When restarting bgp I get errors saying that all of my route-maps do not exist.
Currently running vyos 1.4-rolling-202307060317
Hi!
What is the exact error?
Also please show:
show log protocol bgp
show configuration commands | match bgp
sudo vtysh -c "show run bgp"
So if I try to restart bgp via vyos command I get the following:
WARNING: This is a potentially unsafe function!
You may lose the connection to the router or active configuration after
running this command. Use it at your own risk!
Continue? [y/N] y
WARNING: some of listed daemons are not running!
The route-map 'GENERIC-IN' does not exist.
The route-map 'GENERIC-OUT' does not exist.
The route-map 'PT-ATHARVA-IN' does not exist.
The route-map 'PT-ATHARVA-OUT' does not exist.
Here is the log: Last restart was only a few minutes ago
Jul 08 04:26:16 edge-01.us-kc.tackitt.us bgpd[949]: [VTVCM-Y2NW3] Configuration Read in Took: 00:00:00
Jul 08 04:26:30 vyos bgpd[949]: [VTVCM-Y2NW3] Configuration Read in Took: 00:00:00
Jul 08 04:26:36 edge-01.us-kc.tackitt.us bgpd[949]: [VTVCM-Y2NW3] Configuration Read in Took: 00:00:01
Jul 08 04:26:37 edge-01.us-kc.tackitt.us bgpd[949]: [VTVCM-Y2NW3] Configuration Read in Took: 00:00:00
Jul 08 04:26:38 edge-01.us-kc.tackitt.us bgpd[949]: [VTVCM-Y2NW3] Configuration Read in Took: 00:00:00
Jul 08 04:26:53 edge-01.us-kc.tackitt.us bgpd[949]: [VTVCM-Y2NW3] Configuration Read in Took: 00:00:00
Jul 08 04:26:54 edge-01.us-kc.tackitt.us bgpd[949]: [VTVCM-Y2NW3] Configuration Read in Took: 00:00:00
Jul 08 04:26:55 edge-01.us-kc.tackitt.us bgpd[949]: [VTVCM-Y2NW3] Configuration Read in Took: 00:00:00
Jul 08 04:26:58 edge-01.us-kc.tackitt.us bgpd[949]: [GNAYN-F5F1G] Computing addpath IDs for addpath type All
Jul 08 04:26:58 edge-01.us-kc.tackitt.us bgpd[949]: [GJPH1-W8PZV] Resetting peer 2a0c:2f07:9459::b6(Unknown) due to change in addpath config
Jul 08 04:26:58 edge-01.us-kc.tackitt.us bgpd[949]: [VTVCM-Y2NW3] Configuration Read in Took: 00:00:00
Jul 08 04:26:59 edge-01.us-kc.tackitt.us bgpd[949]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 173.208.141.185 in vrf default
Jul 08 04:26:59 edge-01.us-kc.tackitt.us bgpd[949]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2604:4300:a:3e7::1 in vrf default
Jul 08 04:27:00 edge-01.us-kc.tackitt.us bgpd[949]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2602:fb67:101::2 in vrf default
Jul 08 04:27:00 edge-01.us-kc.tackitt.us bgpd[949]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2602:fb67:101::10 in vrf default
Jul 08 04:27:02 edge-01.us-kc.tackitt.us bgpd[949]: [QN9FK-3DQX7] snmp[info]: NET-SNMP version 5.9.3 AgentX subagent connected
Jul 08 04:27:09 edge-01.us-kc.tackitt.us bgpd[949]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.188 in vrf default
Jul 08 04:27:09 edge-01.us-kc.tackitt.us bgpd[949]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::37 in vrf default
Jul 08 04:27:10 edge-01.us-kc.tackitt.us bgpd[949]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::13 in vrf default
Jul 08 04:27:13 edge-01.us-kc.tackitt.us bgpd[949]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.192 in vrf default
Jul 08 04:27:14 edge-01.us-kc.tackitt.us bgpd[949]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.13 in vrf default
Jul 08 04:27:16 edge-01.us-kc.tackitt.us bgpd[949]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.37 in vrf default
Jul 08 04:27:28 edge-01.us-kc.tackitt.us bgpd[949]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 2602:fb67:1:ffff::2 in vrf default
Jul 08 04:27:28 edge-01.us-kc.tackitt.us bgpd[949]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2602:fb67:1:ffff::2 in vrf default
Jul 08 04:27:34 edge-01.us-kc.tackitt.us bgpd[949]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::188 in vrf default
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: Received signal 11 at 1688790456 (si_addr 0xfffffffffffffffc, PC 0x7f31e4fb3c38); aborting...
