I am currently testing Vyos on a dedicated hardware. I have installed vyos-1.3-rolling-202012290217 . Unfortunately the grub does not start the system. It only works by confirming the enter key. The Grub config looks good so far. It says that it should start after 5 sec. Unfortunately, this does not work in the version on my hardware. I have already tested it on two devices. Both times completely reinstalled.
regards
Christian
Okay. Unfortunately, nothing has led to success so far.
I have pulled off the keyboard and also replaced it. This has not helped. But when I boot e.g. from the Vyos installation stick, the timer works. There are 7 seconds counted down.
Is there any way I can test different things with Grup? update-grub has problems due to the overlay
/usr/sbin/grub-probe: error: failed to get canonical path of `overlay’.
One more addendum. A Debian 10.6 installation also boots automatically after installation. So there must be something in Vyos that prevents the automatic start.
Okay. And one more addendum. The Vyos 1.2.6 S1 does not work either.
I solve my problem myself If you activate the serial console redirection in the Bios it works. But you have to set the parameter Hide Setup item to Disabled under Advanced/OEM FORM. Then there is under Advanced the entry Serial Console Redirection.
