sNAT secondary outbound-interface not working
I’m having trouble getting a sNAT to work.
When i configure eth0 as outbound interface everything works correctly but if I change to eth3 it stops working and I see no traffic in NAT monitor.
I’m new to vyos, can someone point me in right direction?
     address 10.110.100.95/24
     address 10.110.100.96/24
     description `OUTSIDE`
     firewall {
         in {
             name OUTSIDE-IN
         local {
             name OUTSIDE-LOCAL
 ethernet eth2 {
     address 192.168.100.1/24
     description vyos-internal-lab
 ethernet eth3 {
     address 192.168.3.170/24
     firewall {
         in {
             name OUTSIDE-IN
         local {
             name OUTSIDE-LOCAL
     rule 110 {
         log
         outbound-interface eth3
             address 192.168.100.0/24
         translation {
             address masquerade
When you modify nat rules to oubound interface eth3, do you also change your routing table? Otherwise, traffic will still try to go out through eth0
Thank you for your answer.
 static {
     route 0.0.0.0/0 {
         next-hop 10.110.100.1 {
     route 192.168.3.0/24 {
         next-hop 192.168.3.1 {
The output from run show ip route static shows inactive, not sure why. Do i need to enable it?
S>* 0.0.0.0/0 [1/0] via 10.110.100.1, eth0, weight 1, 07:31:07
S   192.168.3.0/24 [1/0] via 192.168.3.1 inactive, weight 1, 02:14:36
Hi, next route is not necessary, since network 192.168.3.0/24 is attached to interface… If you type “show ip route” you may see it
set protocols static route 192.168.3.0/24 next-hop 192.168.3.1
So, you should delete it with:
del protocols static route 192.168.3.0/24
Also, you have configured you default gateway as 10.110.100.1 with command:
set protocols static route 0.0.0.0/0 next-hop 10.110.100.1
That is correct if you want your traffic to go out through eth0.
To configure default gateway through eth3, you should:
#First delete gateway through eth0
del protocols static route 0.0.0.0/0 next-hop 10.110.100.1
# Configure gateway through eth3
set protocols static route 0.0.0.0/0 next-hop 192.168.110.3.1
#Commit changes
commit
# Save changes
save
The goal is for traffic from the local subnets to go out through different interfaces.
In my lab environment, eth0 and eth3 correspond to WAN interfaces with different ISPs.
Maybe it’s my default route that’s causing the problem or some other component of my lab environment.
        rule 100 {
            log
            outbound-interface eth0
                address 10.112.100.0/24
            translation {
                address masquerade
        rule 110 {
            log
            translation {
                address masquerade
If that is your goal, please refer to this docs:
WAN Load Balancing: WAN load balancing — VyOS 1.3.x (equuleus) documentation
Policy and multiple uplinks example: Policy — VyOS 1.3.x (equuleus) documentation