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(zlog_backtrace_sigsafe+0x6f) [0x7f31e61a101f]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(zlog_signal+0xf5) [0x7f31e61a1225]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(+0xd0c91) [0x7f31e61cec91]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /lib/x86_64-linux-gnu/libc.so.6(+0x3bf90) [0x7f31e5e5ef90]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/x86_64-linux-gnu/frr/modules/bgpd_rpki.so(+0x6c38) [0x7f31e4fb3c38]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/x86_64-linux-gnu/frr/modules/bgpd_rpki.so(+0x6d1f) [0x7f31e4fb3d1f]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(+0xc336a) [0x7f31e61c136a]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(route_map_apply_ext+0x205) [0x7f31e61c2ee5]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/frr/bgpd(subgroup_announce_check+0x1398) [0x557beeed4328]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/frr/bgpd(subgroup_announce_table+0x17d) [0x557beef00aad]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/frr/bgpd(+0x186e5a) [0x557beef00e5a]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(thread_call+0x7d) [0x7f31e61e0b7d]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(frr_run+0xe8) [0x7f31e6199328]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/frr/bgpd(main+0x36b) [0x557beee633ab]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /lib/x86_64-linux-gnu/libc.so.6(+0x2718a) [0x7f31e5e4a18a]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7f31e5e4a245]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: /usr/lib/frr/bgpd(_start+0x21) [0x557beee650b1]
Jul 08 04:27:36 edge-01.us-kc.tackitt.us BGP[949]: in thread subgroup_coalesce_timer scheduled from ../bgpd/bgp_updgrp_adv.c:1036 subgroup_announce_all()
Jul 08 04:27:41 edge-01.us-kc.tackitt.us bgpd[5638]: [GNAYN-F5F1G] Computing addpath IDs for addpath type All
Jul 08 04:27:41 edge-01.us-kc.tackitt.us bgpd[5638]: [GJPH1-W8PZV] Resetting peer 2a0c:2f07:9459::b6(Unknown) due to change in addpath config
Jul 08 04:27:41 edge-01.us-kc.tackitt.us bgpd[5638]: [VTVCM-Y2NW3] Configuration Read in Took: 00:00:00
Jul 08 04:27:45 edge-01.us-kc.tackitt.us bgpd[5638]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2604:4300:a:3e7::1 in vrf default
Jul 08 04:27:45 edge-01.us-kc.tackitt.us bgpd[5638]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::126 in vrf default
Jul 08 04:27:45 edge-01.us-kc.tackitt.us bgpd[5638]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.126 in vrf default
Jul 08 04:27:45 edge-01.us-kc.tackitt.us bgpd[5638]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::188 in vrf default
Jul 08 04:27:45 edge-01.us-kc.tackitt.us bgpd[5638]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.192 in vrf default
Jul 08 04:27:46 edge-01.us-kc.tackitt.us bgpd[5638]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.188 in vrf default
Jul 08 04:27:46 edge-01.us-kc.tackitt.us bgpd[5638]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.13 in vrf default
Jul 08 04:27:46 edge-01.us-kc.tackitt.us bgpd[5638]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.37 in vrf default
Jul 08 04:27:46 edge-01.us-kc.tackitt.us bgpd[5638]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::13 in vrf default
Jul 08 04:27:46 edge-01.us-kc.tackitt.us bgpd[5638]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::37 in vrf default
Jul 08 04:27:46 edge-01.us-kc.tackitt.us bgpd[5638]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2602:fb67:101::2 in vrf default
Jul 08 04:27:46 edge-01.us-kc.tackitt.us bgpd[5638]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2602:fb67:101::10 in vrf default
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: Received signal 11 at 1688790467 (si_addr 0xfffffffffffffffc, PC 0x7f1a9ae1ac38); aborting...
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(zlog_backtrace_sigsafe+0x6f) [0x7f1a9c00801f]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(zlog_signal+0xf5) [0x7f1a9c008225]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(+0xd0c91) [0x7f1a9c035c91]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /lib/x86_64-linux-gnu/libc.so.6(+0x3bf90) [0x7f1a9bcc5f90]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/x86_64-linux-gnu/frr/modules/bgpd_rpki.so(+0x6c38) [0x7f1a9ae1ac38]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/x86_64-linux-gnu/frr/modules/bgpd_rpki.so(+0x6d1f) [0x7f1a9ae1ad1f]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(+0xc336a) [0x7f1a9c02836a]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(route_map_apply_ext+0x205) [0x7f1a9c029ee5]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/frr/bgpd(subgroup_announce_check+0x1398) [0x562d5fdc6328]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/frr/bgpd(subgroup_announce_table+0x17d) [0x562d5fdf2aad]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/frr/bgpd(peer_af_announce_route+0xc3) [0x562d5fdf1283]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/frr/bgpd(+0x152335) [0x562d5fdbe335]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(thread_call+0x7d) [0x7f1a9c047b7d]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(frr_run+0xe8) [0x7f1a9c000328]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/frr/bgpd(main+0x36b) [0x562d5fd553ab]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /lib/x86_64-linux-gnu/libc.so.6(+0x2718a) [0x7f1a9bcb118a]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7f1a9bcb1245]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: /usr/lib/frr/bgpd(_start+0x21) [0x562d5fd570b1]
Jul 08 04:27:47 edge-01.us-kc.tackitt.us BGP[5638]: in thread bgp_announce_route_timer_expired scheduled from ../bgpd/bgp_route.c:5107 bgp_announce_route()
Jul 08 04:27:58 edge-01.us-kc.tackitt.us bgpd[5781]: [GNAYN-F5F1G] Computing addpath IDs for addpath type All
Jul 08 04:27:58 edge-01.us-kc.tackitt.us bgpd[5781]: [GJPH1-W8PZV] Resetting peer 2a0c:2f07:9459::b6(Unknown) due to change in addpath config
Jul 08 04:27:58 edge-01.us-kc.tackitt.us bgpd[5781]: [VTVCM-Y2NW3] Configuration Read in Took: 00:00:00
Jul 08 04:27:58 edge-01.us-kc.tackitt.us bgpd[5781]: [QN9FK-3DQX7] snmp[info]: NET-SNMP version 5.9.3 AgentX subagent connected
Jul 08 04:28:02 edge-01.us-kc.tackitt.us bgpd[5781]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2604:4300:a:3e7::1 in vrf default
Jul 08 04:28:02 edge-01.us-kc.tackitt.us bgpd[5781]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::126 in vrf default
Jul 08 04:28:02 edge-01.us-kc.tackitt.us bgpd[5781]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.126 in vrf default
Jul 08 04:28:02 edge-01.us-kc.tackitt.us bgpd[5781]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::188 in vrf default
Jul 08 04:28:02 edge-01.us-kc.tackitt.us bgpd[5781]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.192 in vrf default
Jul 08 04:28:04 edge-01.us-kc.tackitt.us bgpd[5781]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.13 in vrf default
Jul 08 04:28:04 edge-01.us-kc.tackitt.us bgpd[5781]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.37 in vrf default
Jul 08 04:28:04 edge-01.us-kc.tackitt.us bgpd[5781]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::13 in vrf default
Jul 08 04:28:04 edge-01.us-kc.tackitt.us bgpd[5781]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::37 in vrf default
Jul 08 04:28:04 edge-01.us-kc.tackitt.us bgpd[5781]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2602:fb67:101::2 in vrf default
Jul 08 04:28:04 edge-01.us-kc.tackitt.us bgpd[5781]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2602:fb67:101::10 in vrf default
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: Received signal 11 at 1688790484 (si_addr 0xfffffffffffffffc, PC 0x7f4239ef6c38); aborting...
