I have created a feature request regarding software and hardware fastpath with nftables flowtable:
Its based on the added capability of Firewalld as described in their blogpost over at:
So far their results looks promising with +58.5% increase in throughput for the usecase shown in the blogpost (from 12.47Gbps to 19.77Gbps with 2048 concurrent connections).
I wonder if anyone in this forum perhaps already have tested out flowtables (software and/or hardware) in nftables and can share their experience?
Any particular drawbacks by enabling it?
For more information:
As I mentioned in ⚓ T4502 Consider implementing (NAT/other) flow table offload :
As mentioned in ⚓ T5419 Software/Hardware fastpath with nftables flowtable the offloading should not only apply for NAT.
Also it would be prefered if there were option to select between flowtable_software and flowtable_hardware per inferface (or whatever proper naming there might be).
Suggestion is that this setting should be placed in the “set interface ethernet ethX” section instead such as:
set interface ethernet ethX offload_firewall <value>
Where accepted values are “none” (default), “flowtable_software” or “flowtable_hardware”).
Sure it is not only for nat
