Hi All.
I am trying to ping from my main ‘LAN’ to a VLAN and just can’t seem to get it work.
My interfaces are setup as follows :
set interfaces ethernet eth1 address '192.168.2.1/24'
set interfaces ethernet eth1 hw-id '90:e2:ba:3f:f2:69'
set interfaces ethernet eth1 vif 172 address '172.16.0.1/12'
set interfaces ethernet eth1 vif 172 description 'servers'
I have included both interfaces in my ‘trust’ zone :
set firewall zone trust default-action 'drop'
set firewall zone trust from local firewall name 'local-trust'
set firewall zone trust from untrust firewall name 'untrust-trust'
set firewall zone trust interface 'pod-cniBridge'
set firewall zone trust interface 'eth1'
set firewall zone trust interface 'eth1.172'
Output of show interfaces :
Interface IP Address MAC VRF MTU S/L Description
eth0 192.168.11.11/24 10:c4:ca:a6:16:50 default 1500 u/u ATT-XSGPON
xxx.xxx.xxx.xxx/23
eth1 192.168.2.1/24 90:e2:ba:3f:f2:69 default 1500 u/u LAN
eth1.172 172.16.0.1/12 90:e2:ba:3f:f2:69 default 1500 u/u servers
lo 127.0.0.1/8 00:00:00:00:00:00 default 65536 u/u
::1/128
veth0 - 56:d7:ee:63:52:76 default 1500 u/u
veth1 - 6a:81:cb:2a:2f:2a default 1500 u/u
veth2 - 92:0f:c3:6a:8e:72 default 1500 u/u
Output of show ip route :
f - OpenFabric,
S>* 0.0.0.0/0 [210/0] via xxx.xxx.xxx.xxx, eth0, weight 1, 17:53:51
C>* xxx.xxx.xxx.0/23 is directly connected, eth0, 17:53:55
C>* 172.16.0.0/12 is directly connected, eth1.172, 17:54:00
C>* 192.168.2.0/24 is directly connected, eth1, 17:54:00
I can ping a host on 172 vlan when logged into the vyos host:
vyos@vyos:~$ ping 172.16.5.1
PING 172.16.5.1 (172.16.5.1) 56(84) bytes of data.
64 bytes from 172.16.5.1: icmp_seq=1 ttl=64 time=0.158 ms
64 bytes from 172.16.5.1: icmp_seq=2 ttl=64 time=0.182 ms
64 bytes from 172.16.5.1: icmp_seq=3 ttl=64 time=0.191 ms
64 bytes from 172.16.5.1: icmp_seq=4 ttl=64 time=0.239 ms
64 bytes from 172.16.5.1: icmp_seq=5 ttl=64 time=0.227 ms
64 bytes from 172.16.5.1: icmp_seq=6 ttl=64 time=0.184 ms
^C
--- 172.16.5.1 ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 5146ms
rtt min/avg/max/mdev = 0.158/0.196/0.239/0.027 ms
But I am unable to ping this host from any other host on 192.168.2.0/24 network.
All hosts on the 192.168.2.0/24 network can route and ping hosts on the Internet :
vyos@vyos:~$ ping one.one.one.one
PING one.one.one.one (1.1.1.1) 56(84) bytes of data.
64 bytes from one.one.one.one (1.1.1.1): icmp_seq=1 ttl=58 time=13.1 ms
64 bytes from one.one.one.one (1.1.1.1): icmp_seq=2 ttl=58 time=13.1 ms
64 bytes from one.one.one.one (1.1.1.1): icmp_seq=3 ttl=58 time=13.3 ms
64 bytes from 1.1.1.1: icmp_seq=4 ttl=58 time=13.2 ms
64 bytes from one.one.one.one (1.1.1.1): icmp_seq=5 ttl=58 time=13.2 ms
64 bytes from 1.1.1.1: icmp_seq=6 ttl=58 time=15.5 ms
64 bytes from one.one.one.one (1.1.1.1): icmp_seq=7 ttl=58 time=13.1 ms
64 bytes from one.one.one.one (1.1.1.1): icmp_seq=8 ttl=58 time=14.8 ms
64 bytes from one.one.one.one (1.1.1.1): icmp_seq=9 ttl=58 time=13.6 ms
64 bytes from one.one.one.one (1.1.1.1): icmp_seq=10 ttl=58 time=14.9 ms
64 bytes from one.one.one.one (1.1.1.1): icmp_seq=11 ttl=58 time=12.9 ms
^C
--- one.one.one.one ping statistics ---
11 packets transmitted, 11 received, 0% packet loss, time 10016ms
rtt min/avg/max/mdev = 12.936/13.702/15.539/0.872 ms
For sure I am missing something simple - but can’t seem to pin-point what I missing. I had this working on another instance of vyos that crashed (flash died).
I am the following version of vyos:
vyos@vyos:~$ show version
Version: VyOS 1.4-rolling-202403042245
Release train: sagitta
Built by: gnarula@some-domain.org
Built on: Mon 04 Mar 2024 22:45 UTC
Build UUID: b2f926d2-e65f-4973-b0cb-070616cea02f
Build commit ID: d42f7e8a9e79da
Architecture: x86_64
Boot via: installed image
System type: KVM guest
Hardware vendor: QEMU
Hardware model: Standard PC (Q35 + ICH9, 2009)
Hardware S/N:
Hardware UUID: 76aaa1be-4633-4586-a155-e02926bf96b2
It’s running as a proxmox VM with NIC’s passed through to the VM.
Would really appreciate any help with how to troubleshoot this issue.
Thanks in advance.
