We just started playing with VYOS in the classroom and want to incorporate into test labs.
I have setup 2 routers to simplify how our students build test labs in Hyper-V.
Router1-VYOS has 3 interfaces
eth0 - DHCP (access to internet)
eth1 - 192.168.1.1./24 (Subnet1)
eth2 - 10.1.1.1/30 (WANLink1-2)
Router2-VYOS has 2 interfaces
eth0 - 10.1.1.2/30 (WANLink1-2)
eth1 - 192.168.2.1/24 (Subnet2)
Router1 has the following setup.
INTERFACES (router1)
set interfaces ethernet eth0 address dhcp
set interfaces ethernet eth0 description âExternalâ
set interfaces ethernet eth1 address â192.168.1.1/24â
set interfaces ethernet eth1 description âSubnet1â
set interfaces ethernet eth2 address â10.1.1.1/30â
set interfaces ethernet eth2 description âWANLink1-2â
RIP
set protocols rip network 192.168.1.0/24
set protocols rip interface eth1
set protocols rip neighbor 10.1.1.2
set protocols rip passive-interface default
NAT
set nat source rule 100 description âOutbound NAT for Subnet1â
set nat source rule 100 outbound-interface eth0
set nat source rule 100 source address 192.168.1.0/24
set nat source rule 100 translation address masquerade
set nat source rule 110 description âOutbound NAT for Subnet2â
set nat source rule 110 outbound-interface eth0
set nat source rule 110 source address 192.168.2.0/24
set nat source rule 110 translation address masquerade
Router2 has the following setup.
INTERFACES (router2)
set interfaces ethernet eth0 address 10.1.1.2/30
set interfaces ethernet eth0 description âWANLink1-2â
set interfaces ethernet eth1 address â192.168.2.1/24â
set interfaces ethernet eth1 description âSubnet2â
RIP(router2)
set protocols rip network 192.168.2.0/24
set protocols rip neighbor 10.1.1.1
DHCP Relay (Router2)
set service dhcp-relay listen-interface eth1
set service dhcp-relay upstream-interface eth0
set service dhcp-relay server 192.168.1.2
Set DEFAULT ROUTE
set protocols static route 0.0.0.0/0 next-hop 10.1.1.1
My issue is NAT works fine on Router1 but not with Router2. router2 can ping everything on Subnet1, but goes no further. Pings and traceroutes just die.
Can anyone lend assistance? I want to have our students perform their own setups and need to be able to show them how to make everything works.
