I’ve taken a look at the post boot script you mentioned, but I still cannot load my configuration after boot for XDP.
Here’s what I’m doing :
vyos@whyWontYouWork:~$ cat /config/scripts/vyos-postconfig-bootup.script
#!/bin/vbash
# This script is executed at boot time after VyOS configuration is fully applied.
# Any modifications required to work around unfixed bugs
# or use services not available through the VyOS CLI system can be placed here.
loadkeys fr
sudo perl /config/scripts/irq-affinity.pl eth0 auto
sudo perl /config/scripts/irq-affinity.pl eth1 auto
sudo perl /config/scripts/irq-affinity.pl eth2 auto
sudo ethtool -L eth0 combined 4
sudo ethtool -L eth1 combined 4
sudo ethtool -G eth0 rx 2047
sudo ethtool -G eth0 tx 2047
sudo ethtool -G eth1 rx 2047
sudo ethtool -G eth1 tx 2047
echo "STAND BY FOR EXPLOSIONS, APPLYING XDP"
configure
set interfaces ethernet eth0 xdp
set interfaces ethernet eth1 xdp
commit
exit
This causes the error 40 mentioned in T3939 :
Jul 29 10:49:24 systemd[1]: systemd-hostnamed.service: Succeeded.
Jul 29 10:49:29 vyos-router[1908]: STAND BY FOR EXPLOSIONS, APPLYING XDP
Jul 29 10:49:29 sudo[2031]: root : PWD=/ ; USER=root ; COMMAND=/usr/bin/sh -c /usr/sbin/vyshim VYOS_TAGNODE_VALUE='eth0' /usr/libexec/vyos/conf_mode/interfaces-ethernet.py
Jul 29 10:49:29 sudo[2031]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Jul 29 10:49:29 vyos-configd[712]: Received message: {"type": "init"}
Jul 29 10:49:29 vyos-configd[712]: config session pid is 1908
Jul 29 10:49:29 vyos-configd[712]: Received message: {"type": "node", "data": "VYOS_TAGNODE_VALUE=eth0/usr/libexec/vyos/conf_mode/interfaces-ethernet.py"}
Jul 29 10:49:29 vyos-configd[712]: [Errno 40] failed to run command: xdp_loader -d eth0 --auto-mode -F --progsec xdp_router --filename /usr/share/vyos/xdp/xdp_prog_kern.o && xdp_prog_user -d eth0
Jul 29 10:49:29 vyos-configd[712]: returned:
Jul 29 10:49:29 vyos-configd[712]: exit code: 40
Jul 29 10:49:29 vyos-configd[712]: Sending response 4
Jul 29 10:49:29 systemd[1]: [email protected]: Succeeded.
Jul 29 10:49:29 systemd[1]: [email protected]: Scheduled restart job, restart counter is at 3.
Jul 29 10:49:29 systemd[1]: Stopped Serial Getty on ttyS0.
Jul 29 10:49:29 systemd[1]: Started Serial Getty on ttyS0.
