My /tmp mount gets full after less than 24 hours running. This prevents me from running many commands. Restarting the system clears everything out and gets everything working. But I can’t be restarting daily.
I removed all logging from all my firewall rule sets. But that didn’t help. I’m not sure where to look from here. I’m on vyos-1.4-rolling-202210150526-amd64. Here is some hopefully helpful output:
vyos@vyos:~$ monitor log
-vbash: cannot create temp file for here-document: No space left on device
Incomplete command: monitor log
vyos@vyos:~$ show version
Incomplete command: show version
vyos@vyos:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 1.7G 0 1.7G 0% /dev
tmpfs 339M 1.7M 337M 1% /run
/dev/sda3 117G 759M 110G 1% /usr/lib/live/mount/persistence
/dev/loop0 401M 401M 0 100% /usr/lib/live/mount/rootfs/1.4-rolling-202210150526.squashfs
tmpfs 1.7G 0 1.7G 0% /usr/lib/live/mount/overlay
overlay 117G 759M 110G 1% /
tmpfs 1.7G 0 1.7G 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 1.7G 1.7G 0 100% /tmp
tmpfs 1.7G 216K 1.7G 1% /var/tmp
none 1.7G 0 1.7G 0% /etc/cni/net.d
none 1.7G 1020K 1.7G 1% /opt/vyatta/config
unionfs-fuse 1.7G 1020K 1.7G 1% /opt/vyatta/config/tmp/new_config_7980
tmpfs 339M 0 339M 0% /run/user/1002
vyos@vyos:/tmp$ sudo du -cksh *
0 #102 (deleted)
20K config.boot.2934
20K config.boot.8206
8.0K dhcpd.conf
0 systemd-private-f2df832485c54876938f5280928f317b-haveged.service-HpwFTi
0 systemd-private-f2df832485c54876938f5280928f317b-ntp.service-zTJVVg
0 systemd-private-f2df832485c54876938f5280928f317b-pdns-recursor.service-oX4vyf
0 systemd-private-f2df832485c54876938f5280928f317b-systemd-logind.service-C6Wcki
4.0K vyos-configd-script-stdout
4.0K vyos-config-status
56K total
vyos@vyos:~$ sudo df --inodes -h
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 419K 328 419K 1% /dev
tmpfs 423K 601 423K 1% /run
/dev/sda3 7.5M 1.5K 7.5M 1% /usr/lib/live/mount/persistence
/dev/loop0 68K 68K 0 100% /usr/lib/live/mount/rootfs/1.4-rolling-202210150526.squashfs
tmpfs 423K 1 423K 1% /usr/lib/live/mount/overlay
overlay 7.5M 1.5K 7.5M 1% /
tmpfs 423K 1 423K 1% /dev/shm
tmpfs 423K 2 423K 1% /run/lock
tmpfs 423K 21 423K 1% /tmp
tmpfs 423K 51 423K 1% /var/tmp
none 423K 1 423K 1% /etc/cni/net.d
none 0 0 0 - /opt/vyatta/config
unionfs-fuse 0 0 0 - /opt/vyatta/config/tmp/new_config_7980
tmpfs 85K 17 85K 1% /run/user/1002
vyos@vyos:~$ free -mh
total used free shared buff/cache available
Mem: 3.3Gi 319Mi 951Mi 1.7Gi 2.1Gi 1.1Gi
Swap: 0B 0B 0B
