level info
     facility local7 {
         level debug
 host 10.5.0.20 {
     facility all {
         level all
     port 10513
     protocol tcp
And the syslog coniguration file:
vyos@shieldgate# cat /etc/rsyslog.d/00-vyos.conf
Autogenerated by system_syslog.py
$ModLoad immark
$MarkMessagePeriod 1200
We always log to /var/log/messages
$outchannel global,/var/log/messages,262144,/usr/sbin/logrotate /etc/logrotate.d/vyos-rsyslog
*.info;local7.debug :omfile:$global
Remote logging
It as working fine since end of september
Thanks.
Do you have a valid route towards 10.5.0.20?
Does 10.5.0.20 even listen on 10513/TCP?
Are any logs being produced in /var/log/messages and/or dmesg and/or journalctl -b -f ?
Yes it’s working fine if I add this to the syslog config (file: 00-vyos.conf):
Remote logging
. @@10.5.0.20:10513
Until the next reboot.
What happens if you remove the config, commit, and re-add the config.
Does it then apply the correct syslogging?
I’m just wondering if there’s a problem parsing the configuration on bootup.
I delete the syslog config and reenable it:
vyos@shieldgate# set system syslog global facility local7 level debug
vyos@shieldgate# set system syslog host 10.5.0.50
vyos@shieldgate# set system syslog host 10.5.0.50 port 10513
vyos@shieldgate# set system syslog host 10.5.0.50 protocol tcp
vyos@shieldgate# set system syslog host 10.5.0.50 facility all level all
vyos@shieldgate# commit
$ModLoad immark
Remote logging
The remote syslog is still missing….
Open a bug report on https://vyos.dev/
Thanks for reporting this. Bug fixed in syslog: T6858: bugfix remote syslog using TCP by c-po · Pull Request #4185 · vyos/vyos-1x · GitHub
Thanks for the fix, i will check that this weekend!!!
I just update to the latest version and remote syslog is working as expected.
Thanks again for the fix!
