I’ve defined a podman network as:
network podman-servers {
description "Virtual network for podman servers"
prefix 172.16.8.0/24
The relevant container is defined as:
description "Database for Passbolt"
image mariadb:10.3
volume database_volume {
destination /var/lib/mysql
source /config/pods/passbolt/mysql
Committing it results int the container being created and having a “Created” status when running “show container”
running restart container Passbolt-DB results in the following error:
time="2022-11-28T12:19:21Z" level=warning msg="Failed to load cached network config: network podman-servers not found in CNI cache, falling back to loading network podman-servers from disk"
Error: plugin type="bridge" failed (add): cni plugin bridge failed: failed to create bridge "cni-podman-servers": could not add "cni-podman-servers": numerical result out of range
despite the network being defined:
sudo podman network inspect podman-servers
"name": "podman-servers",
"id": "a8da27c417b2b84e8d411a5f53c082c634982a8703d7f84a3b3987ae7b30237f",
"driver": "bridge",
"network_interface": "cni-podman-servers",
"created": "2022-11-28T12:17:59.405896553Z",
"subnets": [
"subnet": "172.16.8.0/24",
"gateway": "172.16.8.1"
"ipv6_enabled": false,
"internal": false,
"dns_enabled": false,
"ipam_options": {
"driver": "host-local"