Jul 29 10:49:29 agetty[2084]: /dev/ttyS0: not a tty
Jul 29 10:49:29 python3[2063]: Report time: 2022-07-29 10:49:29
Jul 29 10:49:29 python3[2063]: Image version: VyOS 1.4-rolling-202207270217
Jul 29 10:49:29 python3[2063]: Release train: sagitta
Jul 29 10:49:29 python3[2063]: Built by: [email protected]
Jul 29 10:49:29 python3[2063]: Built on: Wed 27 Jul 2022 02:17 UTC
Jul 29 10:49:29 python3[2063]: Build UUID: db3bf91b-152e-4cae-9faf-f7176be287d4
Jul 29 10:49:29 python3[2063]: Build commit ID: 3327957356be99
Jul 29 10:49:29 Architecture[2063]: x86_64
Jul 29 10:49:29 python3[2063]: Boot via: installed image
Jul 29 10:49:29 python3[2063]: System type: KVM guest
Jul 29 10:49:29 python3[2063]: Hardware vendor: QEMU
Jul 29 10:49:29 python3[2063]: Hardware model: Standard PC (Q35 + ICH9, 2009)
Jul 29 10:49:29 python3[2063]: Hardware S/N:
Jul 29 10:49:29 python3[2063]: Hardware UUID: 88f32e10-cde2-4e63-bb89-f80e2d396e05
Jul 29 10:49:29 python3[2063]: Traceback (most recent call last):
Jul 29 10:49:29 python3[2063]: File "/usr/libexec/vyos/conf_mode/interfaces-ethernet.py", line 215, in <module>
Jul 29 10:49:29 python3[2063]: apply(c)
Jul 29 10:49:29 python3[2063]: File "/usr/libexec/vyos/conf_mode/interfaces-ethernet.py", line 204, in apply
Jul 29 10:49:29 python3[2063]: e.update(ethernet)
Jul 29 10:49:29 python3[2063]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/ethernet.py", line 363, in update
Jul 29 10:49:29 python3[2063]: super().update(config)
Jul 29 10:49:29 python3[2063]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/interface.py", line 1590, in update
Jul 29 10:49:29 python3[2063]: self.set_xdp('xdp' in config)
Jul 29 10:49:29 python3[2063]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/interface.py", line 1382, in set_xdp
Jul 29 10:49:29 python3[2063]: return self._cmd(cmd)
Jul 29 10:49:29 python3[2063]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/control.py", line 52, in _cmd
Jul 29 10:49:29 python3[2063]: return cmd(command, self.debug)
Jul 29 10:49:29 python3[2063]: File "/usr/lib/python3/dist-packages/vyos/util.py", line 161, in cmd
Jul 29 10:49:29 python3[2063]: raise OSError(code, feedback)
Jul 29 10:49:29 OSError[2063]: [Errno 40] failed to run command: xdp_loader -d eth0 --auto-mode -F --progsec xdp_router --filename /usr/share/vyos/xdp/xdp_prog_kern.o && xdp_prog_user -d eth0
Jul 29 10:49:29 returned[2063]:
Jul 29 10:49:29 python3[2063]: exit code: 40
Jul 29 10:49:29 noteworthy[2063]:
Jul 29 10:49:29 python3[2063]: cmd 'nft -c delete element inet vrf_zones ct_iface_map { "eth0" }'
Jul 29 10:49:29 python3[2063]: returned (out):
Jul 29 10:49:29 python3[2063]: returned (err):
Jul 29 10:49:29 Error[2063]: No such file or directory
Jul 29 10:49:29 python3[2063]: delete element inet vrf_zones ct_iface_map { eth0 }
Jul 29 10:49:29 python3[2063]: ^^^^^^^^^
Jul 29 10:49:29 python3[2063]: cmd 'xdp_loader -d eth0 --auto-mode -F --progsec xdp_router --filename /usr/share/vyos/xdp/xdp_prog_kern.o && xdp_prog_user -d eth0'
Jul 29 10:49:29 libbpf[2063]: failed to create map (name: 'redirect_params'): Operation not permitted(-1)
Jul 29 10:49:29 libbpf[2063]: failed to load object '/usr/share/vyos/xdp/xdp_prog_kern.o'
Jul 29 10:49:29 ERR[2063]: loading BPF-OBJ file(/usr/share/vyos/xdp/xdp_prog_kern.o) (-22): Invalid argument
Jul 29 10:49:29 ERR[2063]: loading file: /usr/share/vyos/xdp/xdp_prog_kern.o
Jul 29 10:49:29 vyos-router[2027]: [ interfaces ethernet eth0 ]
Jul 29 10:49:29 vyos-router[2027]: VyOS had an issue completing a command.
Jul 29 10:49:29 vyos-router[2027]: We are sorry that you encountered a problem while using VyOS.
