Slow outbound forwarding
I have the following setup (simplified):
Client (ConnectX 5) ← 100g fiber → Switch (Mikrotik CRS510) ← 100g DAC → Router (ConnectX 4 2x 100g) ← 25g fiber–> Internet
Running a speed test on the router yields ~22g download/upload to the internet.
Running iperf from client to router yields 70-90g.
Running a speed test on the client to internet gets ~22g download but just 400m upload.
The router has a dual port ConnectX 4. One trunk port with multiple vlans to the switch, and one plain to the internet. I’ve tested both with VyOS and with a Live CD Debian 12. Also tested with different clients, all same result. With the Live CD I tested with very simple setup (NAT + allow all outbound / established). Also tried moving WAN to the switch as a VLAN on the same interface as LAN vlans.
Doing download tests I get visible CPU load for handling the 22g, but doing upload the CPU (7700X) is almost idle.
I tried setting/disabling different offloads, so far no idea what else to test. MTU on all interfaces is 1500. Upgraded to latest ConnectX firmware etc.
This sounds very much like a MTU/fragmentation problem to me.
If your TCP (to a file!) the traffic on the router when you’re doing an upload and examine it, do you see a lot of fragmented packets/TCP retransmits?
I expect somewhere you have an MTU issue, probably between your Client and your Router. TCP is able to do retransmits etc “fast enough” between those two point so the loss doesn’t show up in your testing as badly.
All interfaces on clients and router are MTU 1500, also set the interfaces on Mikrotik to 1500 to be sure, still the same issue.
Yes I understand that. What does TCPDUMP show? What does your switch have set for MTU?
I did a capture during upload on the router’s LAN interface: sudo tcpdump -i eth1 -s 0 host 77.109.175.63
(77.109.175.63 is the remote speedtest server)
No  Time        Src         Dst             Pro Length  Info
26	0.070335	10.2.2.1	77.109.175.63	TCP	34822	51434 → 8080 [ACK] Seq=1841857 Ack=1 Win=65535 Len=34752 TSval=1561212148 TSecr=599954409
27	0.070503	10.2.2.1	77.109.175.63	TCP	1518	51434 → 8080 [ACK] Seq=1876609 Ack=1 Win=65535 Len=1448 TSval=1561212148 TSecr=599954409
28	0.070741	10.2.2.1	77.109.175.63	TCP	24686	51434 → 8080 [ACK] Seq=1878057 Ack=1 Win=65535 Len=24616 TSval=1561212148 TSecr=599954409
29	0.070804	10.2.2.1	77.109.175.63	TCP	17446	51434 → 8080 [ACK] Seq=1902673 Ack=1 Win=65535 Len=17376 TSval=1561212148 TSecr=599954409
30	0.071079	10.2.2.1	77.109.175.63	TCP	29030	51434 → 8080 [ACK] Seq=1920049 Ack=1 Win=65535 Len=28960 TSval=1561212148 TSecr=599954409