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(zlog_backtrace_sigsafe+0x6f) [0x7f423b0e401f]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(zlog_signal+0xf5) [0x7f423b0e4225]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(+0xd0c91) [0x7f423b111c91]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /lib/x86_64-linux-gnu/libc.so.6(+0x3bf90) [0x7f423ada1f90]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/x86_64-linux-gnu/frr/modules/bgpd_rpki.so(+0x6c38) [0x7f4239ef6c38]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/x86_64-linux-gnu/frr/modules/bgpd_rpki.so(+0x6d1f) [0x7f4239ef6d1f]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(+0xc336a) [0x7f423b10436a]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(route_map_apply_ext+0x205) [0x7f423b105ee5]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/frr/bgpd(subgroup_announce_check+0x1398) [0x561307f74328]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/frr/bgpd(subgroup_announce_table+0x17d) [0x561307fa0aad]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/frr/bgpd(peer_af_announce_route+0xc3) [0x561307f9f283]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/frr/bgpd(+0x152335) [0x561307f6c335]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(thread_call+0x7d) [0x7f423b123b7d]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(frr_run+0xe8) [0x7f423b0dc328]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/frr/bgpd(main+0x36b) [0x561307f033ab]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /lib/x86_64-linux-gnu/libc.so.6(+0x2718a) [0x7f423ad8d18a]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7f423ad8d245]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: /usr/lib/frr/bgpd(_start+0x21) [0x561307f050b1]
Jul 08 04:28:04 edge-01.us-kc.tackitt.us BGP[5781]: in thread bgp_announce_route_timer_expired scheduled from ../bgpd/bgp_route.c:5107 bgp_announce_route()
Jul 08 04:28:45 edge-01.us-kc.tackitt.us bgpd[5850]: [GNAYN-F5F1G] Computing addpath IDs for addpath type All
Jul 08 04:28:45 edge-01.us-kc.tackitt.us bgpd[5850]: [GJPH1-W8PZV] Resetting peer 2a0c:2f07:9459::b6(Unknown) due to change in addpath config
Jul 08 04:28:45 edge-01.us-kc.tackitt.us bgpd[5850]: [VTVCM-Y2NW3] Configuration Read in Took: 00:00:00
Jul 08 04:28:49 edge-01.us-kc.tackitt.us bgpd[5850]: [MVZKX-EG443][EC 33554452] bgp_process_packet: BGP OPEN receipt failed for peer: 2001:504:1b:1::188
Jul 08 04:28:49 edge-01.us-kc.tackitt.us bgpd[5850]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2604:4300:a:3e7::1 in vrf default
Jul 08 04:28:49 edge-01.us-kc.tackitt.us bgpd[5850]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::126 in vrf default
Jul 08 04:28:49 edge-01.us-kc.tackitt.us bgpd[5850]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.126 in vrf default
Jul 08 04:28:49 edge-01.us-kc.tackitt.us bgpd[5850]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::188 in vrf default
Jul 08 04:28:49 edge-01.us-kc.tackitt.us bgpd[5850]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.192 in vrf default
Jul 08 04:28:50 edge-01.us-kc.tackitt.us bgpd[5850]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.188 in vrf default
Jul 08 04:28:50 edge-01.us-kc.tackitt.us bgpd[5850]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.13 in vrf default
Jul 08 04:28:50 edge-01.us-kc.tackitt.us bgpd[5850]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv4 Unicast from 206.51.7.37 in vrf default
Jul 08 04:28:50 edge-01.us-kc.tackitt.us bgpd[5850]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::37 in vrf default
Jul 08 04:28:50 edge-01.us-kc.tackitt.us bgpd[5850]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2001:504:1b:1::13 in vrf default
Jul 08 04:28:50 edge-01.us-kc.tackitt.us bgpd[5850]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2602:fb67:101::2 in vrf default
Jul 08 04:28:50 edge-01.us-kc.tackitt.us bgpd[5850]: [M59KS-A3ZXZ] bgp_update_receive: rcvd End-of-RIB for IPv6 Unicast from 2602:fb67:101::10 in vrf default
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: Received signal 11 at 1688790530 (si_addr 0xfffffffffffffffc, PC 0x7f2b071c6c38); aborting...
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(zlog_backtrace_sigsafe+0x6f) [0x7f2b083b401f]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(zlog_signal+0xf5) [0x7f2b083b4225]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(+0xd0c91) [0x7f2b083e1c91]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /lib/x86_64-linux-gnu/libc.so.6(+0x3bf90) [0x7f2b08071f90]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/x86_64-linux-gnu/frr/modules/bgpd_rpki.so(+0x6c38) [0x7f2b071c6c38]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/x86_64-linux-gnu/frr/modules/bgpd_rpki.so(+0x6d1f) [0x7f2b071c6d1f]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(+0xc336a) [0x7f2b083d436a]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(route_map_apply_ext+0x205) [0x7f2b083d5ee5]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/frr/bgpd(subgroup_announce_check+0x1398) [0x55938d5b0328]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/frr/bgpd(subgroup_announce_table+0x17d) [0x55938d5dcaad]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/frr/bgpd(+0x152335) [0x55938d5a8335]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(thread_call+0x7d) [0x7f2b083f3b7d]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/x86_64-linux-gnu/frr/libfrr.so.0(frr_run+0xe8) [0x7f2b083ac328]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/frr/bgpd(main+0x36b) [0x55938d53f3ab]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /lib/x86_64-linux-gnu/libc.so.6(+0x2718a) [0x7f2b0805d18a]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x85) [0x7f2b0805d245]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: /usr/lib/frr/bgpd(_start+0x21) [0x55938d5410b1]
Jul 08 04:28:50 edge-01.us-kc.tackitt.us BGP[5850]: in thread bgp_announce_route_timer_expired scheduled from ../bgpd/bgp_route.c:5107 bgp_announce_route()
BGP configuration
set protocols bgp address-family ipv4-unicast network 23.139.88.0/24
set protocols bgp address-family ipv6-unicast network 2602:fb67:1::/48
set protocols bgp address-family ipv6-unicast network 2602:fb67:100::/40
set protocols bgp address-family ipv6-unicast network 2602:fb67:d::/48
set protocols bgp neighbor 2a0c:2f07:9459::b6 address-family ipv4-unicast addpath-tx-all
set protocols bgp neighbor 2a0c:2f07:9459::b6 address-family ipv6-unicast addpath-tx-all
set protocols bgp neighbor 2a0c:2f07:9459::b6 capability extended-nexthop
set protocols bgp neighbor 2a0c:2f07:9459::b6 description 'bgp.tools'
set protocols bgp neighbor 2a0c:2f07:9459::b6 ebgp-multihop '10'
set protocols bgp neighbor 2a0c:2f07:9459::b6 remote-as '212232'
set protocols bgp neighbor 2a0c:2f07:9459::b6 update-source '2602:fb67:1::1'
set protocols bgp neighbor 173.208.141.185 description 'NOCIX [TRANSIT]'
set protocols bgp neighbor 173.208.141.185 peer-group 'TRANSIT_4'
set protocols bgp neighbor 173.208.141.185 remote-as '33387'
set protocols bgp neighbor 173.208.141.185 update-source '173.208.141.187'
set protocols bgp neighbor 206.51.7.5 description 'HE [KCIX]'
set protocols bgp neighbor 206.51.7.5 peer-group 'KCIX_4'
set protocols bgp neighbor 206.51.7.5 remote-as '6939'
set protocols bgp neighbor 206.51.7.13 description 'NETFLIX [KCIX]'
set protocols bgp neighbor 206.51.7.13 peer-group 'KCIX_4'
set protocols bgp neighbor 206.51.7.13 remote-as '2906'
set protocols bgp neighbor 206.51.7.34 description 'Cloudflare [KCIX]'
set protocols bgp neighbor 206.51.7.34 peer-group 'KCIX_4'
set protocols bgp neighbor 206.51.7.34 remote-as '13335'
set protocols bgp neighbor 206.51.7.37 description 'NETFLIX [KCIX]'
set protocols bgp neighbor 206.51.7.37 peer-group 'KCIX_4'
set protocols bgp neighbor 206.51.7.37 remote-as '2906'
set protocols bgp neighbor 206.51.7.126 description 'RS [KCIX]'
set protocols bgp neighbor 206.51.7.126 peer-group 'KCIX_4'
set protocols bgp neighbor 206.51.7.126 remote-as '40542'
set protocols bgp neighbor 206.51.7.188 description 'Thomas347 [KCIX]'
set protocols bgp neighbor 206.51.7.188 peer-group 'KCIX_4'
set protocols bgp neighbor 206.51.7.188 remote-as '200454'
set protocols bgp neighbor 206.51.7.192 address-family ipv4-unicast default-originate
set protocols bgp neighbor 206.51.7.192 address-family ipv4-unicast route-map export 'PT-ATHARVA-OUT'
set protocols bgp neighbor 206.51.7.192 address-family ipv4-unicast route-map import 'PT-ATHARVA-IN'
set protocols bgp neighbor 206.51.7.192 description 'PT Atharva [KCIX]'
set protocols bgp neighbor 206.51.7.192 peer-group 'KCIX_4_T'
set protocols bgp neighbor 206.51.7.192 remote-as '150249'
set protocols bgp neighbor 206.51.7.193 description 'Hawk Jizbel[KCIX]'
set protocols bgp neighbor 206.51.7.193 peer-group 'KCIX_4'
set protocols bgp neighbor 206.51.7.193 remote-as '21738'
set protocols bgp neighbor 2001:504:1b:1::5 description 'HE [KCIX]'
set protocols bgp neighbor 2001:504:1b:1::5 peer-group 'KCIX_6'
set protocols bgp neighbor 2001:504:1b:1::5 remote-as '6939'
set protocols bgp neighbor 2001:504:1b:1::13 description 'NETFLIX [KCIX]'
set protocols bgp neighbor 2001:504:1b:1::13 peer-group 'KCIX_6'
set protocols bgp neighbor 2001:504:1b:1::13 remote-as '2906'
set protocols bgp neighbor 2001:504:1b:1::34 description 'Cloudflare [KCIX]'
set protocols bgp neighbor 2001:504:1b:1::34 peer-group 'KCIX_6'
set protocols bgp neighbor 2001:504:1b:1::34 remote-as '13335'
set protocols bgp neighbor 2001:504:1b:1::37 description 'NETFLIX [KCIX]'
set protocols bgp neighbor 2001:504:1b:1::37 peer-group 'KCIX_6'
set protocols bgp neighbor 2001:504:1b:1::37 remote-as '2906'
set protocols bgp neighbor 2001:504:1b:1::126 description 'RS [KCIX]'
set protocols bgp neighbor 2001:504:1b:1::126 peer-group 'KCIX_6'
set protocols bgp neighbor 2001:504:1b:1::126 remote-as '40542'
set protocols bgp neighbor 2001:504:1b:1::188 description 'Thomas347 [KCIX]'
set protocols bgp neighbor 2001:504:1b:1::188 peer-group 'KCIX_6'
set protocols bgp neighbor 2001:504:1b:1::188 remote-as '200454'