Jul 29 10:49:29 vyos-router[2027]: There are a few things you can do to help us (and yourself):
Jul 29 10:49:29 vyos-router[2027]: - Contact us using the online help desk if you have a subscription:
Jul 29 10:49:29 vyos-router[2027]: https://support.vyos.io/
Jul 29 10:49:29 vyos-router[2027]: - Make sure you are running the latest version of VyOS available at:
Jul 29 10:49:29 vyos-router[2027]: https://vyos.net/get/
Jul 29 10:49:29 vyos-router[2027]: - Consult the community forum to see how to handle this issue:
Jul 29 10:49:29 vyos-router[2027]: https://forum.vyos.io
Jul 29 10:49:29 vyos-router[2027]: - Join us on Slack where our users exchange help and advice:
Jul 29 10:49:29 vyos-router[2027]: https://vyos.slack.com
Jul 29 10:49:29 vyos-router[2027]: When reporting problems, please include as much information as possible:
Jul 29 10:49:29 vyos-router[2027]: - do not obfuscate any data (feel free to contact us privately if your
Jul 29 10:49:29 vyos-router[2027]: business policy requires it)
Jul 29 10:49:29 vyos-router[2027]: - and include all the information presented below
Jul 29 10:49:29 vyos-router[2027]: Report time: 2022-07-29 10:49:29
Jul 29 10:49:29 vyos-router[2027]: Image version: VyOS 1.4-rolling-202207270217
Jul 29 10:49:29 vyos-router[2027]: Release train: sagitta
Jul 29 10:49:29 vyos-router[2027]: Built by: [email protected]
Jul 29 10:49:29 vyos-router[2027]: Built on: Wed 27 Jul 2022 02:17 UTC
Jul 29 10:49:29 vyos-router[2027]: Build UUID: db3bf91b-152e-4cae-9faf-f7176be287d4
Jul 29 10:49:29 vyos-router[2027]: Build commit ID: 3327957356be99
Jul 29 10:49:29 vyos-router[2027]: Architecture: x86_64
Jul 29 10:49:29 vyos-router[2027]: Boot via: installed image
Jul 29 10:49:29 vyos-router[2027]: System type: KVM guest
Jul 29 10:49:29 vyos-router[2027]: Hardware vendor: QEMU
Jul 29 10:49:29 vyos-router[2027]: Hardware model: Standard PC (Q35 + ICH9, 2009)
Jul 29 10:49:29 vyos-router[2027]: Hardware S/N:
Jul 29 10:49:29 vyos-router[2027]: Hardware UUID: 88f32e10-cde2-4e63-bb89-f80e2d396e05
Jul 29 10:49:29 vyos-router[2027]: Traceback (most recent call last):
Jul 29 10:49:29 vyos-router[2027]: File "/usr/libexec/vyos/conf_mode/interfaces-ethernet.py", line 215, in <module>
Jul 29 10:49:29 vyos-router[2027]: apply(c)
Jul 29 10:49:29 vyos-router[2027]: File "/usr/libexec/vyos/conf_mode/interfaces-ethernet.py", line 204, in apply
Jul 29 10:49:29 vyos-router[2027]: e.update(ethernet)
Jul 29 10:49:29 vyos-router[2027]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/ethernet.py", line 363, in update
Jul 29 10:49:29 vyos-router[2027]: super().update(config)
Jul 29 10:49:29 vyos-router[2027]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/interface.py", line 1590, in update
Jul 29 10:49:29 vyos-router[2027]: self.set_xdp('xdp' in config)
Jul 29 10:49:29 vyos-router[2027]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/interface.py", line 1382, in set_xdp
Jul 29 10:49:29 vyos-router[2027]: return self._cmd(cmd)
Jul 29 10:49:29 vyos-router[2027]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/control.py", line 52, in _cmd
Jul 29 10:49:29 vyos-router[2027]: return cmd(command, self.debug)
Jul 29 10:49:29 vyos-router[2027]: File "/usr/lib/python3/dist-packages/vyos/util.py", line 161, in cmd
Jul 29 10:49:29 vyos-router[2027]: raise OSError(code, feedback)
Jul 29 10:49:29 vyos-router[2027]: OSError: [Errno 40] failed to run command: xdp_loader -d eth0 --auto-mode -F --progsec xdp_router --filename /usr/share/vyos/xdp/xdp_prog_kern.o && xdp_prog_user -d eth0
