Hello Guys and Happy New Year.
I was wondering sompting strange if is possible
Ower nerwork has 2 ISP 2 Companys
I have a customer who have an vlan /29 assigned to hes dedicated server the think is he whants hes traffic from hes server to work only true ISP 1 and not both ISPs.
Is there a way a vlan or some ips hes traffic to go only true ISP 1 and not both ISPs ?
Thank you
You can use policy local route
set policy local-route rule 100 source 192.0.2.0/29
set policy local-route rule 100 set table 10
set protocols static table 10 route 0.0.0.0/0 next-hop ISP_1
At the ISP_1 is ASNumer ? Or BGP Session IP ? From each ISP we have 2 BGP Tables (National and GLobal)
Dose this work with an /32 ? for testing
ISP_1 ip address - gateway/isp/bgp/etc it is just the next hop via the desired isp
It works with any prefix BGP Example β VyOS 1.4.x (sagitta) documentation
Note the solutions posted only affect outgoing traffic, not incoming.
To do that, you need to advertise customer /29 network only on single link, but ISP probably wonβt allow smaller networks than /24
