I’ve got two upstream connections:
- fiber connection that uses pppoe
- cellular modem and router, that is serving an internet connection to my vyos router from 172.16.5.1
I’m trying to setup default routes for both interfaces (also have wan-load-balancing setup, but I don’t think that’s related to the issue at hand):
set protocols static route 0.0.0.0/0 dhcp-interface pppoe0
set protocols static route 0.0.0.0/0 next-hop 172.16.5.1 distance 100
However, no route appears to be setup for the pppoe0
interface:
$ show interfaces
eth0 - u/u CenturyLink WAN (Managed by Ansible)
eth0.201 - u/u CenturyLink PPPOE (Managed by Ansible)
eth2 172.16.5.2/24 u/u Cellular WAN (Managed by Ansible)
pppoe0 10.100.1.101/32 u/u
$ show ip route
F - PBR, f - OpenFabric,
> - selected route, * - FIB route, q - queued route, r - rejected route
S>* 0.0.0.0/0 [100/0] via 172.16.5.1, eth2, 00:26:21
C>* 10.100.1.1/32 is directly connected, pppoe0, 00:26:00
$ netstat -rd
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
default 172.16.5.1 0.0.0.0 UG 0 0 0 eth2
10.100.1.1 0.0.0.0 255.255.255.255 UH 0 0 0 pppoe0
I would expect a default route to be created via 10.100.1.1
, much like the default route created via 172.16.5.1
, however it doesn’t get created. I’ve tested this in a vm with a more typical ethernet
interface, and the route does get created with a dhcp address.
I’ve removed irrelevant interfaces from the above output. I’m using this ansible playbook to configure it, so you can see all the commands that are being run if needed.