31	0.071129	10.2.2.1	77.109.175.63	TCP	7310	51434 → 8080 [ACK] Seq=1949009 Ack=1 Win=65535 Len=7240 TSval=1561212148 TSecr=599954409
32	0.071244	10.2.2.1	77.109.175.63	TCP	17446	51434 → 8080 [ACK] Seq=1956249 Ack=1 Win=65535 Len=17376 TSval=1561212148 TSecr=599954409
33	0.071255	10.2.2.1	77.109.175.63	TCP	10206	51434 → 8080 [ACK] Seq=1973625 Ack=1 Win=65535 Len=10136 TSval=1561212148 TSecr=599954409
34	0.071595	10.2.2.1	77.109.175.63	TCP	37718	51434 → 8080 [ACK] Seq=1983761 Ack=1 Win=65535 Len=37648 TSval=1561212148 TSecr=599954409
35	0.071648	10.2.2.1	77.109.175.63	TCP	11654	51434 → 8080 [ACK] Seq=2021409 Ack=1 Win=65535 Len=11584 TSval=1561212148 TSecr=599954409
36	0.071783	10.2.2.1	77.109.175.63	TCP	39166	51434 → 8080 [ACK] Seq=2032993 Ack=1 Win=65535 Len=39096 TSval=1561212148 TSecr=599954409
37	0.071952	10.2.2.1	77.109.175.63	TCP	21790	51434 → 8080 [ACK] Seq=2072089 Ack=1 Win=65535 Len=21720 TSval=1561212148 TSecr=599954409
38	0.072286	77.109.175.63	10.2.2.1	TCP	70	8080 → 51434 [ACK] Seq=1 Ack=1876609 Win=16319 Len=0 TSval=599954411 TSecr=1561212148
39	0.072324	77.109.175.63	10.2.2.1	TCP	70	8080 → 51434 [ACK] Seq=1 Ack=1878057 Win=16342 Len=0 TSval=599954411 TSecr=1561212148
40	0.072491	10.2.2.1	77.109.175.63	TCP	65230	51434 → 8080 [ACK] Seq=2093809 Ack=1 Win=65535 Len=65160 TSval=1561212148 TSecr=599954409
41	0.072494	10.2.2.1	77.109.175.63	TCP	10206	51434 → 8080 [ACK] Seq=2158969 Ack=1 Win=65535 Len=10136 TSval=1561212148 TSecr=599954409
42	0.072635	77.109.175.63	10.2.2.1	TCP	70	8080 → 51434 [ACK] Seq=1 Ack=1902673 Win=16494 Len=0 TSval=599954412 TSecr=1561212148
43	0.072661	77.109.175.63	10.2.2.1	TCP	70	8080 → 51434 [ACK] Seq=1 Ack=1920049 Win=16531 Len=0 TSval=599954412 TSecr=1561212148
44	0.072967	77.109.175.63	10.2.2.1	TCP	70	8080 → 51434 [ACK] Seq=1 Ack=1949009 Win=16470 Len=0 TSval=599954412 TSecr=1561212148
45	0.072982	77.109.175.63	10.2.2.1	TCP	70	8080 → 51434 [ACK] Seq=1 Ack=1956249 Win=16432 Len=0 TSval=599954412 TSecr=1561212148
46	0.073036	10.2.2.1	77.109.175.63	TCP	65230	51434 → 8080 [ACK] Seq=2169105 Ack=1 Win=65535 Len=65160 TSval=1561212148 TSecr=599954409
47	0.073043	10.2.2.1	77.109.175.63	TCP	4414	51434 → 8080 [ACK] Seq=2234265 Ack=1 Win=65535 Len=4344 TSval=1561212148 TSecr=599954409
48	0.073098	10.2.2.1	77.109.175.63	TCP	2966	51434 → 8080 [ACK] Seq=2238609 Ack=1 Win=65535 Len=2896 TSval=1561212148 TSecr=599954409
49	0.073113	10.2.2.1	77.109.175.63	TCP	7310	51434 → 8080 [ACK] Seq=2241505 Ack=1 Win=65535 Len=7240 TSval=1561212148 TSecr=599954409
50	0.073179	77.109.175.63	10.2.2.1	TCP	70	8080 → 51434 [ACK] Seq=1 Ack=1983761 Win=16478 Len=0 TSval=599954412 TSecr=1561212148
