Hi.
It would be great if Juniper’s “replace pattern” feature could be incorporated into VyOS. I don’t think this feature is copyrighted
replace pattern <pattern> with <new_value>
The pattern should support regular expressions.
The use cases are many but let’s say that you want to change naming convention on all firewall objects - either change object name from hyphen to underscore, or add a prefix to all objects.
You can run awk or whatever on the /config/config.boot file and then reboot or load that modified config to replace your current running one.
I would call that a workaround, but it works of course
I just love the “replace pattern” feature in Junos along with “commit confirm” without having to reboot when the configuration gets rolled back.
By the way, did you test rollback-soft
feature? Allows to rollback configs without rebooting
rollback-soft
works great
but the use-case is a bit different than commit-confirm
which is a great feature if you lock yourself out with a faulty commit.
You may already know this since it seems you’re more referring to more complex renaming, but just in case:
There is a rename feature that works similar to Juniper, but it can’t do regex:
vyos@vyos# show route-map | commands
set route-map TEST rule 10 action 'permit'
set route-map TEST rule 10 match ip address prefix-list 'TEST'
[edit policy]
vyos@vyos# rename route-map TEST to route-map NEW_NAME
[edit policy]
vyos@vyos# show | compare
[policy route-map]
- TEST {
- rule 10 {
- action "permit"
- match {
- ip {
- address {
- prefix-list "TEST"
+ NEW_NAME {
+ rule 10 {
+ action "permit"
+ match {
+ ip {
+ address {
+ prefix-list "TEST"
I’ve tried this method to rename and it works.
However if an element is referred several places in the config I cannot rename in one command like Junos «replace pattern» does.
Not a big issue but would be a nice feature to add to an already great system