Jul 29 10:49:29 vyos-router[2027]: returned:
Jul 29 10:49:29 vyos-router[2027]: exit code: 40
Jul 29 10:49:29 vyos-router[2027]: noteworthy:
Jul 29 10:49:29 vyos-router[2027]: cmd 'nft -c delete element inet vrf_zones ct_iface_map { "eth0" }'
Jul 29 10:49:29 vyos-router[2027]: returned (out):
Jul 29 10:49:29 vyos-router[2027]: returned (err):
Jul 29 10:49:29 vyos-router[2027]: Error: No such file or directory
Jul 29 10:49:29 vyos-router[2027]: delete element inet vrf_zones ct_iface_map { eth0 }
Jul 29 10:49:29 vyos-router[2027]: ^^^^^^^^^
Jul 29 10:49:29 vyos-router[2027]: cmd 'xdp_loader -d eth0 --auto-mode -F --progsec xdp_router --filename /usr/share/vyos/xdp/xdp_prog_kern.o && xdp_prog_user -d eth0'
Jul 29 10:49:29 vyos-router[2027]: libbpf: failed to create map (name: 'redirect_params'): Operation not permitted(-1)
Jul 29 10:49:29 vyos-router[2027]: libbpf: failed to load object '/usr/share/vyos/xdp/xdp_prog_kern.o'
Jul 29 10:49:29 vyos-router[2027]: ERR: loading BPF-OBJ file(/usr/share/vyos/xdp/xdp_prog_kern.o) (-22): Invalid argument
Jul 29 10:49:29 vyos-router[2027]: ERR: loading file: /usr/share/vyos/xdp/xdp_prog_kern.o
Jul 29 10:49:29 sudo[2031]: pam_unix(sudo:session): session closed for user root
Jul 29 10:49:29 sudo[2102]: root : PWD=/ ; USER=root ; COMMAND=/usr/bin/sh -c /usr/sbin/vyshim VYOS_TAGNODE_VALUE='eth1' /usr/libexec/vyos/conf_mode/interfaces-ethernet.py
Jul 29 10:49:29 sudo[2102]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Jul 29 10:49:29 vyos-configd[712]: Received message: {"type": "node", "data": "VYOS_TAGNODE_VALUE=eth1/usr/libexec/vyos/conf_mode/interfaces-ethernet.py"}
Jul 29 10:49:29 vyos-configd[712]: [Errno 40] failed to run command: xdp_loader -d eth1 --auto-mode -F --progsec xdp_router --filename /usr/share/vyos/xdp/xdp_prog_kern.o && xdp_prog_user -d eth1
Jul 29 10:49:30 python3[2131]: Report time: 2022-07-29 10:49:30
Jul 29 10:49:30 python3[2131]: Image version: VyOS 1.4-rolling-202207270217
Jul 29 10:49:30 python3[2131]: Release train: sagitta
Jul 29 10:49:30 python3[2131]: Built by: [email protected]
Jul 29 10:49:30 python3[2131]: Built on: Wed 27 Jul 2022 02:17 UTC
Jul 29 10:49:30 python3[2131]: Build UUID: db3bf91b-152e-4cae-9faf-f7176be287d4
Jul 29 10:49:30 python3[2131]: Build commit ID: 3327957356be99
Jul 29 10:49:30 Architecture[2131]: x86_64
Jul 29 10:49:30 python3[2131]: Boot via: installed image
Jul 29 10:49:30 python3[2131]: System type: KVM guest
Jul 29 10:49:30 python3[2131]: Hardware vendor: QEMU
Jul 29 10:49:30 python3[2131]: Hardware model: Standard PC (Q35 + ICH9, 2009)
Jul 29 10:49:30 python3[2131]: Hardware S/N:
Jul 29 10:49:30 python3[2131]: Hardware UUID: 88f32e10-cde2-4e63-bb89-f80e2d396e05
Jul 29 10:49:30 python3[2131]: Traceback (most recent call last):
Jul 29 10:49:30 python3[2131]: File "/usr/libexec/vyos/conf_mode/interfaces-ethernet.py", line 215, in <module>
Jul 29 10:49:30 python3[2131]: apply(c)
Jul 29 10:49:30 python3[2131]: File "/usr/libexec/vyos/conf_mode/interfaces-ethernet.py", line 204, in apply
Jul 29 10:49:30 python3[2131]: e.update(ethernet)
Jul 29 10:49:30 python3[2131]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/ethernet.py", line 363, in update
Jul 29 10:49:30 python3[2131]: super().update(config)
Jul 29 10:49:30 python3[2131]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/interface.py", line 1590, in update
