[Solved] Vyos 1.5 Final step settings up tunnelbroker connection, via: pppoe
I would be very happy if you could help me regarding the - hopefully tiny - final step towards completing the setup of an IPv6-tunnel via tunnelbroker. I run this tunnel since the year 2009 using various opensource routing platforms in the past. Currently it’s established via *Sense, a platform which I would like to replace against vyos, as soon as the tunnelbroker connection works.
I use vyos 1.5-nightly. These are the current settings:
#Tunnel settings:
vyos@vyos# show interfaces tunnel
 tunnel tun0 {
     address 2001:470:____:____::2/64
     description "HE.NET IPv6 Tunnel"
     encapsulation sit
     remote 216.66.xx.xx
     source-address 0.0.0.0
#Routing settings:
vyos@vyos# sho protocols static route6 ::/0
 next-hop 2001:470:____:____::1 {
     interface tun0
#Firewall settings:
vyos@vyos# show firewall ipv4
Configuration under specified path is empty
vyos@vyos# show firewall ipv6
vyos@vyos# show firewall global-options
 all-ping enable
 broadcast-ping disable
 ipv6-src-route disable
 ip-src-route disable
 log-martians enable
 send-redirects disable
 source-validation disable
 syn-cookies enable
With these settings the tunnel seems to be established fine, but ping6-ing works only partially:
  1. Pinging inside->out (LAN to IPv6-internet):
    1.1. ping6 from vyos to TB server IPv6 addr (2001:470:____:____::1/64) works fine.
    1.2. ping6 from clients to TB server IPv6 addr (2001:470:____:____::1/64) works fine, too.
    1.3. ping6 from vyos or clients to anywhere else (eg. 2001:470:20:1) doesn’t work.
  2. Pinging outside->in (IPv6-internet to LAN)
    2.1. ping6 from internet to the TB client IPv6 addr (2001:470:____:____::2/64) doesn’t work.
    2.1. ping6 from internet to internal addresses doesn’t work.
Some remarks regarding 2. (outside->in):
Using tcpdump on ppp0 and tun0 I can see the pings from outside arriving at pppoe0 and tun0:
Here is the output of ping and tcpdump (pppoe0 and tun0) while ping6ing from 2001:470:____:____::00c0:ffee to the TB client IPv6 addr (2001:470:____:____::2/64):
user@host:~$ ping 2001:470:____:____::2
PING 2001:470:____:____::2 (2001:470:____:____::2) 56 data bytes
^C
--- 2001:470:____:____::2 ping statistics ---
4 packets transmitted, 0 received, 100% packet loss, time 4075ms
tcpdump shows, that the ping at least arrives on pppoe0 …
vyos@vyos:~$ tcpdump -ni pppoe0 host 216.66.xx.xx
tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
listening on pppoe0, link-type LINUX_SLL (Linux cooked v1), snapshot length 262144 bytes
14:42:34.229947 IP 216.66.xx.xx > 62.xx.xx.228: IP6 2001:470:____:____::00c0:ffee > 2001:470:____:____::2: ICMP6, echo request, id 4937, seq 1, length 64
14:42:35.233426 IP 216.66.xx.xx > 62.xx.xx.228: IP6 2001:470:____:____::00c0:ffee > 2001:470:____:____::2: ICMP6, echo request, id 4937, seq 2, length 64
14:42:36.257615 IP 216.66.xx.xx > 62.xx.xx.228: IP6 2001:470:____:____::00c0:ffee > 2001:470:____:____::2: ICMP6, echo request, id 4937, seq 3, length 64
14:42:38.305652 IP 216.66.xx.xx > 62.xx.xx.228: IP6 2001:470:____:____::00c0:ffee > 2001:470:____:____::2: ICMP6, echo request, id 4937, seq 5, length 64
… as well as on tun0:
vyos@vyos:~$ tcpdump -ni tun0
listening on tun0, link-type RAW (Raw IP), snapshot length 262144 bytes
14:42:34.229947 IP6 2001:470:____:____::00c0:ffee > 2001:470:____:____::2: ICMP6, echo request, id 4937, seq 1, length 64
14:42:35.233426 IP6 2001:470:____:____::00c0:ffee > 2001:470:____:____::2: ICMP6, echo request, id 4937, seq 2, length 64
14:42:36.257615 IP6 2001:470:____:____::00c0:ffee > 2001:470:____:____::2: ICMP6, echo request, id 4937, seq 3, length 64
14:42:38.305652 IP6 2001:470:____:____::00c0:ffee > 2001:470:____:____::2: ICMP6, echo request, id 4937, seq 5, length 64
I can’t find the configuration error, and even worse I’m out of ideas - probably because I ran out of c0ffee and the delivery of new capsules/pakets is currently blocked. :wink:
Ohh no, there’s one last thing/idea:
During my investigations I stumbled over ip addr show’s output. It looks strange to me especially the interface sit0, which is DOWN.
Why is it down? Could this be the cause for the problems? Could it be an MTU issue? Questions over question … The most important for me is: How can I further debug the problem using vyos?
12: pppoe0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1492 qdisc fq_codel state UNKNOWN group default qlen 3
    link/ppp
    inet 62.____:____.228 peer 62.____:____.245/32 scope global pppoe0
    inet6 fe80::f531:____:____:cc1c/64 scope link
    inet6 fe80::a1f1:____:____:b6af peer fe80::c203:____:____:83fe/128 scope link
13: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
    link/sit 0.0.0.0 brd 0.0.0.0
14: tun0@NONE: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1476 qdisc noqueue state UNKNOWN group default qlen 1000
    link/sit 0.0.0.0 peer 216.66.xx.xx
    inet6 2001:470:____:____::2/64 scope global
    inet6 fe80::f0c7:____:____:1f71/64 scope link
Thank you very much for your assistance!
Best regards,
vyozzy
Ok, there seems to be no static IPv6 default route:
vyos@vyos# run sho log protocol static | grep tun0
Aug 18 13:53:05 RC1 staticd[1479]: [PNYPZ-BCP8Y] Static Route using tun0 interface not installed because the interface does not exist in specified vrf
More exact the IPv6 default route points to the interface pppoe0:
vyos@vyos# ip -6 route | grep default
default via fe80::c203:____:____:83fe dev pppoe0 proto ra metric 1024 expires 1336sec hoplimit 64 pref medium
This IPv6 routing table entry seems strange to me, especially because I’ve already disabled ipv6 forwarding for the interface pppoe0:
vyos@vyos# show interfaces pppoe pppoe0  | strip-private
 authentication {
     password xxxxxx
     username xxxxxx
 description "IPv4-ISP"
 ip {
     adjust-mss clamp-mss-to-pmtu
     source-validation strict
 ipv6 {
     disable-forwarding
 mtu 1492
 source-interface eth8
How to move the IPv6 default route from pppoe0 to tun0?
After removing the wrong IPv6 default route manually in the backend using good old sudo ip -6 route delete default a new IPv6 default route pointing to the TB Tunnel Server Endpoint spawned …
::C0ffee flows again :slight_smile: - but only for a relatively short period of time: After some seconds/minutes the IPv6 default route is pointing to pppoe0 again.
How do I get the IPv6 default route setup fixed to tun0 (while keep pointing the IPv4 default route to pppoe0) using native vyos setup commands?
Forget about it. After a reboot everything seems magically fine.
Addendum:
The error was the to me harmless seeming statement
set interfaces pppoe pppoe0 ipv6 disable-forwarding
In fact it seems to enable IPv6 (adds “+ipv6” to /etc/ppp/peers/pppoe0) to be able to disable IPv6 forwarding. :thinking:
