Is it possible to configure the HTB shaper to limit the incoming and outgoing speed of the vlan interfaces?
old script htb.init allows you to limit the incoming and outgoing speed.
But I can’t make a simple rule shaper in VyOS.
In the future, I want to change the shaper through http api
Hello @zavndw, you can use input interface
for using HTB
https://docs.vyos.io/en/latest/configuration/trafficpolicy/index.html#the-case-of-ingress-shaping
I have over 100 vlan interfaces. I looked at the option from the link, it is suitable for 1 interface
I’m sure that it is possible to use a redirect to one IFB
for many subinterfaces. I think you need to try.
Also, I think that policer
has more performance if you have a high load system.
I created a sub interface ifbXXX for each vlan. thanks