Jul 29 10:49:30 python3[2131]: self.set_xdp('xdp' in config)
Jul 29 10:49:30 python3[2131]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/interface.py", line 1382, in set_xdp
Jul 29 10:49:30 python3[2131]: return self._cmd(cmd)
Jul 29 10:49:30 python3[2131]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/control.py", line 52, in _cmd
Jul 29 10:49:30 python3[2131]: return cmd(command, self.debug)
Jul 29 10:49:30 python3[2131]: File "/usr/lib/python3/dist-packages/vyos/util.py", line 161, in cmd
Jul 29 10:49:30 python3[2131]: raise OSError(code, feedback)
Jul 29 10:49:30 OSError[2131]: [Errno 40] failed to run command: xdp_loader -d eth1 --auto-mode -F --progsec xdp_router --filename /usr/share/vyos/xdp/xdp_prog_kern.o && xdp_prog_user -d eth1
Jul 29 10:49:30 returned[2131]:
Jul 29 10:49:30 python3[2131]: exit code: 40
Jul 29 10:49:30 noteworthy[2131]:
Jul 29 10:49:30 python3[2131]: cmd 'nft -c delete element inet vrf_zones ct_iface_map { "eth1" }'
Jul 29 10:49:30 python3[2131]: returned (out):
Jul 29 10:49:30 python3[2131]: returned (err):
Jul 29 10:49:30 Error[2131]: No such file or directory
Jul 29 10:49:30 python3[2131]: delete element inet vrf_zones ct_iface_map { eth1 }
Jul 29 10:49:30 python3[2131]: ^^^^^^^^^
Jul 29 10:49:30 python3[2131]: cmd 'xdp_loader -d eth1 --auto-mode -F --progsec xdp_router --filename /usr/share/vyos/xdp/xdp_prog_kern.o && xdp_prog_user -d eth1'
Jul 29 10:49:30 libbpf[2131]: failed to create map (name: 'redirect_params'): Operation not permitted(-1)
Jul 29 10:49:30 libbpf[2131]: failed to load object '/usr/share/vyos/xdp/xdp_prog_kern.o'
Jul 29 10:49:30 ERR[2131]: loading BPF-OBJ file(/usr/share/vyos/xdp/xdp_prog_kern.o) (-22): Invalid argument
Jul 29 10:49:30 ERR[2131]: loading file: /usr/share/vyos/xdp/xdp_prog_kern.o
Jul 29 10:49:30 vyos-router[2027]: [[interfaces ethernet eth0]] failed
Jul 29 10:49:30 vyos-router[2027]: [ interfaces ethernet eth1 ]
Jul 29 10:49:30 vyos-router[2027]: VyOS had an issue completing a command.
Jul 29 10:49:30 vyos-router[2027]: We are sorry that you encountered a problem while using VyOS.
Jul 29 10:49:30 vyos-router[2027]: There are a few things you can do to help us (and yourself):
Jul 29 10:49:30 vyos-router[2027]: - Contact us using the online help desk if you have a subscription:
Jul 29 10:49:30 vyos-router[2027]: https://support.vyos.io/
Jul 29 10:49:30 vyos-router[2027]: - Make sure you are running the latest version of VyOS available at:
Jul 29 10:49:30 vyos-router[2027]: https://vyos.net/get/
Jul 29 10:49:30 vyos-router[2027]: - Consult the community forum to see how to handle this issue:
Jul 29 10:49:30 vyos-router[2027]: https://forum.vyos.io
Jul 29 10:49:30 vyos-router[2027]: - Join us on Slack where our users exchange help and advice:
Jul 29 10:49:30 vyos-router[2027]: https://vyos.slack.com
Jul 29 10:49:30 vyos-router[2027]: When reporting problems, please include as much information as possible:
Jul 29 10:49:30 vyos-router[2027]: - do not obfuscate any data (feel free to contact us privately if your
Jul 29 10:49:30 vyos-router[2027]: business policy requires it)
Jul 29 10:49:30 vyos-router[2027]: - and include all the information presented below
Jul 29 10:49:30 vyos-router[2027]: Report time: 2022-07-29 10:49:30
Jul 29 10:49:30 vyos-router[2027]: Image version: VyOS 1.4-rolling-202207270217
Jul 29 10:49:30 vyos-router[2027]: Release train: sagitta
Jul 29 10:49:30 vyos-router[2027]: Built by: [email protected]
