I am pretty new to the VyOS operating system, recently somehow managed to replace my home network router with small dell pc.
I have configured everything and OpenVPN and Static Route work perfectly inside the VyOS host, but it doesn’t work in the LAN maybe someone could look over it?
Here is my configuration commands:
set firewall ipv6-receive-redirects 'enable'
set firewall name NET-IN default-action 'drop'
set firewall name NET-IN rule 10 action 'accept'
set firewall name NET-IN rule 10 state established 'enable'
set firewall name NET-IN rule 10 state related 'enable'
set firewall name NET-LOCAL default-action 'drop'
set firewall name NET-LOCAL rule 10 action 'accept'
set firewall name NET-LOCAL rule 10 state established 'enable'
set firewall name NET-LOCAL rule 10 state related 'enable'
set firewall name NET-LOCAL rule 20 action 'accept'
set firewall name NET-LOCAL rule 20 icmp type-name 'echo-request'
set firewall name NET-LOCAL rule 20 protocol 'icmp'
set firewall name NET-LOCAL rule 20 state new 'enable'
set firewall options interface pppoe0 adjust-mss '1414'
set firewall options interface pppoe0 adjust-mss6 '1414'
set interfaces bridge br0 address 'xxx.xxx.0.1/24'
set interfaces bridge br0 ipv6 address autoconf
set interfaces bridge br0 ipv6 disable-forwarding
set interfaces bridge br0 ipv6 dup-addr-detect-transmits '1'
set interfaces bridge br0 member interface eth0
set interfaces bridge br0 member interface eth1
set interfaces bridge br0 member interface eth2
set interfaces ethernet eth0 description 'INSIDE 1G'
set interfaces ethernet eth0 hw-id 'XX:XX:XX:XX:XX:58'
set interfaces ethernet eth1 description 'INSIDE 10G'
set interfaces ethernet eth1 hw-id 'XX:XX:XX:XX:XX:c2'
set interfaces ethernet eth2 description 'OUTSIDE 10G'
set interfaces ethernet eth2 hw-id 'XX:XX:XX:XX:XX:c3'
set interfaces loopback lo
set interfaces openvpn vtun0 description 'Vutlr'
set interfaces openvpn vtun0 device-type 'tun'
set interfaces openvpn vtun0 encryption cipher 'aes256'
set interfaces openvpn vtun0 hash 'sha512'
set interfaces openvpn vtun0 mode 'client'
set interfaces openvpn vtun0 openvpn-option 'route-nopull'
set interfaces openvpn vtun0 persistent-tunnel
set interfaces openvpn vtun0 protocol 'udp'
set interfaces openvpn vtun0 remote-host 'xxxx:xxxx:7001:1c'
set interfaces openvpn vtun0 remote-port '1993'
set interfaces openvpn vtun0 tls ca-cert-file xxxxxx
set interfaces openvpn vtun0 tls cert-file xxxxxx
set interfaces openvpn vtun0 tls crypt-file '/config/auth/openvpn/vultr/tls-crypt.key'
set interfaces openvpn vtun0 tls key-file xxxxxx
set interfaces pppoe pppoe0 authentication password xxxxxx
set interfaces pppoe pppoe0 authentication user xxxxxx
set interfaces pppoe pppoe0 default-route 'auto'
set interfaces pppoe pppoe0 firewall in name 'NET-IN'
set interfaces pppoe pppoe0 firewall local name 'NET-LOCAL'
set interfaces pppoe pppoe0 mtu '1454'
set interfaces pppoe pppoe0 source-interface 'br0'
set nat source rule 100 outbound-interface 'pppoe0'
set nat source rule 100 source address 'xxx.xxx.0.0/24'
set protocols static interface-route xxx.xxx.161.186/32 next-hop-interface vtun0 distance '1'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 default-router 'xxx.xxx.0.1'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 dns-server 'xxx.xxx.0.1'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 domain-name xxxxxx
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 lease '86400'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 range 0 start 'xxx.xxx.0.50'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 range 0 stop 'xxx.xxx.0.254'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx ip-address 'xxx.xxx.0.2'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx mac-address 'XX:XX:XX:XX:XX:18'
set service dns forwarding allow-from 'xxx.xxx.0.0/24'
set service dns forwarding cache-size '0'
set service dns forwarding listen-address 'xxx.xxx.0.1'
set service dns forwarding name-server 'xxx.xxx.1.1'
set service dns forwarding name-server 'xxx.xxx.8.8'
set service ssh port '22'
set system host-name xxxxxx
set system ntp server xxxxx.tld
set system time-zone 'Asia/Tokyo'
