Set firewall zone wan interface
I’m on Vyos 1.5. I am building a zone-based firewall. Whenever I assign an interface to the zone, it errors-out.
vyos@vyos-router# set firewall zone wan interface eth0
Configuration path: firewall zone wan [interface] is not valid
Set failed
The interface exists:
eth0         192.168.3.9/24    20:7c:14:f8:35:8e  default   9000  u/u    WAN
The zone exists:
+zone WAN {
+    default-action drop
But I can’t set the interface. With or without quotes.
set firewall zone WAN member interface 'eth0'
You can use tab completion and ? to see possible completions.
-> set firewall zone WAN
Possible completions:
   default-action       Default-action for traffic coming into this zone (default: drop)
   default-log          Log packets hitting default-action
   description          Description
+> from                 Zone from which to filter traffic
 > intra-zone-filtering Intra-zone filtering
   local-zone           Zone to be local-zone
 > member               Interface associated with zone
-> set firewall zone WAN member interface
   <text>               Interface name, wildcard (*) supported
   eth0
   eth0.2
   eth0.3
   eth0.4
   eth0.5
   eth0.6
   eth1
   eth2
   eth3
   eth4
   eth5
   eth6
   eth7
   lo
   veth0
   veth1
   veth2
   veth3
   wwan0
Thank you! The “member” was missing. Was not in any examples …