Jul 29 10:49:30 vyos-router[2027]: Built on: Wed 27 Jul 2022 02:17 UTC
Jul 29 10:49:30 vyos-router[2027]: Build UUID: db3bf91b-152e-4cae-9faf-f7176be287d4
Jul 29 10:49:30 vyos-router[2027]: Build commit ID: 3327957356be99
Jul 29 10:49:30 vyos-router[2027]: Architecture: x86_64
Jul 29 10:49:30 vyos-router[2027]: Boot via: installed image
Jul 29 10:49:30 vyos-router[2027]: System type: KVM guest
Jul 29 10:49:30 vyos-router[2027]: Hardware vendor: QEMU
Jul 29 10:49:30 vyos-router[2027]: Hardware model: Standard PC (Q35 + ICH9, 2009)
Jul 29 10:49:30 vyos-router[2027]: Hardware S/N:
Jul 29 10:49:30 vyos-router[2027]: Hardware UUID: 88f32e10-cde2-4e63-bb89-f80e2d396e05
Jul 29 10:49:30 vyos-router[2027]: Traceback (most recent call last):
Jul 29 10:49:30 vyos-router[2027]: File "/usr/libexec/vyos/conf_mode/interfaces-ethernet.py", line 215, in <module>
Jul 29 10:49:30 vyos-router[2027]: apply(c)
Jul 29 10:49:30 vyos-router[2027]: File "/usr/libexec/vyos/conf_mode/interfaces-ethernet.py", line 204, in apply
Jul 29 10:49:30 vyos-router[2027]: e.update(ethernet)
Jul 29 10:49:30 vyos-router[2027]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/ethernet.py", line 363, in update
Jul 29 10:49:30 vyos-router[2027]: super().update(config)
Jul 29 10:49:30 vyos-router[2027]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/interface.py", line 1590, in update
Jul 29 10:49:30 vyos-router[2027]: self.set_xdp('xdp' in config)
Jul 29 10:49:30 vyos-router[2027]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/interface.py", line 1382, in set_xdp
Jul 29 10:49:30 vyos-router[2027]: return self._cmd(cmd)
Jul 29 10:49:30 vyos-router[2027]: File "/usr/lib/python3/dist-packages/vyos/ifconfig/control.py", line 52, in _cmd
Jul 29 10:49:30 vyos-router[2027]: return cmd(command, self.debug)
Jul 29 10:49:30 vyos-router[2027]: File "/usr/lib/python3/dist-packages/vyos/util.py", line 161, in cmd
Jul 29 10:49:30 vyos-router[2027]: raise OSError(code, feedback)
Jul 29 10:49:30 vyos-router[2027]: OSError: [Errno 40] failed to run command: xdp_loader -d eth1 --auto-mode -F --progsec xdp_router --filename /usr/share/vyos/xdp/xdp_prog_kern.o && xdp_prog_user -d eth1
Jul 29 10:49:30 vyos-router[2027]: returned:
Jul 29 10:49:30 vyos-router[2027]: exit code: 40
Jul 29 10:49:30 vyos-router[2027]: noteworthy:
Jul 29 10:49:30 vyos-router[2027]: cmd 'nft -c delete element inet vrf_zones ct_iface_map { "eth1" }'
Jul 29 10:49:30 vyos-router[2027]: returned (out):
Jul 29 10:49:30 vyos-router[2027]: returned (err):
Jul 29 10:49:30 vyos-router[2027]: Error: No such file or directory
Jul 29 10:49:30 vyos-router[2027]: delete element inet vrf_zones ct_iface_map { eth1 }
Jul 29 10:49:30 vyos-router[2027]: ^^^^^^^^^
Jul 29 10:49:30 vyos-router[2027]: cmd 'xdp_loader -d eth1 --auto-mode -F --progsec xdp_router --filename /usr/share/vyos/xdp/xdp_prog_kern.o && xdp_prog_user -d eth1'
Jul 29 10:49:30 vyos-router[2027]: libbpf: failed to create map (name: 'redirect_params'): Operation not permitted(-1)
Jul 29 10:49:30 vyos-router[2027]: libbpf: failed to load object '/usr/share/vyos/xdp/xdp_prog_kern.o'
Jul 29 10:49:30 vyos-router[2027]: ERR: loading BPF-OBJ file(/usr/share/vyos/xdp/xdp_prog_kern.o) (-22): Invalid argument
Jul 29 10:49:30 vyos-router[2027]: ERR: loading file: /usr/share/vyos/xdp/xdp_prog_kern.o
Jul 29 10:49:30 sudo[2102]: pam_unix(sudo:session): session closed for user root
Jul 29 10:49:30 systemd[1]: opt-vyatta-config-tmp-new_config_1908.mount: Succeeded.
Jul 29 10:49:30 vyos-router[2027]: [[interfaces ethernet eth1]] failed
Jul 29 10:49:30 vyos-router[2027]: Commit failed
Jul 29 10:49:39 systemd[1]: [email protected]: Succeeded.
Jul 29 10:49:39 systemd[1]: [email protected]: Scheduled restart job, restart counter is at 4.
Jul 29 10:49:39 systemd[1]: Stopped Serial Getty on ttyS0.
Jul 29 10:49:39 systemd[1]: Started Serial Getty on ttyS0.
Jul 29 10:49:39 agetty[2197]: /dev/ttyS0: not a tty
Jul 29 10:49:49 systemd[1]: [email protected]: Succeeded.
Jul 29 10:49:50 systemd[1]: [email protected]: Scheduled restart job, restart counter is at 5.
Jul 29 10:49:50 systemd[1]: Stopped Serial Getty on ttyS0.
Jul 29 10:49:50 systemd[1]: Started Serial Getty on ttyS0.
Jul 29 10:49:50 agetty[2201]: /dev/ttyS0: not a tty
Jul 29 10:50:00 systemd[1]: [email protected]: Succeeded.
Jul 29 10:50:00 systemd[1]: [email protected]: Scheduled restart job, restart counter is at 6.
Jul 29 10:50:00 systemd[1]: Stopped Serial Getty on ttyS0.
Jul 29 10:50:00 systemd[1]: Started Serial Getty on ttyS0.
Jul 29 10:50:00 agetty[2206]: /dev/ttyS0: not a tty
Jul 29 10:50:00 sshd[2202]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=5giss-chr-1 user=vyos
Jul 29 10:50:02 sshd[2202]: Failed password for vyos from 10.178.128.1 port 46364 ssh2
Jul 29 10:50:05 sshd[2202]: Accepted password for vyos from 10.178.128.1 port 46364 ssh2
Jul 29 10:50:05 sshd[2202]: pam_unix(sshd:session): session opened for user vyos(uid=1002) by (uid=0)
Jul 29 10:50:05 systemd[1]: Created slice User Slice of UID 1002.
Jul 29 10:50:05 systemd[1]: Starting User Runtime Directory /run/user/1002...
Jul 29 10:50:05 systemd-logind[868]: New session 1 of user vyos.
Jul 29 10:50:05 systemd[1]: Finished User Runtime Directory /run/user/1002.
Jul 29 10:50:05 systemd[1]: Starting User Manager for UID 1002...
Jul 29 10:50:05 systemd[2208]: pam_unix(systemd-user:session): session opened for user vyos(uid=1002) by (uid=0)
Jul 29 10:50:05 systemd[2208]: Queued start job for default target Main User Target.
Jul 29 10:50:05 systemd[2208]: Created slice User Application Slice.
Jul 29 10:50:05 systemd[2208]: Reached target Paths.
Jul 29 10:50:05 systemd[2208]: Reached target Timers.
Jul 29 10:50:05 systemd[2208]: Listening on GnuPG network certificate management daemon.
Jul 29 10:50:05 systemd[2208]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jul 29 10:50:05 systemd[2208]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Jul 29 10:50:05 systemd[2208]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Jul 29 10:50:05 systemd[2208]: Listening on GnuPG cryptographic agent and passphrase cache.
Jul 29 10:50:05 systemd[2208]: Listening on Podman API Socket.
