Keyvan
November 10, 2020, 11:17am
1
Hi community
I am trying to run this scenario:
in this scenario I am trying to establish an IPSec between 192.168.2.1(vyos right side) and 10.4.1.2(cisco router in the left side)
in my scenario 192.168.2.1 is behind the nat and translated to 172.2.3.1.
I use
set ipsec site-to-site peer 10.4.1.2 force-encapsulation ‘enable’
set ipsec ike-group VR02_ike mobike ‘disable’
but its not still working
I will attach the VyOS and Cisco router configuration
cisco-router.txt (3 KB) Vy-cfg.txt (2.0 KB)
Thanks you
Keyvan
Is it works without NAT? One typo
On the scheme and in configuration IP addresses mismatch
eth0 10.2.2 .3 on the network map and 10.2.3 .2 in the vyos config.
Try that configuration.
For example, we use 10.2.3.2 on eth0
Delete loopback 172.2.3.1
Change IPSec interface to eth0
Use authentication id 172.2.3.1
set interfaces dummy dum0 address '10.20.20.1/24'
set interfaces ethernet eth0 address '10.2.3.2/30'
set protocols static route 10.4.1.0/30 next-hop 10.2.3.1
set system host-name 'vyos'
set vpn ipsec esp-group VR02_esp compression 'disable'
set vpn ipsec esp-group VR02_esp lifetime '3600'
set vpn ipsec esp-group VR02_esp mode 'tunnel'
set vpn ipsec esp-group VR02_esp pfs 'disable'
set vpn ipsec esp-group VR02_esp proposal 1 encryption 'aes256'
set vpn ipsec esp-group VR02_esp proposal 1 hash 'sha256'
set vpn ipsec ike-group VR02_ike close-action 'none'
set vpn ipsec ike-group VR02_ike ikev2-reauth 'no'
set vpn ipsec ike-group VR02_ike key-exchange 'ikev2'
set vpn ipsec ike-group VR02_ike lifetime '86400'
set vpn ipsec ike-group VR02_ike mobike 'disable'
set vpn ipsec ike-group VR02_ike proposal 2 dh-group '14'
set vpn ipsec ike-group VR02_ike proposal 2 encryption 'aes256'
set vpn ipsec ike-group VR02_ike proposal 2 hash 'sha256'
set vpn ipsec site-to-site peer 10.4.1.2 authentication id '172.2.3.1'
set vpn ipsec site-to-site peer 10.4.1.2 authentication mode 'pre-shared-secret'
set vpn ipsec site-to-site peer 10.4.1.2 authentication pre-shared-secret 'salam'
set vpn ipsec site-to-site peer 10.4.1.2 connection-type 'initiate'
set vpn ipsec site-to-site peer 10.4.1.2 force-encapsulation 'enable'
set vpn ipsec site-to-site peer 10.4.1.2 ike-group 'VR02_ike'
set vpn ipsec site-to-site peer 10.4.1.2 ikev2-reauth 'inherit'
set vpn ipsec site-to-site peer 10.4.1.2 local-address '10.2.3.2'
set vpn ipsec site-to-site peer 10.4.1.2 tunnel 0 allow-nat-networks 'disable'
set vpn ipsec site-to-site peer 10.4.1.2 tunnel 0 allow-public-networks 'disable'
set vpn ipsec site-to-site peer 10.4.1.2 tunnel 0 esp-group 'VR02_esp'
set vpn ipsec site-to-site peer 10.4.1.2 tunnel 0 local prefix '10.20.20.0/24'
set vpn ipsec site-to-site peer 10.4.1.2 tunnel 0 remote prefix '10.10.10.0/24'
VyOS host:
vyos@vyos:~$ show vpn ipsec sa
Connection State Up Bytes In/Out Remote address Remote ID Proposal
peer-10.4.1.2-tunnel-0 up 5 minutes 0B/0B 10.4.1.2 N/A AES_CBC_256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_2048
vyos@vyos:~$ show vpn ipsec sa verbose
Status of IKE charon daemon (strongSwan 5.7.2, Linux 4.19.142-amd64-vyos, x86_64):
uptime: 5 minutes, since Nov 10 19:32:41 2020
Listening IP addresses:
10.2.3.2
Connections:
peer-10.4.1.2-tunnel-0: 10.2.3.2...10.4.1.2 IKEv2
peer-10.4.1.2-tunnel-0: local: [172.2.3.1] uses pre-shared key authentication
peer-10.4.1.2-tunnel-0: remote: [10.4.1.2] uses pre-shared key authentication
peer-10.4.1.2-tunnel-0: child: 10.20.20.0/24 === 10.10.10.0/24 TUNNEL
peer-10.4.1.2-tunnel-0[1]: ESTABLISHED 5 minutes ago, 10.2.3.2[172.2.3.1]...10.4.1.2[10.4.1.2]
peer-10.4.1.2-tunnel-0[1]: IKEv2 SPIs: 54ea438aa7c7df94_i* 0b5e15548368f594_r, rekeying in 23 hours
peer-10.4.1.2-tunnel-0[1]: IKE proposal: AES_CBC_256/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/MODP_2048
peer-10.4.1.2-tunnel-0{1}: INSTALLED, TUNNEL, reqid 1, ESP in UDP SPIs: cd354e7a_i 43edd033_o
peer-10.4.1.2-tunnel-0{1}: AES_CBC_256/HMAC_SHA2_256_128, 0 bytes_i, 0 bytes_o, rekeying in 43 minutes
peer-10.4.1.2-tunnel-0{1}: 10.20.20.0/24 === 10.10.10.0/24
Cisco:
Switch#show crypto session
Crypto session current status
Interface: Ethernet0/0
Profile: site1_to_site2-profile
Session status: UP-ACTIVE
Peer: 172.2.3.1 port 4500
Session ID: 2
IKEv2 SA: local 10.4.1.2/4500 remote 172.2.3.1/4500 Active
IPSEC FLOW: permit ip 10.10.10.0/255.255.255.0 10.20.20.0/255.255.255.0
Active SAs: 2, origin: crypto map
Switch#
Switch#show crypto ikev2 sa
IPv4 Crypto IKEv2 SA
Tunnel-id Local Remote fvrf/ivrf Status
2 10.4.1.2/4500 172.2.3.1/4500 none/none READY
Encr: AES-CBC, keysize: 256, PRF: SHA256, Hash: SHA256, DH Grp:14, Auth sign: PSK, Auth verify: PSK
Life/Active Time: 3600/752 sec
IPv6 Crypto IKEv2 SA
Switch#
Keyvan
November 10, 2020, 8:07pm
4
the scheme was wrong the VyOS int ip was correct
As I wanted to test on the NAT network, I did not test without NAT
In my scheme “R2” do nat 1:1 172.2.3.1 => 10.2.3.2
And “vyos” node behind nat.
Try my above configuration.
Keyvan
November 10, 2020, 8:24pm
6
Viacheslav:
show vpn ipsec sa
Great
let me check and inform you
Keyvan
November 10, 2020, 9:31pm
7
Thanks a lot in my real network I have floating ip and by using “authentication id” the problem has been solved
but in the lab because the ip 10.2.3.2 has been set on my interface and I doing static nat on R2 they have overlapped together and not working
