Hi everyone, I’m new to VyOS but I have used JunOS before, so it’s not to hard for me to handle VyOS.
I use VyOS 1.3.2 to operate a BGP network with a few upstreams. Here is what I’m facing:
set interfaces ethernet eth0 address ‘x.x.x.x/31’
set interfaces ethernet eth0 description ‘Upstream BGP IP’
set interfaces ethernet eth0 firewall local name ‘BGP’
set firewall name BGP default-action ‘drop’
set firewall name BGP rule 1 action ‘accept’
set firewall name BGP rule 1 description ‘Allow traffic from upstream IP’
set firewall name BGP rule 1 source group address-group ‘BGP-IP’
set interfaces ethernet eth1 address ‘x.x.x.1/24’
set interfaces ethernet eth1 description ‘Owned Announcing IP’
set policy route-map BGP-import rule 1 action ‘deny’
set policy route-map BGP-import rule 1 match ip address prefix-list ‘bogons’
set policy route-map BGP-import rule 2 action ‘deny’
set policy route-map BGP-import rule 2 match ipv6 address prefix-list ‘bogonsv6’
set policy route-map BGP-import rule 3 action ‘permit’
set policy route-map BGP-import rule 3 set as-path-exclude ‘xxxxx’
set policy route-map BGP-import rule 3 set src ‘x.x.x.1’
set protocols bgp xxxxx address-family ipv4-unicast network x.x.x.0/24
set protocols bgp xxxxx neighbor xx.xx.xx.xx address-family ipv4-unicast route-map import ‘BGP-import’
set protocols bgp xxxxx neighbor xx.xx.xx.xx remote-as ‘xxxxx’
set protocols bgp xxxxx neighbor xx.xx.xx.xx solo
I use route-map to set src IP, but nothing happened.
Hi @ILLKX , did you configure source ip address on eth0 which you define in policy route-map BGP-import rule 3 set src ‘x.x.x.1’?
A bit complex to understand without toplogy and full ip address masking, what do you really want to achive . Maybe it will be better to use show configuration commands | strip-private
Thank you very much for the reply. Yes, the x.x.x.1 has been configured on eth1 instead of eth0. I have spent some time to reproduce on a completely new machine with both VyOS 1.3.2 and the rolling release and the result remains. Below is my configuration:
set interfaces ethernet eth0 address 'xxx.xxx.109.211/23'
set interfaces ethernet eth1 address 'xxx.xxx.0.1/24'
set interfaces loopback lo
set policy route-map import rule 1 action 'permit'
set policy route-map import rule 1 set local-preference '100'
set policy route-map import rule 1 set src 'xxx.xxx.0.1'
set protocols bgp neighbor xxx.xxx.169.254 address-family ipv4-unicast route-map import 'import'
set protocols bgp neighbor xxx.xxx.169.254 ebgp-multihop '2'
set protocols bgp neighbor xxx.xxx.169.254 password xxxxxx
set protocols bgp neighbor xxx.xxx.169.254 remote-as '64515'
set protocols bgp neighbor xxx.xxx.169.254 solo
set protocols bgp parameters default local-pref '100'
set protocols bgp parameters ebgp-requires-policy
set protocols bgp system-as '4288000215'
set protocols static route xxx.xxx.0.0/0 next-hop xxx.xxx.108.1
set protocols static route xxx.xxx.169.254/32 next-hop xxx.xxx.108.1
set service ssh port '22'
set system host-name xxxxxx
set system ntp server xxxxx.tld
I hope this configuration will help you address the issue.
