Routing - Design
Hi All,
Seeking assistance for below design. Just for Home-Lab.
Will Static Routes and NATing on the Router connected to ISP Router do ? or do I need something else to allow internal VIF 10 Network to get Internet connection as well as allow connectivity between Site A and Site B subnets ? Please help
Yes you can make this work only using static routes and NAT… Just make sure you use different networks/subnets for Site A and B. But using OSPF between the three routers would be easier.
Cheers
Thanks a lot. I was thinking the OSPF route too yesterday, while posting this. Will go the OSPF way.