51	0.073272	10.2.2.1	77.109.175.63	TCP	17446	51434 → 8080 [ACK] Seq=2248745 Ack=1 Win=65535 Len=17376 TSval=1561212148 TSecr=599954409
52	0.073283	10.2.2.1	77.109.175.63	TCP	5862	51434 → 8080 [ACK] Seq=2266121 Ack=1 Win=65535 Len=5792 TSval=1561212148 TSecr=599954409
53	0.073377	10.2.2.1	77.109.175.63	TCP	18894	51434 → 8080 [ACK] Seq=2271913 Ack=1 Win=65535 Len=18824 TSval=1561212148 TSecr=599954409
54	0.073536	10.2.2.1	77.109.175.63	TCP	20342	51434 → 8080 [ACK] Seq=2290737 Ack=1 Win=65535 Len=20272 TSval=1561212148 TSecr=599954409
55	0.073577	77.109.175.63	10.2.2.1	TCP	70	8080 → 51434 [ACK] Seq=1 Ack=2032993 Win=16365 Len=0 TSval=599954413 TSecr=1561212148
56	0.073589	10.2.2.1	77.109.175.63	TCP	4414	51434 → 8080 [ACK] Seq=2311009 Ack=1 Win=65535 Len=4344 TSval=1561212148 TSecr=599954409
57	0.073686	77.109.175.63	10.2.2.1	TCP	70	8080 → 51434 [ACK] Seq=1 Ack=2072089 Win=16418 Len=0 TSval=599954413 TSecr=1561212148
58	0.073808	77.109.175.63	10.2.2.1	TCP	70	8080 → 51434 [ACK] Seq=1 Ack=2093809 Win=16509 Len=0 TSval=599954413 TSecr=1561212148
59	0.073820	10.2.2.1	77.109.175.63	TCP	36270	51434 → 8080 [ACK] Seq=2315353 Ack=1 Win=65535 Len=36200 TSval=1561212148 TSecr=599954409
60	0.073832	10.2.2.1	77.109.175.63	TCP	10206	51434 → 8080 [ACK] Seq=2351553 Ack=1 Win=65535 Len=10136 TSval=1561212148 TSecr=599954409
61	0.073916	10.2.2.1	77.109.175.63	TCP	11654	51434 → 8080 [ACK] Seq=2361689 Ack=1 Win=65535 Len=11584 TSval=1561212148 TSecr=599954409
62	0.074039	10.2.2.1	77.109.175.63	TCP	10206	51434 → 8080 [ACK] Seq=2373273 Ack=1 Win=65535 Len=10136 TSval=1561212148 TSecr=599954409
63	0.074053	10.2.2.1	77.109.175.63	TCP	1518	51434 → 8080 [ACK] Seq=2383409 Ack=1 Win=65535 Len=1448 TSval=1561212148 TSecr=599954409
64	0.074376	77.109.175.63	10.2.2.1	TCP	70	8080 → 51434 [ACK] Seq=1 Ack=2116977 Win=16501 Len=0 TSval=599954413 TSecr=1561212148
65	0.074437	77.109.175.63	10.2.2.1	TCP	70	8080 → 51434 [ACK] Seq=1 Ack=2169105 Win=16094 Len=0 TSval=599954413 TSecr=1561212148
66	0.074658	10.2.2.1	77.109.175.63	TCP	65230	51434 → 8080 [ACK] Seq=2384857 Ack=1 Win=65535 Len=65160 TSval=1561212148 TSecr=599954409
67	0.074659	10.2.2.1	77.109.175.63	TCP	5862	51434 → 8080 [ACK] Seq=2450017 Ack=1 Win=65535 Len=5792 TSval=1561212148 TSecr=599954409
68	0.074715	10.2.2.1	77.109.175.63	TCP	5862	51434 → 8080 [ACK] Seq=2455809 Ack=1 Win=65535 Len=5792 TSval=1561212148 TSecr=599954409
69	0.074964	77.109.175.63	10.2.2.1	TCP	70	8080 → 51434 [ACK] Seq=1 Ack=2187929 Win=16524 Len=0 TSval=599954414 TSecr=1561212148
Mikrotik default was 9000, I set the two interfaces used in the test to 1500.
If you your capture up in Wireshark does it show any duplicate ACKs etc
Now and then I see some:
322	0.114818	77.109.175.63	10.2.2.1	TCP	82	[TCP Dup ACK 318#1] 8080 → 51434 [ACK] Seq=1 Ack=3302889 Win=24515 Len=0 TSval=599954454 TSecr=1561212190 SLE=3304337 SRE=3315921
323	0.115139	10.2.2.1	77.109.175.63	TCP	1518	[TCP Retransmission] 51434 → 8080 [ACK] Seq=3302889 Ack=1 Win=65535 Len=1448 TSval=1561212192 TSecr=599954454
324	0.115139	10.2.2.1	77.109.175.63	TCP	1518	51434 → 8080 [ACK] Seq=3334745 Ack=1 Win=65535 Len=1448 TSval=1561212192 TSecr=599954454
325	0.116158	77.109.175.63	10.2.2.1	TCP	82	[TCP Dup ACK 318#2] 8080 → 51434 [ACK] Seq=1 Ack=3302889 Win=24515 Len=0 TSval=599954455 TSecr=1561212190 SLE=3304337 SRE=3330401
326	0.116196	77.109.175.63	10.2.2.1	TCP	82	[TCP Dup ACK 318#3] 8080 → 51434 [ACK] Seq=1 Ack=3302889 Win=24515 Len=0 TSval=599954455 TSecr=1561212190 SLE=3304337 SRE=3334745
When I’m doing a tcpdump on the client: sudo tcpdump -i en14 -s 0 host 77.109.175.63 -w capture.pcap
4	0.000039	10.2.2.1	77.109.175.63	TCP	1514	54124 → 8080 [ACK] Seq=14481 Ack=1 Win=65535 Len=1448 TSval=2255708013 TSecr=602381411
5	0.000039	10.2.2.1	77.109.175.63	TCP	1514	54124 → 8080 [ACK] Seq=15929 Ack=1 Win=65535 Len=1448 TSval=2255708013 TSecr=602381411
6	0.000040	10.2.2.1	77.109.175.63	TCP	1514	54124 → 8080 [ACK] Seq=17377 Ack=1 Win=65535 Len=1448 TSval=2255708013 TSecr=602381411
7	0.000041	10.2.2.1	77.109.175.63	TCP	1514	54124 → 8080 [ACK] Seq=18825 Ack=1 Win=65535 Len=1448 TSval=2255708013 TSecr=602381411
8	0.000041	10.2.2.1	77.109.175.63	TCP	1514	54124 → 8080 [ACK] Seq=20273 Ack=1 Win=65535 Len=1448 TSval=2255708013 TSecr=602381411
9	0.000042	10.2.2.1	77.109.175.63	TCP	1514	54124 → 8080 [ACK] Seq=21721 Ack=1 Win=65535 Len=1448 TSval=2255708013 TSecr=602381411
10	0.000042	10.2.2.1	77.109.175.63	TCP	1514	54124 → 8080 [ACK] Seq=23169 Ack=1 Win=65535 Len=1448 TSval=2255708013 TSecr=602381411
11	0.000043	10.2.2.1	77.109.175.63	TCP	1514	54124 → 8080 [ACK] Seq=24617 Ack=1 Win=65535 Len=1448 TSval=2255708013 TSecr=602381411
12	0.000076	10.2.2.1	77.109.175.63	TCP	1514	54120 → 8080 [ACK] Seq=15929 Ack=1 Win=65535 Len=1448 TSval=2802166125 TSecr=602381411
13	0.000077	10.2.2.1	77.109.175.63	TCP	1514	54120 → 8080 [ACK] Seq=17377 Ack=1 Win=65535 Len=1448 TSval=2802166125 TSecr=602381411
14	0.000077	10.2.2.1	77.109.175.63	TCP	1514	54120 → 8080 [ACK] Seq=18825 Ack=1 Win=65535 Len=1448 TSval=2802166125 TSecr=602381411
15	0.000078	10.2.2.1	77.109.175.63	TCP	1514	54120 → 8080 [ACK] Seq=20273 Ack=1 Win=65535 Len=1448 TSval=2802166125 TSecr=602381411
16	0.000079	10.2.2.1	77.109.175.63	TCP	1514	54120 → 8080 [ACK] Seq=21721 Ack=1 Win=65535 Len=1448 TSval=2802166125 TSecr=602381411
