I cannot commit the command “set interfaces ethernet eth0 address dhcp”.
There are lot of errors, last message “Commit failed”.
It would be easier to help if you post the errors you get.
Microsoft Hyper-V VM
Hi @Zamp , thanks for sharing information about the issue. It’s a known issue for 1.4 rolling releases and a task on phabricator is already created. Please follow the following task to get updates when the issue is solved: ⚓ T4327 Ethernet interface configuration fails on Hyper-V due to speed/duplex/autoneg ethtool command error
