I am using VMWare’s Invoke-VMScript command to invoke a command on the VyOS box.
$script =@'
run show configuration
Invoke-VMScript -vm $vm -ScriptText $script -GuestUser "vyos" -GuestPassword "vyos"
No matter what I try, I can not get the scripts to work succesfully.
As of now, I am getting: bash: run: command not found
Any information would be helpful.
Try it
/opt/vyatta/bin/vyatta-op-cmd-wrapper show interfaces
@Viacheslav
ScriptOutput
-----------------------------------------------------------------------------------------------------------------------| Codes: S - State, L - Link, u - Up, D - Down, A - Admin Down
| Interface IP Address S/L Description
| Traceback (most recent call last):
| File “/usr/libexec/vyos/op_mode/show_interfaces.py”, line 301, in
| args.vrrp
| File “/usr/libexec/vyos/op_mode/show_interfaces.py”, line 221, in run_show_intf_brief
| descs = list(split_text(interface.get_alias(),56))
| File “/usr/libexec/vyos/op_mode/show_interfaces.py”, line 90, in split_text
| returned = cmd(‘stty size’)
| File “/usr/lib/python3/dist-packages/vyos/util.py”, line 178, in cmd
| raise OSError(code, feedback)
| PermissionError: [Errno 1] failed to run command: stty size
| returned:
| exit code: 1
With this command:
/opt/vyatta/bin/vyatta-op-cmd-wrapper set service ssh port 22
-----------------------------------------------------------------------------------------------------------------------| Invalid command: set [service]