Jul 29 10:50:05 systemd[2208]: Reached target Sockets.
Jul 29 10:50:05 systemd[2208]: Reached target Basic System.
Jul 29 10:50:05 systemd[2208]: Reached target Main User Target.
Jul 29 10:50:05 systemd[2208]: Startup finished in 204ms.
Jul 29 10:50:05 systemd[1]: Started User Manager for UID 1002.
Jul 29 10:50:05 systemd[1]: Started Session 1 of user vyos.
Jul 29 10:50:05 systemd[2208]: opt-vyatta-config-tmp-new_config_2224.mount: Succeeded.
Jul 29 10:50:05 systemd[1]: opt-vyatta-config-tmp-new_config_2224.mount: Succeeded.
What I don’t understand is that running the commands myself, or the script, will work.
As far as I’m aware, this seems to be a permission problem :
Seems the environment variables aren’t the same when in shell & when the post boot script runs :
1,2c1,3
< VYATTA_ACTIVE_CONFIGURATION_DIR=/opt/vyatta/config/active
< VYATTA_CONFIG_TMP=/opt/vyatta/config/tmp/tmp_1910
> CAML_LD_LIBRARY_PATH=/opt/opam/4.07.0/lib/stublibs:/opt/opam/4.07.0/lib/ocaml/stublibs:/opt/opam/4.07.0/lib/ocaml
> MANPATH=:/opt/opam/4.07.0/man
> XDG_SESSION_ID=1
4,5c5
< TERM=linux
7a8,9
> TERM=xterm-256color
> SHELL=/bin/vbash
9,11c11,12
< VYATTA_COMP_LINE_EMPTY=VYATTA_COMP_LINE_EMPTY
< vyatta_htmldir=/opt/vyatta/share/man
< VYATTA_TEMPLATE_LEVEL=/
> vyatta_htmldir=/opt/vyatta/share/html
> SSH_CLIENT=10.178.128.1 47464 22
12a14
> OPAM_SWITCH_PREFIX=/opt/opam/4.07.0
13a16,19
> SSH_TTY=/dev/pts/0
> OPAMROOT=/opt/opam
> XDG_SESSION_CLASS=user
> OCAML_TOPLEVEL_PATH=/opt/opam/4.07.0/lib/toplevel
15c21,22
< INVOCATION_ID=60bccfe27dac40668708e72716ef9b79
> USER=vyos
> LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:
18d24
< vyos_prefix=/opt/vyatta
19a26
21a29
> MOTD_SHOWN=pam
27,28c35,36
< PWD=/
< VYATTA_COMP_LINE=VYATTA_COMP_LINE_EMPTY
> PWD=/home/vyos
> XDG_SESSION_TYPE=tty
30,31d37
< VYATTA_CHANGES_ONLY_DIR=/opt/vyatta/config/tmp/changes_only_1910
< vyshim=/usr/sbin/vyshim
34d39
< PS1=[edit]\n\u@\H#
38,39d42
< BOOTFILE=/opt/vyatta/etc/config/config.boot
< HISTCONTROL=
40a44
> HISTCONTROL=
42c46,47
< SHLVL=2
> SHLVL=1
> HOME=/home/vyos
44d48
< vyatta_libdir=/opt/vyatta/lib
46,48c50,51
< VYATTA_CONFIG_TEMPLATE=/opt/vyatta/share/vyatta-cfg/templates
< VYATTA_EDIT_LEVEL=/
< vyatta_localstatedir=/opt/vyatta/var
> LOGNAME=vyos
49a53,55
> VYATTA_PAGER=less --buffers=64 --auto-buffers --no-lessopen --QUIT-AT-EOF --quit-if-one-screen --RAW-CONTROL-CHARS --squeeze-blank-lines --no-init
> SSH_CONNECTION=10.178.128.1 47464 10.178.128.52 22
52,53d57
< PROMPT_COMMAND=history -a
< JOURNAL_STREAM=7:1258
54a59
55a61
> XDG_RUNTIME_DIR=/run/user/1002
59d64
< VYATTA_TEMP_CONFIG_DIR=/opt/vyatta/config/tmp/new_config_1910
I think it may have to do with how the
is ran and with which context.
