Hi
As the title says, is there any way to set the link local address of all the LAN interfaces to FE80::1? That should simplify some setup, such at configuring DNS, as you would no longer need to list each individual interface.
Thanks!
Hi
Thanks!
Please do not use link local address to set DNS to continue recording. This address should only be used for Dad detection and multicast communication in LAN. Router RA should be configured so that clients can obtain stateless address by SLAAC. This address should be unique for intranet prefix. You can set this address to intranet DNS (setting the same address for all clients will cause conflicts)