17	0.000079	10.2.2.1	77.109.175.63	TCP	1514	54120 → 8080 [ACK] Seq=23169 Ack=1 Win=65535 Len=1448 TSval=2802166125 TSecr=602381411
18	0.000080	10.2.2.1	77.109.175.63	TCP	1514	54120 → 8080 [ACK] Seq=24617 Ack=1 Win=65535 Len=1448 TSval=2802166125 TSecr=602381411
19	0.000081	10.2.2.1	77.109.175.63	TCP	1514	54120 → 8080 [ACK] Seq=26065 Ack=1 Win=65535 Len=1448 TSval=2802166125 TSecr=602381411
20	0.000182	77.109.175.63	10.2.2.1	TCP	66	8080 → 54123 [ACK] Seq=1 Ack=1 Win=24530 Len=0 TSval=602381411 TSecr=678372975
21	0.000222	10.2.2.1	77.109.175.63	TCP	1514	54123 → 8080 [ACK] Seq=8689 Ack=1 Win=65535 Len=1448 TSval=678372977 TSecr=602381411
22	0.000223	10.2.2.1	77.109.175.63	TCP	1514	54123 → 8080 [ACK] Seq=10137 Ack=1 Win=65535 Len=1448 TSval=678372977 TSecr=602381411
23	0.000224	10.2.2.1	77.109.175.63	TCP	1514	54123 → 8080 [ACK] Seq=11585 Ack=1 Win=65535 Len=1448 TSval=678372977 TSecr=602381411
24	0.000225	10.2.2.1	77.109.175.63	TCP	1514	54123 → 8080 [ACK] Seq=13033 Ack=1 Win=65535 Len=1448 TSval=678372977 TSecr=602381411
25	0.000225	10.2.2.1	77.109.175.63	TCP	1514	54123 → 8080 [ACK] Seq=14481 Ack=1 Win=65535 Len=1448 TSval=678372977 TSecr=602381411
26	0.000226	10.2.2.1	77.109.175.63	TCP	1514	54123 → 8080 [ACK] Seq=15929 Ack=1 Win=65535 Len=1448 TSval=678372977 TSecr=602381411
27	0.000227	10.2.2.1	77.109.175.63	TCP	1514	54123 → 8080 [ACK] Seq=17377 Ack=1 Win=65535 Len=1448 TSval=678372977 TSecr=602381411
28	0.000227	10.2.2.1	77.109.175.63	TCP	1514	54123 → 8080 [ACK] Seq=18825 Ack=1 Win=65535 Len=1448 TSval=678372977 TSecr=602381411
29	0.000228	10.2.2.1	77.109.175.63	TCP	1514	54123 → 8080 [ACK] Seq=20273 Ack=1 Win=65535 Len=1448 TSval=678372977 TSecr=602381411
30	0.000229	10.2.2.1	77.109.175.63	TCP	1514	54123 → 8080 [ACK] Seq=21721 Ack=1 Win=65535 Len=1448 TSval=678372977 TSecr=602381411
31	0.000229	10.2.2.1	77.109.175.63	TCP	1514	54123 → 8080 [ACK] Seq=23169 Ack=1 Win=65535 Len=1448 TSval=678372977 TSecr=602381411
32	0.000230	10.2.2.1	77.109.175.63	TCP	1514	54123 → 8080 [ACK] Seq=24617 Ack=1 Win=65535 Len=1448 TSval=678372977 TSecr=602381411
33	0.000263	77.109.175.63	10.2.2.1	TCP	66	8080 → 54123 [ACK] Seq=1 Ack=7241 Win=24576 Len=0 TSval=602381411 TSecr=678372975
Try doing some pings from the client with donotfragment set etc. I may be wrong you have an MTU issue but still that’s what it seems like to me based on what you’ve posted.
I did a try for both the router and the remote host which ended up the same:
sh-3.2# ping -D -g 1470 -G 1500 10.2.0.1
PING 10.2.0.1 (10.2.0.1): (1470 ... 1500) data bytes
1478 bytes from 10.2.0.1: icmp_seq=0 ttl=64 time=0.929 ms
1479 bytes from 10.2.0.1: icmp_seq=1 ttl=64 time=0.907 ms
1480 bytes from 10.2.0.1: icmp_seq=2 ttl=64 time=1.014 ms
ping: sendto: Message too long
But I got the same issues directly connecting the client and the firewall.
