Hi folks,
Been puzzling over this one for ages. Right up to Equulus 202103 seems that SNMP V3 just doesn’t work. SNMP V2 is fine, but V3 just returns… nothing, timeouts. After doing many changes and tests I blew the config all away and started again with the example in the wiki:
vyos@vyos# show service snmp v3
engineid 000000000000000000000002
group default {
mode ro
view default
user vyos {
auth {
encrypted-password 4e52fe55fd011c9c51ae2c65f4b78ca93dcafdfe
type sha
group default
privacy {
type aes
view default {
oid 1 {
Both SNMPwalk and Paessler SNMP Tester return timeouts while running tcpdump on the node returns nothing but invalidEngineID:
vyos@vyos# tcpdump -vv | grep snmp
tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
10.168.243.16.61406 > 10.168.243.241.snmp: [udp sum ok] { SNMPv3 { F=r } { USM B=0 T=0 U="" } { ScopedPDU E= C="000000000000000000000002" { GetRequest(12) R=1534 } } }
10.168.243.241.snmp > 10.168.243.16.61406: [bad udp cksum 0xfcd1 → 0x7d7f!] { SNMPv3 { F= } { USM B=1 T=1330 U=“” } { ScopedPDU E=_00_00_00_00_00_00_00_00_00_00_00_02 C=“” { Report(29) R=1534 S:snmpUsmMIB.usmMIBObjects.usmStats.usmStatsUnknownEngineIDs.0=21 } } }
10.168.243.16.61406 > 10.168.243.241.snmp: [udp sum ok] { SNMPv3 { F=apr } { USM B=1 T=1330 U="vyos" } { ScopedPDU [!scoped PDU]c3_68_05_8d_dc_d9_f0_10_c2_81_fe_06_a7_bd_bd_dd_74_ec_30_e3_d2_ea_22_a6_72_e3_2b_e1_e0_9b_0e_fc_5e_40_c7_b5_f2_83_38_d6_48_79_6c_e1_d6_92_33_04_60_a5_a8_5c_25_57_e3_9f_81_d0_87_43_0b_69_0f_4f_3a_3b_68_76_fd_01} }
10.168.243.16.61407 > 10.168.243.241.snmp: [udp sum ok] { SNMPv3 { F=r } { USM B=0 T=0 U="" } { ScopedPDU E= C="000000000000000000000002" { GetRequest(12) R=5067 } } }
10.168.243.241.snmp > 10.168.243.16.61407: [bad udp cksum 0xfcd1 -> 0x082c!] { SNMPv3 { F= } { USM B=1 T=1332 U="" } { ScopedPDU E=_00_00_00_00_00_00_00_00_00_00_00_02 C="" { Report(29) R=5067 S:snmpUsmMIB.usmMIBObjects.usmStats.usmStatsUnknownEngineIDs.0=22 } } }
10.168.243.16.61407 > 10.168.243.241.snmp: [udp sum ok] { SNMPv3 { F=apr } { USM B=1 T=1332 U="vyos" } { ScopedPDU [!scoped PDU]35_25_98_70_d2_45_82_94_95_a4_51_23_4e_11_6e_3e_4e_84_d3_b6_21_7c_93_3d_54_01_98_52_fa_0e_4e_0f_d3_d8_3d_2d_e9_a2_68_99_bc_6a_19_4b_63_f6_26_48_7c_72_3d_1a_d9_b3_81_8d_58_92_d3_6a_e5_28_e6_39_02_23_2b_8e_9e_43} }
10.168.243.16.61408 > 10.168.243.241.snmp: [udp sum ok] { SNMPv3 { F=r } { USM B=0 T=0 U="" } { ScopedPDU E= C="000000000000000000000002" { GetRequest(12) R=5069 } } }
10.168.243.241.snmp > 10.168.243.16.61408: [bad udp cksum 0xfcd1 -> 0x022a!] { SNMPv3 { F= } { USM B=1 T=1334 U="" } { ScopedPDU E=_00_00_00_00_00_00_00_00_00_00_00_02 C="" { Report(29) R=5069 S:snmpUsmMIB.usmMIBObjects.usmStats.usmStatsUnknownEngineIDs.0=23 } } }
10.168.243.16.61408 > 10.168.243.241.snmp: [udp sum ok] { SNMPv3 { F=apr } { USM B=1 T=1334 U="vyos" } { ScopedPDU [!scoped PDU]11_07_d4_85_e6_56_bd_cc_5e_38_2d_7c_0c_ac_08_0b_a5_0f_87_2e_7e_4b_65_ac_1e_85_a3_29_41_ae_e7_47_54_15_28_ce_c2_18_e3_56_20_40_1a_fa_d0_70_c5_29_ed_ff_c5_4c_65_ef_26_fc_4c_79_37_09_5d_f8_f2_91_46_39_49_44_77_40_58} }
10.168.243.16.61409 > 10.168.243.241.snmp: [udp sum ok] { SNMPv3 { F=r } { USM B=0 T=0 U="" } { ScopedPDU E= C="000000000000000000000002" { GetRequest(12) R=9289 } } }
10.168.243.241.snmp > 10.168.243.16.61409: [bad udp cksum 0xfcd1 -> 0x8042!] { SNMPv3 { F= } { USM B=1 T=1336 U="" } { ScopedPDU E=_00_00_00_00_00_00_00_00_00_00_00_02 C="" { Report(29) R=9289 S:snmpUsmMIB.usmMIBObjects.usmStats.usmStatsUnknownEngineIDs.0=24 } } }
10.168.243.16.61409 > 10.168.243.241.snmp: [udp sum ok] { SNMPv3 { F=apr } { USM B=1 T=1336 U="vyos" } { ScopedPDU [!scoped PDU]d5_38_ce_f6_3a_f3_4a_14_80_09_6c_cf_d3_1f_ac_6e_cf_31_25_6a_aa_88_5a_aa_ac_98_9c_70_77_4d_0c_82_fd_94_bf_a2_7a_52_94_44_2e_91_6c_af_8a_a4_8a_f6_57_33_b8_4f_dc_a0_7c_d2_01_de_fb_4d_14_8a_3c_d5_fc_87_d6_d9_03_bb_49} }
Thanks!
Witchy
