I’m trying to reproduce GRE over IPsec example in GNS3, following GRE Over IPsec for Secure Tunneling : VyOS Support Portal (following Configuration Using Just GRE/IPsec ). Using exactly the same configuration, show vpn ipsec sa
indicates the tunnel up and running. However, I cannot ping 10.2.2.1 from central-office-net
Probably missing something obvious… Any hints?
Kind regards
Milos
n.fort
February 4, 2022, 11:01am
2
Can you share your configuration?
Router 1:
address 10.1.1.1/24
hw-id 0c:df:e9:cc:00:00
address 203.0.113.2/24
hw-id 0c:df:e9:cc:00:01
ethernet eth2 {
hw-id 0c:df:e9:cc:00:02
loopback lo {
tunnel tun0 {
address 10.1.1.5/32
encapsulation gre
multicast enable
remote 192.51.100.2
source-address 203.0.113.2
protocols {
static {
route 0.0.0.0/0 {
next-hop 203.0.113.1 {
system {
config-management {
commit-revisions 100
conntrack {
modules {
ftp
h323
nfs
pptp
sip
sqlnet
tftp
console {
device ttyS0 {
speed 115200
host-name central-office-rtr
login {
user vyos {
authentication {
ntp {
server time1.vyos.net {
server time2.vyos.net {
server time3.vyos.net {
syslog {
global {
facility all {
level info
facility protocols {
level debug
vpn {
ipsec {
esp-group central-rtr-esp {
compression disable
lifetime 1800
mode tunnel
pfs enable
proposal 1 {
encryption aes256
hash sha256
ike-group central-rtr-ike {
close-action none
ikev2-reauth no
key-exchange ikev1
lifetime 3600
proposal 1 {
dh-group 2
encryption aes256
hash sha256
ipsec-interfaces {
interface eth1
site-to-site {
peer 192.51.100.2 {
authentication {
mode pre-shared-secret
connection-type initiate
default-esp-group central-rtr-esp
ikev2-reauth inherit
local-address 203.0.113.2
tunnel 0 {
allow-nat-networks disable
allow-public-networks disable
local {
prefix 10.1.1.0/24
protocol gre
remote {
prefix 10.2.2.0/24
Router 2:
address 10.2.2.1/24
hw-id 0c:d0:6a:2e:00:00
address 192.51.100.2/24
hw-id 0c:d0:6a:2e:00:01
ethernet eth2 {
hw-id 0c:d0:6a:2e:00:02
loopback lo {
tunnel tun0 {
address 10.2.2.5/32
encapsulation gre
multicast enable
remote 203.0.113.2
source-address 192.51.100.2
protocols {
static {
route 0.0.0.0/0 {
next-hop 192.51.100.1 {
system {
config-management {
conntrack {
modules {
ftp
h323
nfs
pptp
sip
sqlnet
tftp
console {
device ttyS0 {
speed 115200
host-name remote-office-rtr
login {
user vyos {
authentication {
ntp {
syslog {
global {
facility all {
level info
level debug
vpn {
ipsec {
esp-group remote-rtr-esp {
compression disable
lifetime 1800
mode tunnel
pfs enable
proposal 1 {
encryption aes256
hash sha256
ike-group remote-rtr-ike {
close-action none
ikev2-reauth no
key-exchange ikev1
lifetime 3600
proposal 1 {
dh-group 2
encryption aes256
hash sha256
ipsec-interfaces {
interface eth1
site-to-site {
peer 203.0.113.2 {
authentication {
default-esp-group remote-rtr-esp
local-address 192.51.100.2
tunnel 0 {
local {
prefix 10.2.2.0/24
protocol gre
remote {
prefix 10.1.1.0/24
16again
February 4, 2022, 10:34pm
4
Your GRE interfaces have local /32 addresses. And you don’t have any route pointing over the vpn tunnel.
So no packet will ever be routed over vpn
Add interface route onto gre tunnel, or adjust gre tun0 addresses to be in the same /30 subnet.
Moreover, ipsec remote/local tunnel addresses should be local and remote gre tunnel addresses.
remote 203.0.113.2
Many thanks! Subnet /30 on tun0
and static routes corresponding subnets on the other side solved the problem. I am just wondering the purpose of /32 interfaces in GRE Over IPsec for Secure Tunneling : VyOS Support Portal …
system
Closed
February 7, 2022, 6:18am
6