set protocols bgp neighbor 2001:504:1b:1::192 address-family ipv6-unicast default-originate
set protocols bgp neighbor 2001:504:1b:1::192 address-family ipv6-unicast route-map export 'PT-ATHARVA-OUT'
set protocols bgp neighbor 2001:504:1b:1::192 address-family ipv6-unicast route-map import 'PT-ATHARVA-IN'
set protocols bgp neighbor 2001:504:1b:1::192 description 'PT Atharva [KCIX]'
set protocols bgp neighbor 2001:504:1b:1::192 peer-group 'KCIX_6_T'
set protocols bgp neighbor 2001:504:1b:1::192 remote-as '150249'
set protocols bgp neighbor 2001:504:1b:1::193 description 'Hawk Jizbel[KCIX]'
set protocols bgp neighbor 2001:504:1b:1::193 peer-group 'KCIX_6'
set protocols bgp neighbor 2001:504:1b:1::193 remote-as '21738'
set protocols bgp neighbor 2602:fb67:1:ffff::2 address-family ipv4-unicast default-originate
set protocols bgp neighbor 2602:fb67:1:ffff::2 address-family ipv4-unicast prefix-list export 'DEF-ONLY-4'
set protocols bgp neighbor 2602:fb67:1:ffff::2 address-family ipv6-unicast default-originate
set protocols bgp neighbor 2602:fb67:1:ffff::2 address-family ipv6-unicast prefix-list export 'DEF-ONLY-6'
set protocols bgp neighbor 2602:fb67:1:ffff::2 capability extended-nexthop
set protocols bgp neighbor 2602:fb67:1:ffff::2 description 'core-01.us-kc'
set protocols bgp neighbor 2602:fb67:1:ffff::2 remote-as '397244'
set protocols bgp neighbor 2602:fb67:101::2 address-family ipv6-unicast route-map export 'GENERIC-OUT'
set protocols bgp neighbor 2602:fb67:101::2 description 'RS [NAVIX]'
set protocols bgp neighbor 2602:fb67:101::2 ebgp-multihop '5'
set protocols bgp neighbor 2602:fb67:101::2 peer-group 'NAVIX'
set protocols bgp neighbor 2602:fb67:101::2 remote-as '65000'
set protocols bgp neighbor 2602:fb67:101::10 address-family ipv6-unicast default-originate
set protocols bgp neighbor 2602:fb67:101::10 description 'tackitt.us [NAVIX]'
set protocols bgp neighbor 2602:fb67:101::10 peer-group 'NAVIX'
set protocols bgp neighbor 2602:fb67:101::10 remote-as '65002'
set protocols bgp neighbor 2604:4300:a:3e7::1 description 'NOCIX [TRANSIT]'
set protocols bgp neighbor 2604:4300:a:3e7::1 peer-group 'TRANSIT_6'
set protocols bgp neighbor 2604:4300:a:3e7::1 remote-as '33387'
set protocols bgp neighbor 2604:4300:a:3e7::1 update-source '2604:4300:a:3e7::2'
set protocols bgp peer-group KCIX_4 address-family ipv4-unicast remove-private-as
set protocols bgp peer-group KCIX_4 address-family ipv4-unicast route-map export 'GENERIC-OUT'
set protocols bgp peer-group KCIX_4 address-family ipv4-unicast route-map import 'GENERIC-IN'
set protocols bgp peer-group KCIX_4 capability dynamic
set protocols bgp peer-group KCIX_4 update-source '206.51.7.156'
set protocols bgp peer-group KCIX_4_T capability dynamic
set protocols bgp peer-group KCIX_4_T update-source '206.51.7.156'
set protocols bgp peer-group KCIX_6 address-family ipv6-unicast remove-private-as
set protocols bgp peer-group KCIX_6 address-family ipv6-unicast route-map export 'GENERIC-OUT'
set protocols bgp peer-group KCIX_6 address-family ipv6-unicast route-map import 'GENERIC-IN'
set protocols bgp peer-group KCIX_6 capability dynamic
set protocols bgp peer-group KCIX_6 update-source '2001:504:1b:1::156'
set protocols bgp peer-group KCIX_6_T capability dynamic
set protocols bgp peer-group KCIX_6_T update-source '2001:504:1b:1::156'
set protocols bgp peer-group NAVIX address-family ipv6-unicast
set protocols bgp peer-group NAVIX capability dynamic
set protocols bgp peer-group TRANSIT_4 address-family ipv4-unicast remove-private-as
set protocols bgp peer-group TRANSIT_4 address-family ipv4-unicast route-map export 'GENERIC-OUT'
set protocols bgp peer-group TRANSIT_4 address-family ipv4-unicast route-map import 'GENERIC-IN'
set protocols bgp peer-group TRANSIT_4 address-family ipv4-unicast weight '100'
set protocols bgp peer-group TRANSIT_6 address-family ipv6-unicast remove-private-as
set protocols bgp peer-group TRANSIT_6 address-family ipv6-unicast route-map export 'GENERIC-OUT'
set protocols bgp peer-group TRANSIT_6 address-family ipv6-unicast route-map import 'GENERIC-IN'
set protocols bgp peer-group TRANSIT_6 address-family ipv6-unicast weight '100'
set protocols bgp system-as '397244'
vtysh output
Building configuration...
Current configuration:
hostname edge-01.us-kc.tackitt.us
service integrated-vtysh-config
end
at this time, my bgpd will not stay active.
Here is the vtysh output with bgpd active:
frr version 8.5.2
frr defaults traditional
log syslog
log facility local7
agentx
router bgp 397244
no bgp ebgp-requires-policy
no bgp default ipv4-unicast
no bgp network import-check
neighbor KCIX_4 peer-group
neighbor KCIX_4 update-source 206.51.7.156
neighbor KCIX_4 capability dynamic
neighbor KCIX_4_T peer-group
neighbor KCIX_4_T update-source 206.51.7.156
neighbor KCIX_4_T capability dynamic
neighbor KCIX_6 peer-group
neighbor KCIX_6 update-source 2001:504:1b:1::156
neighbor KCIX_6 capability dynamic
neighbor KCIX_6_T peer-group
neighbor KCIX_6_T update-source 2001:504:1b:1::156
neighbor KCIX_6_T capability dynamic
