Hello there. I’m pretty new to vyos and it suits my needs pretty much.
But right now I want to try to make in my wireguard gateway for my home network.
What I have rn: freshly installed vyos with 2 interfaces (wan and lan). WAN got it address from dhcp and LAN got dhcp server running on it. Everything works.
So, what I want to do is: route all traffic that coming from my home subnet (i.e. 10.1.0.0/24) through wg0 interface (10.100.0.0/24).
What I’ve tried:
set protocols static interface-route 0.0.0.0/0 next-hop-interface wg0 (not working, could not even ping anything)
set protocols static route 0.0.0.0/0 next-hop 10.100.0.1 (10.100.0.1 is my wg server ip, not working as well)
Any suggestions here?
Some additional info:
show interfaces
Did you set a nat rule using the wireguard interface as your outbound? Your static interface route would be needed as well. If you don’t want to use the wan interface as an outbound then you’d need to disable or delete the nat rule for that interface.
Yes, all routes set up correctly at wireguard server and vyos peer.
at wireguard server allowed-ips is 10.100.253.2/32 (vyos wireguard interface IP address)
at vyos wireguard interfaces allowed-ips is 0.0.0.0/0
I don’t want to add srcnat masquerade for interface because I want to be able to route dynamically at the wireguard server. Wireguard server is notified about my local subnet and I can ping any VM on LAN subnet from wireguard server.
I guess I’m confused about what exactly you are trying to accomplish. You said initially that:
This would normally be done by taking your LAN subnet and nat’ing it out through the WG interface. Maybe you are trying to do something else? Sorry, I’m just not following.
So, how it should look like (i did the same thing on debian via iptables)
I have distant wireguard server: public ip: 2.2.2.2, wireguard interface ip: 10.100.253.1 ( iptables -A FORWARD -i wg0 -j ACCEPT; iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE; iptables -A FORWARD -i eth0 -m state --state RELATED,ESTABLISHED -j ACCEPT;)
I have wireguard peer on vyos (10.100.253.2)
Behind vyos I have local subnet (which can reach internet, have it’s own addresses 10.100.254.0/24, and which can reach wireguard server by it’s wireguard tunnel ip address)
What I want to do is: be able to reach any of those VMs behind vyos. I can route single address through wireguard such as 8.8.8.8 and it does it correctly, but when I’m trying to add 0.0.0.0/0 as a static route everything stops to work as expected (i can’t ping anything, etc).
Sorry, was away for a bit. So you are trying to access the VMs behind vyos from the remote wireguard server? Can you post your vyos configuration (minus sensitive info)?
So I’m confused yet again. Your first post said your WAN is assigned via dhcp, but you have it set static in your configuration. You also have no source nat for LAN outbound but instead have a static route. Why? From where are you trying to access the VMs behind VyOS? From the other end of the wireguard connection?
I changed it from dhcp few minutes away after i reset the whole config on the vyos.
Why I do not have source rule because I have a static route on my main router which allows me to reach devices behind a vyos (add distance=1 dst-address=10.100.254.0/24 gateway=10.66.1.151).
So, what is required: Every VM in 10.100.254.0/24 subnet must go to internet through distant wireguard server (10.100.253.1).
Ok. That all makes much more sense now. So if I were you, I would create a source nat rule with the wireguard Interface as the outbound. Then I’d create a new routing table (let’s say 100) with a static interface route of 0.0.0.0/0 to wg0. Then I’d put the VMs in a firewall group(address if it’s just individual machines or ips). Lasty I would make a policy route (let’s name it MyRouting), add a rule (let’s say 10) which says essentially, if source address is from devices in the VMs firewall address group, then set table 100. I would then apply that policy to your LAN interface. If there are any other devices that you don’t want to use the wireguard route, then I’d maybe make another rule (number 20) and say, if source address ! VMs firewall address group, set table main. Anything from the VMs would be sent over wireguard, everything else would be sent over regular internet route.
I have a very similar setup with my network and Mullvad VPN. I policy route a number of devices or groups of devices on a few vlans over Mullvad. A number of other devices simply route out via my ISP.
