SNMPD configuration incorrect for IPv6
Hello VyOS team !
When configuring the SNMP daemon for IPv4 and IPv6, the generated snmpd.conf file does not contain rocommunity6 statement. Please have a look below for the exact version I’m running and excerpt of my configuration.
VyOS Version:
Version: VyOS 1.4-rolling-202211190627
Release train: current
Built by: autobuild@vyos.net
Built on: Sat 19 Nov 2022 06:27 UTC
Build UUID: 687dfd47-11ca-4c0c-8045-944ed60279be
Build commit ID: cd6f8ab1040139
Architecture: x86_64
Boot via: installed image
System type: KVM guest
Hardware vendor: QEMU
Hardware S/N:
Hardware UUID: 9245d8cc-e46e-4478-b2d8-587b2e087fee
Configuration:
snmp {
    community monitor {
        authorization "ro"
    contact "**redacted**"
    listen-address 10.100.0.2 {
        port "161"
    listen-address 127.0.0.1 {
        port "161"
    listen-address fd00:dead:babe:100::2 {
        port "161"
    location "**redacted**"
Ah yes, there seems to be a copy/paste error in the etc.snmpd.conf.j2 template. It says:
{%         if comm_config.network is vyos_defined %}
{%             for network in comm_config.network %}
{%                 if network | is_ipv4 %}
{{ comm_config.authorization }}community {{ comm }} {{ network }}
{%                 elif client | is_ipv6 %}
{{ comm_config.authorization }}community6 {{ comm }} {{ network }}
{%                 endif %}
{%             endfor %}
{%         endif %}
But should be
{%                 elif network| is_ipv6 %}
{%                 endif %}
{%             endfor %}
{%         endif %}
I’ll create a PR later if time permits.
See:
Hi @roedie,
Thanks for the fix, and I see that the change is in the latest nightly I downloaded this morning. However… It is still not working with the configuration I posted : no community6 string.
Looking a bit more at the template (now that I understand a bit more how it works), I see this line:
{%         if comm_config.client is not vyos_defined and comm_config.network is not vyos_defined %}
{%         endif %}
It does not have any equivalent for community6. Don’t know if it’s the reason it’s not working but it might be.
Actually, I’ve just duplicated the line in the if statement and changed community to community6 and now it works.
However I don’t really know what it implies to have both community statements being generated without more control.
