Smoketests fail when building ISO image
Hi All,
Not sure if I’m being an idiot here or whether there is a (pretty fundamental) bug in the current build of VyOS. When I follow the build instructions and make an ISO and then run “make test” a lot of the smoketests fail for me. Specifically, the ones related to the DHCP server seem to be the worst as all of them fail. I conducted the build on a fresh virtual machine with everything installed from scratch using the official docker images to do the actual build/test. Could someone have a look at the attached error log and/or run the smoketests on their machine and see if they also fail?
Thanks
Chris
smoketest errors.txt (81.8 KB)
They really were failed (dhcp + vrf)
Should be fixed. Nothing to add.