neighbor NAVIX peer-group
neighbor NAVIX capability dynamic
neighbor TRANSIT_4 peer-group
neighbor TRANSIT_6 peer-group
neighbor 206.51.7.5 remote-as 6939
neighbor 206.51.7.5 peer-group KCIX_4
neighbor 206.51.7.5 description HE [KCIX]
neighbor 206.51.7.13 remote-as 2906
neighbor 206.51.7.13 peer-group KCIX_4
neighbor 206.51.7.13 description NETFLIX [KCIX]
neighbor 206.51.7.34 remote-as 13335
neighbor 206.51.7.34 peer-group KCIX_4
neighbor 206.51.7.34 description Cloudflare [KCIX]
neighbor 206.51.7.37 remote-as 2906
neighbor 206.51.7.37 peer-group KCIX_4
neighbor 206.51.7.37 description NETFLIX [KCIX]
neighbor 206.51.7.126 remote-as 40542
neighbor 206.51.7.126 peer-group KCIX_4
neighbor 206.51.7.126 description RS [KCIX]
neighbor 206.51.7.188 remote-as 200454
neighbor 206.51.7.188 peer-group KCIX_4
neighbor 206.51.7.188 description Thomas347 [KCIX]
neighbor 206.51.7.193 remote-as 21738
neighbor 206.51.7.193 peer-group KCIX_4
neighbor 206.51.7.193 description Hawk Jizbel[KCIX]
neighbor 206.51.7.192 remote-as 150249
neighbor 206.51.7.192 peer-group KCIX_4_T
neighbor 206.51.7.192 description PT Atharva [KCIX]
neighbor 2001:504:1b:1::5 remote-as 6939
neighbor 2001:504:1b:1::5 peer-group KCIX_6
neighbor 2001:504:1b:1::5 description HE [KCIX]
neighbor 2001:504:1b:1::13 remote-as 2906
neighbor 2001:504:1b:1::13 peer-group KCIX_6
neighbor 2001:504:1b:1::13 description NETFLIX [KCIX]
neighbor 2001:504:1b:1::34 remote-as 13335
neighbor 2001:504:1b:1::34 peer-group KCIX_6
neighbor 2001:504:1b:1::34 description Cloudflare [KCIX]
neighbor 2001:504:1b:1::37 remote-as 2906
neighbor 2001:504:1b:1::37 peer-group KCIX_6
neighbor 2001:504:1b:1::37 description NETFLIX [KCIX]
neighbor 2001:504:1b:1::126 remote-as 40542
neighbor 2001:504:1b:1::126 peer-group KCIX_6
neighbor 2001:504:1b:1::126 description RS [KCIX]
neighbor 2001:504:1b:1::188 remote-as 200454
neighbor 2001:504:1b:1::188 peer-group KCIX_6
neighbor 2001:504:1b:1::188 description Thomas347 [KCIX]
neighbor 2001:504:1b:1::193 remote-as 21738
neighbor 2001:504:1b:1::193 peer-group KCIX_6
neighbor 2001:504:1b:1::193 description Hawk Jizbel[KCIX]
neighbor 2001:504:1b:1::192 remote-as 150249
neighbor 2001:504:1b:1::192 peer-group KCIX_6_T
neighbor 2001:504:1b:1::192 description PT Atharva [KCIX]
neighbor 2602:fb67:101::2 remote-as 65000
neighbor 2602:fb67:101::2 peer-group NAVIX
neighbor 2602:fb67:101::2 description RS [NAVIX]
neighbor 2602:fb67:101::2 ebgp-multihop 5
neighbor 2602:fb67:101::10 remote-as 65002
neighbor 2602:fb67:101::10 peer-group NAVIX
neighbor 2602:fb67:101::10 description tackitt.us [NAVIX]
neighbor 173.208.141.185 remote-as 33387
neighbor 173.208.141.185 peer-group TRANSIT_4
neighbor 173.208.141.185 description NOCIX [TRANSIT]
neighbor 173.208.141.185 update-source 173.208.141.187
neighbor 2604:4300:a:3e7::1 remote-as 33387
neighbor 2604:4300:a:3e7::1 peer-group TRANSIT_6
neighbor 2604:4300:a:3e7::1 description NOCIX [TRANSIT]
neighbor 2604:4300:a:3e7::1 update-source 2604:4300:a:3e7::2
neighbor 2602:fb67:1:ffff::2 remote-as 397244
neighbor 2602:fb67:1:ffff::2 description core-01.us-kc
neighbor 2a0c:2f07:9459::b6 remote-as 212232
neighbor 2a0c:2f07:9459::b6 description bgp.tools
neighbor 2a0c:2f07:9459::b6 ebgp-multihop 10
neighbor 2a0c:2f07:9459::b6 update-source 2602:fb67:1::1
address-family ipv4 unicast
neighbor KCIX_4 activate
neighbor KCIX_4 remove-private-AS
neighbor KCIX_4 route-map GENERIC-IN in
neighbor KCIX_4 route-map GENERIC-OUT out
neighbor TRANSIT_4 activate
neighbor TRANSIT_4 remove-private-AS
neighbor TRANSIT_4 weight 100
neighbor TRANSIT_4 route-map GENERIC-IN in
neighbor TRANSIT_4 route-map GENERIC-OUT out
neighbor 206.51.7.192 activate
neighbor 206.51.7.192 default-originate
neighbor 206.51.7.192 route-map PT-ATHARVA-IN in
neighbor 206.51.7.192 route-map PT-ATHARVA-OUT out
neighbor 2602:fb67:1:ffff::2 activate
neighbor 2602:fb67:1:ffff::2 default-originate
neighbor 2602:fb67:1:ffff::2 prefix-list DEF-ONLY-4 out
neighbor 2a0c:2f07:9459::b6 activate
neighbor 2a0c:2f07:9459::b6 addpath-tx-all-paths
exit-address-family
address-family ipv6 unicast
neighbor KCIX_6 activate
neighbor KCIX_6 remove-private-AS
neighbor KCIX_6 route-map GENERIC-IN in
neighbor KCIX_6 route-map GENERIC-OUT out
neighbor NAVIX activate
neighbor TRANSIT_6 activate
neighbor TRANSIT_6 remove-private-AS
neighbor TRANSIT_6 weight 100
neighbor TRANSIT_6 route-map GENERIC-IN in
neighbor TRANSIT_6 route-map GENERIC-OUT out
neighbor 2001:504:1b:1::192 activate
neighbor 2001:504:1b:1::192 default-originate
neighbor 2001:504:1b:1::192 route-map PT-ATHARVA-IN in
neighbor 2001:504:1b:1::192 route-map PT-ATHARVA-OUT out
neighbor 2602:fb67:101::2 route-map GENERIC-OUT out
neighbor 2602:fb67:101::10 default-originate
neighbor 2602:fb67:1:ffff::2 prefix-list DEF-ONLY-6 out
exit-address-family
exit
ip prefix-list Bogons-IPv4 description Check if the IPv4 prefix is non-globally routable prefixes
ip prefix-list Bogons-IPv4 seq 10 permit 0.0.0.0/8 le 32
ip prefix-list Bogons-IPv4 seq 20 permit 10.0.0.0/8 le 32
