I am trying to SSH from one VLAN to another, and have run up against my limit of network understanding.
My network consists of a router-on-a-stick and a VLAN-aware switch, and I am using a zone-based firewall. The following image shows the firewall rules in place between what I consider to be the relevant zones.
What I wish to do is SSH from an administration PC (on VLAN30) to a PC on robot1 (on VLAN20). I am able to ping the router interface of VLAN20 (192.168.20.1) from VLAN30, but am unable to ping any of the PCs on VLAN20. Having read a few posts on inter-vlan routing, it seems that a bridge network may be required, but I am not sure.
Can someone please point me in the right direction? Happy to post the relevant bits of my router configuration file if this helps.
Thanks for your reply. The live configuration file runs to over 2000 lines - here is what I hope are the most important bits (apologies if it is still a bit long):
There’s nothing there I can see that shouldn’t work - I suspect you’ll either have a Layer 2 issue (VLANs no working/making it to the router properly) or a firewall/ruleset issue, which as we can’t see your rules we can’t comment on.
Certainly I’d be looking at basic IP connectivity first though.
The client gateway certainly appears to be set properly - the route command has clients on the VLAN20 listed as using 192.168.20.1 so all is well there. In case it is a firewall thing, here are all the rule sets mentioned in the image from the OP. Again, apologies for the length, but there is a lot of repetition.
firewall {
/* [1] */
name infrastructure-local {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
rule 100 {
action accept
description "Accept ICMP requests"
protocol icmp
rule 200 {
action accept
description "Accept HTTP/HTTPS requests"
destination {
group {
port-group hypertext-ports
protocol tcp
rule 600 {
action accept
description "Accept DNS requests"
destination {
port 53
protocol tcp_udp
rule 700 {
action accept
description "Accept DHCP requests"
destination {
port 67,68
protocol udp
rule 800 {
action accept
description "Accept SSH requests"
destination {
port 22
protocol tcp
/* [2] */
name infrastructure-wan {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
rule 100 {
action accept
protocol icmp
rule 200 {
action accept
destination {
group {
protocol tcp
/* [3] */
name robot-1-local {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
rule 100 {
action accept
protocol icmp
rule 600 {
action accept
destination {
port 53
protocol tcp_udp
rule 700 {
action accept
destination {
port 67,68
protocol udp
/* [4] */
name robot-1-wan {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
/* [9] */
name administration-robot-1 {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
rule 100 {
action accept
protocol icmp
rule 200 {
action accept
destination {
group {
protocol tcp
rule 800 {
action accept
destination {
port 22
protocol tcp
/* [16] */
name administration-local {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
rule 100 {
action accept
protocol icmp
rule 600 {
action accept
destination {
port 53
protocol tcp_udp
rule 700 {
action accept
destination {
port 67,68
protocol udp
/* [17] */
name administration-wan {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
rule 100 {
action accept
protocol icmp
rule 200 {
action accept
destination {
group {
protocol tcp
/* [30] */
name local-infrastructure {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
rule 100 {
action accept
protocol icmp
/* [31] */
name local-robot-1 {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
rule 100 {
action accept
protocol icmp
/* [34] */
name local-administration {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
rule 100 {
action accept
protocol icmp
/* [41] */
name local-wan {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
rule 100 {
action accept
protocol icmp
rule 400 {
action accept
description "Accept NTP requests"
destination {
port 123
protocol udp
rule 600 {
action accept
destination {
port 53
protocol tcp_udp
/* [42] */
name wan-infrastructure {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
/* [43] */
name wan-robot-1 {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
/* [53] */
name wan-local {
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
So withouth going over your rules yet - what does the ARP table show. Not interested in the routing table.
show arp
Do you see the MAC Addresses of your clients listed?
What does the ARP table of your clients look like? arp -a on a windows box, ip arp on a Linux box. No idea on a Mac sorry, Google is your friend.
Can a client on the Infrastructure LAN ping Infrastructure’s default GW (192.168.10.1)
Can a client on the Infrastructure LAN ping Robot 1’s default GW (192.168.20.1)
I mean the easy fix here is to temporarily just put in an allow/allow rule. Does ping/routing work then? You know you’ve got a FW rule to fix. If it doesn’t you have to figure you’ve got a Layer 2 issue somewhere.
administrator@mech2452:~$ show arp
Address HWtype HWaddress Flags Mask Iface
192.168.10.3 ether e4:38:83:db:b1:2f C eth1.10
192.168.10.254 ether f0:de:f1:4c:33:0d C eth1.10
192.168.10.2 ether f4:92:bf:84:17:23 C eth1.10
192.168.20.3 ether d8:3a:dd:51:d3:30 C eth1.22
192.168.20.4 ether d8:3a:dd:51:d2:07 C eth1.22
192.168.30.254 ether f0:de:f1:4c:33:0d C eth1.30
132.181.61.254 ether c8:fe:6a:a9:de:00 C eth2
So the MAC addresses of the clients on VLAN20 are indeed listed. With regards to your ping queries, did you mean clients on administration VLAN20 pinging default GWs? In either case (infrastructure or administration) all pings are successful.
With regards to the ARP table of a random VLAN20 Raspberri Pi client:
$ arp -a
? (192.168.20.1) at d8:b3:70:3c:be:45 [ether] on eth0
Which looks fine to me as well. I will try your suggestion of a default-action allow rule in the administration-robot-1 ruleset first thing tomorrow.
Ok that’s great then I agree, all L2 stuff is fine - this sounds like it’s going to be just a firewall rule stopping things from working. I will have a look at the config you’ve pasted when I’ve got a bit more time, but yes, a temporary “any/any” rule will help you prove this quickly.
Things are beginning to get interesting. After some experimentation, it appears that the issue is the default-action drop statement in the robot-1 firewall zone definition, ie:
zone-policy {
zone robot-1 {
default-action drop
/* [9] */
from administration {
firewall {
interface eth1.20
If this is changed to default-action accept then I can SSH into a client on VLAN20 without issue. I am somewhat baffled as to why this default action statement over-rides those of firewall ruleset 9 (administration-robot-1) in which SSH traffic is explicitly permitted by rule 800:
firewall {
/* [9] */
default-action drop
enable-default-log
rule 1 {
action accept
state {
established enable
related enable
rule 2 {
action drop
log enable
state {
invalid enable
rule 100 {
action accept
protocol icmp
rule 200 {
action accept
destination {
group {
protocol tcp
rule 800 {
action accept
destination {
port 22
protocol tcp
I will continue to investigate and see what I can find out.
This is clearly an amateur mistake as I have A-B and B-A rule sets and zone policies defined for everything else. Thanks for your help though Tim - it made me think about things slowly and carefully.
