I have a VyOS instance installed as a VM in ProxMox.
It has 1 x Interface attached, eth0, which is sat on our LAN, with a static IP.
It’s next hop for 0.0.0.0 is set to our current router (Unifi USG), and the device can reach the internet and local network fine, similarly we can access it fine from the LAN.
We have 2 x IPSec Site-To-Site tunnels configured, as follow:
1 - AWS, this is setup using BGP and is advertising two routes, the LAN subnet (10.11.12.0/23), and the second VPN tunnels range (10.0.100.0/24), this works fine and is propagated into AWS as expected.
2 - Oracle, this is setup using static routing, static routes are defined on the other side of the tunnel for the LAN Subnet 1(0.11.12.0/23) and the AWS Subnet (10.12.0.0/16).
From the LAN I can ping an access devices on both tunnels, from AWS I can access devices on the LAN. I am unable to test directly from Oracle to LAN as I don’t have access to that site, but I can access it from the LAN so it seems to be working fine.
However what I also need to be able to do it access the Oracle site from the AWS site, and that’s where I’m failing.
I can see the Static Route for the oracle 10.0.100.0/24 network being propagated into the AWS VPC as expected.
But if I attempt a traceroute from a machine on AWS I can see the the traffic is routed over the tunnel as expected, but is then passed from the eth0 of the VyOS system to our internet gateway device.
I do have static routes setup on the gateway for both remote networks pointing to the VyOS instance, and this works internally, but in this context causes an infinite loop as the gateway routes the packet back to VyOS, and it then sends it back to the gateway.
So, I’m obviously missing a step here to tell VyOS to not send the traffic arriving from the AWS address range, with a destination of the Oracle network, to the LAN and instead route it directly to the VPN Tunnel, but I’m not sure how to achieve this, as their isn’t a VTI interface here to route to as it’s a static route based tunnel.
So, if anyone could offer any suggestions that would be amazing, save me having to just setup a second instance and have a tunnel on each
Here’s the current configuration, but some bits redacted!
address 10.11.12.4/23
description DMZ
loopback lo {
vti vti2 {
address 169.#.#.#/30
description "AWS 1"
mtu 1436
vti vti3 {
description “AWS 2“
mtu 1436
nat {
rule 100 {
outbound-interface eth0
address 10.11.12.0/23
translation {
address masquerade
protocols {
bgp 65026 {
address-family {
ipv4-unicast {
network 10.0.100.0/24 {
network 10.11.12.0/23 {
neighbor 169.#.#.# {
address-family {
ipv4-unicast {
soft-reconfiguration {
inbound
remote-as 64512
timers {
holdtime 30
keepalive 10
address-family {
ipv4-unicast {
inbound
remote-as 64512
timers {
holdtime 30
keepalive 10
static {
route 0.0.0.0/0 {
next-hop 10.11.12.1 {
service {
dns {
ssh {
system {
config-management {
commit-revisions 100
console {
device ttyS0 {
speed 115200
host-name vyos
login {
user # {
authentication {
level admin
name-server 10.11.12.1
ntp {
server 0.pool.ntp.org {
server 1.pool.ntp.org {
server 2.pool.ntp.org {
syslog {
global {
facility all {
level info
facility protocols {
level debug
time-zone UTC
vpn {
ipsec {
esp-group ESP2-AES256-SHA1-LT3600-DH5 {
lifetime 3600
mode tunnel
pfs dh-group5
proposal 1 {
encryption aes256
hash sha1
esp-group ESP-AES256-SHA1-LT3600 {
lifetime 3600
mode tunnel
pfs enable
proposal 1 {
encryption aes256
hash sha1
ike-group IKE-AES256-SHA1-LT28800 {
dead-peer-detection {
action restart
interval 15
timeout 30
lifetime 28800
proposal 1 {
dh-group 2
encryption aes128
hash sha1
ipsec-interfaces {
interface eth0
nat-traversal enable
site-to-site {
peer 3.#.#.# {
authentication {
mode pre-shared-secret
connection-type initiate
description "AWS Tunnel 1"
local-address 10.11.12.4
vti {
bind vti2
peer 35.#.#.# {
authentication {
description "AWS Tunnel 2"
vti {
bind vti3
peer 132.#.#.# {
authentication {
id 88.98.164.150
default-esp-group ESP2-AES256-SHA1-LT3600-DH5
description "OCI 2"
tunnel 1 {
local {
prefix 10.11.12.0/23
remote {
prefix 10.0.100.0/24
peer 132.#.#.# {
authentication {
id 88.98.164.150
description "OCI 1"
tunnel 1 {
local {
remote {
Thanks
Gareth