ip prefix-list Bogons-IPv4 seq 30 permit 100.64.0.0/10 le 32
ip prefix-list Bogons-IPv4 seq 40 permit 127.0.0.0/8 le 32
ip prefix-list Bogons-IPv4 seq 50 permit 169.254.0.0/16 le 32
ip prefix-list Bogons-IPv4 seq 60 permit 172.16.0.0/12 le 32
ip prefix-list Bogons-IPv4 seq 70 permit 192.0.2.0/24 le 32
ip prefix-list Bogons-IPv4 seq 80 permit 192.88.99.0/24 le 32
ip prefix-list Bogons-IPv4 seq 90 permit 192.168.0.0/16 le 32
ip prefix-list Bogons-IPv4 seq 100 permit 198.18.0.0/15 le 32
ip prefix-list Bogons-IPv4 seq 110 permit 198.51.100.0/24 le 32
ip prefix-list Bogons-IPv4 seq 120 permit 203.0.113.0/24 le 32
ip prefix-list Bogons-IPv4 seq 130 permit 224.0.0.0/4 le 32
ip prefix-list Bogons-IPv4 seq 140 permit 240.0.0.0/4 le 32
ip prefix-list DEF-ONLY-4 seq 1 permit 0.0.0.0/0 le 1
ip prefix-list PT-ATHARVA-4 seq 1 permit 103.87.68.0/24 ge 24 le 24
ip prefix-list Small-IPv4 description Matches IPv4 block that is smaller than /24
ip prefix-list Small-IPv4 seq 10 deny 0.0.0.0/0 le 24
ip prefix-list Small-IPv4 seq 20 permit 0.0.0.0/0 le 32
ip prefix-list TACKITT-4 seq 1 permit 23.139.88.0/24
ipv6 prefix-list Bogons-IPv6 description Check if the IPv6 prefix is non-globally routable prefixes
ipv6 prefix-list Bogons-IPv6 seq 10 permit ::/8 le 128
ipv6 prefix-list Bogons-IPv6 seq 20 permit 100::/64 le 128
ipv6 prefix-list Bogons-IPv6 seq 30 permit 2001:2::/48 le 128
ipv6 prefix-list Bogons-IPv6 seq 40 permit 2001:10::/28 le 128
ipv6 prefix-list Bogons-IPv6 seq 50 permit 2001:db8::/32 le 128
ipv6 prefix-list Bogons-IPv6 seq 60 permit 2002::/16 le 128
ipv6 prefix-list Bogons-IPv6 seq 70 permit 3ffe::/16 le 128
ipv6 prefix-list Bogons-IPv6 seq 80 permit fc00::/7 le 128
ipv6 prefix-list Bogons-IPv6 seq 90 permit fe80::/10 le 128
ipv6 prefix-list Bogons-IPv6 seq 100 permit fec0::/10 le 128
ipv6 prefix-list Bogons-IPv6 seq 110 permit ff00::/8 le 128
ipv6 prefix-list DEF-ONLY-6 seq 1 permit ::/0 le 1
ipv6 prefix-list PT-ATHARVA-6 seq 1 permit 2001:df1:7340::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 2 permit 2a05:1082:f::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 3 permit 2a05:dfc1:800::/40 ge 40 le 40
ipv6 prefix-list PT-ATHARVA-6 seq 4 permit 2a05:dfc1:800::/47 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 5 permit 2a05:dfc1:803::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 6 permit 2a05:dfc1:816::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 7 permit 2a05:dfc1:888::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 8 permit 2a05:dfc1:4b00::/40 ge 40 le 40
ipv6 prefix-list PT-ATHARVA-6 seq 9 permit 2a05:dfc1:4b01::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 10 permit 2a05:dfc1:4b02::/47 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 11 permit 2a05:dfc1:4b04::/46 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 12 permit 2a05:dfc1:4b08::/47 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 13 permit 2a05:dfc1:4b10::/46 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 14 permit 2a05:dfc1:4b14::/47 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 15 permit 2a05:dfc7:aa00::/40 ge 40 le 40
ipv6 prefix-list PT-ATHARVA-6 seq 16 permit 2a05:dfc7:bc00::/38 ge 39 le 39
ipv6 prefix-list PT-ATHARVA-6 seq 17 permit 2a06:1287:5400::/39 ge 39 le 39
ipv6 prefix-list PT-ATHARVA-6 seq 18 permit 2a06:1287:5410::/44 ge 44 le 44
ipv6 prefix-list PT-ATHARVA-6 seq 19 permit 2a06:1287:5420::/43 ge 44 le 44
ipv6 prefix-list PT-ATHARVA-6 seq 20 permit 2a06:1287:5440::/43 ge 44 le 44
ipv6 prefix-list PT-ATHARVA-6 seq 21 permit 2a06:1287:5460::/44 ge 44 le 44
ipv6 prefix-list PT-ATHARVA-6 seq 22 permit 2a06:a005:6::/47 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 23 permit 2a06:a005:15d9::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 24 permit 2a07:22c1:ffe5::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 25 permit 2a07:54c2:b00b::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 26 permit 2a0a:280:1000::/40 ge 40 le 40
ipv6 prefix-list PT-ATHARVA-6 seq 27 permit 2a0a:280:1200::/40 ge 40 le 40
ipv6 prefix-list PT-ATHARVA-6 seq 28 permit 2a0a:280:2800::/40 ge 40 le 40
ipv6 prefix-list PT-ATHARVA-6 seq 29 permit 2a0a:280:2801::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 30 permit 2a0a:280:2802::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 31 permit 2a0a:280:2a00::/40 ge 40 le 40
ipv6 prefix-list PT-ATHARVA-6 seq 32 permit 2a0a:280:b000::/36 ge 36 le 36
ipv6 prefix-list PT-ATHARVA-6 seq 33 permit 2a0a:280:b00b::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 34 permit 2a0a:6040:3000::/40 ge 40 le 40
ipv6 prefix-list PT-ATHARVA-6 seq 35 permit 2a0a:6040:fb00::/40 ge 40 le 40
ipv6 prefix-list PT-ATHARVA-6 seq 36 permit 2a0a:6040:fb00::/44 ge 44 le 44
ipv6 prefix-list PT-ATHARVA-6 seq 37 permit 2a0c:9a40:9a00::/40 ge 40 le 40
ipv6 prefix-list PT-ATHARVA-6 seq 38 permit 2a0c:9a40:9aa0::/43 ge 44 le 44
ipv6 prefix-list PT-ATHARVA-6 seq 39 permit 2a0e:b107:198::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 40 permit 2a0e:b107:f14::/47 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 41 permit 2a0e:b107:f16::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 42 permit 2a0e:b107:13d3::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 43 permit 2a0e:fd45:1337::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 44 permit 2a12:dd47:3900::/40 ge 40 le 40
ipv6 prefix-list PT-ATHARVA-6 seq 45 permit 2a12:dd47:8046::/48 ge 48 le 48
ipv6 prefix-list PT-ATHARVA-6 seq 46 permit 2a12:dd47:d300::/40 ge 40 le 40
ipv6 prefix-list PT-ATHARVA-6 seq 47 permit 2a13:b487:1900::/40 ge 40 le 40
ipv6 prefix-list PT-ATHARVA-6 seq 48 permit 2a13:b487:1900::/47 ge 48 le 48
ipv6 prefix-list Small-IPv6 description Matches IPv6 block that is smaller than /48
ipv6 prefix-list Small-IPv6 seq 10 deny ::/0 le 48
ipv6 prefix-list Small-IPv6 seq 20 permit ::/0 le 128
ipv6 prefix-list TACKITT-6 seq 1 permit 2602:fb67::/36 le 48
bgp as-path access-list Bogons-ASN seq 10 permit .*0.*
bgp as-path access-list Bogons-ASN seq 20 permit .*23456.*
bgp as-path access-list Bogons-ASN seq 30 permit .*6449[6-9]|6450[0-9]|6451[01].*
bgp as-path access-list Bogons-ASN seq 40 permit .*6553[6-9]|6554[0-9]|6555[01].*
bgp as-path access-list Bogons-ASN seq 50 permit .*6451[2-9]|645[2-9][0-9]|64[6-9][0-9]{2}|65[0-4][0-9]{2}|655[0-2][0-9]|6553[0-5].*
bgp as-path access-list Bogons-ASN seq 60 permit .*42[0-8][0-9]{7}|429[0-3][0-9]{6}|4294[0-8][0-9]{5}|42949[0-5][0-9]{4}|429496[0-6][0-9]{3}|4294967[01][0-9]{2}|42949672[0-8][0-9]|429496729[0-5].*
bgp as-path access-list Bogons-ASN seq 70 permit .*6555[2-9]|655[6-9][0-9]|65[6-9][0-9]{2}|6[6-9][0-9]{3}|[7-9][0-9]{4}|1[0-2][0-9]{4}|130[0-9]{3}|1310[0-6][0-9]|13107[01].*
bgp as-path access-list PT-ATHARVA-ASN seq 10 permit 150249
route-map GENERIC-IN deny 1
match ip address prefix-list Small-IPv4
exit
route-map GENERIC-IN deny 2
match ipv6 address prefix-list Small-IPv6
exit
route-map GENERIC-IN deny 4
match ip address prefix-list Bogons-IPv4
exit
route-map GENERIC-IN deny 5
match ipv6 address prefix-list Bogons-IPv6
exit
route-map GENERIC-IN permit 6
match rpki valid
set weight 300
exit
route-map GENERIC-IN permit 7
match rpki notfound
set weight 100
exit
route-map GENERIC-IN deny 8
match rpki invalid
exit
route-map GENERIC-IN permit 999
exit
route-map GENERIC-OUT deny 1
exit
route-map GENERIC-OUT deny 2
exit
route-map GENERIC-OUT deny 4
exit
route-map GENERIC-OUT deny 5
exit
route-map GENERIC-OUT permit 6
match rpki valid
on-match goto 10
set weight 300
exit
route-map GENERIC-OUT permit 7
match rpki notfound
on-match goto 10
set weight 100
exit
route-map GENERIC-OUT deny 8
match rpki invalid
exit
route-map GENERIC-OUT permit 10
match ip address prefix-list TACKITT-4
exit
route-map GENERIC-OUT permit 20
match ipv6 address prefix-list TACKITT-6
exit
route-map GENERIC-OUT permit 30
match ip address prefix-list PT-ATHARVA-4
exit
route-map GENERIC-OUT permit 40
match ipv6 address prefix-list PT-ATHARVA-6
exit
route-map GENERIC-OUT deny 999
exit
route-map GENERIC-RM deny 1
exit
route-map GENERIC-RM deny 2
exit
route-map GENERIC-RM deny 4
exit
route-map GENERIC-RM deny 5
exit
route-map GENERIC-RM permit 6
match rpki valid
set weight 300
exit
route-map GENERIC-RM permit 7
match rpki notfound
set weight 100
exit
route-map GENERIC-RM deny 8
match rpki invalid
exit
route-map GENERIC-RM permit 999
exit
route-map PT-ATHARVA-IN deny 1
exit
route-map PT-ATHARVA-IN deny 2
exit
route-map PT-ATHARVA-IN deny 4
exit
route-map PT-ATHARVA-IN deny 5
exit
route-map PT-ATHARVA-IN permit 6
match rpki valid
on-match goto 10
set weight 300
exit
route-map PT-ATHARVA-IN permit 7
match rpki notfound
on-match goto 10
set weight 100
exit
route-map PT-ATHARVA-IN deny 8
match rpki invalid
exit
route-map PT-ATHARVA-IN permit 10
match as-path PT-ATHARVA-ASN
on-match next
exit
route-map PT-ATHARVA-IN permit 20
exit
route-map PT-ATHARVA-IN permit 30
exit
route-map PT-ATHARVA-IN deny 999
exit
route-map PT-ATHARVA-OUT deny 1
exit
route-map PT-ATHARVA-OUT deny 2
exit
route-map PT-ATHARVA-OUT deny 4
exit
route-map PT-ATHARVA-OUT deny 5
exit
route-map PT-ATHARVA-OUT permit 6
match rpki valid
on-match goto 10
set weight 300
exit
route-map PT-ATHARVA-OUT permit 7
match rpki notfound
on-match goto 10
set weight 100
exit
route-map PT-ATHARVA-OUT deny 8
match rpki invalid
exit
route-map PT-ATHARVA-OUT deny 10
exit
route-map PT-ATHARVA-OUT deny 20
exit
route-map PT-ATHARVA-OUT permit 999
exit
rpki
rpki polling_period 300
rpki cache 2602:fb67:1:102::202 323 preference 1
exit
end
Can you also display the output of show version
Thank you
I assume you have done “commit” along with “save” when you are in config mode?
When you say restart bgp you mean you restart just the bgp process and not the VyoS box itself?
Do you get the same error if you restart the VyOS box itself (after you have done “commit” and “save”)?
as far I know , it’s a bug when there is a route-map on bgp session and the deamon is restarted :
although , after the restart , it would still work as usual , does it happens ? or bgp configuration is not longer there. any comment you can share on the T5155 .
