Spoke hasn't learnt correct NBMA-Address for another cisco spoke when both spokes are behind the nat
Hi all,
i have found a problem with DMVPN: when both spokes are behind the NAT and one of the spokes is a Cisco router, VyOS hasn’t learnt the correct NBMA-Address for the Cisco router
my topology first
HUB is connected to the Internet through eth0 with a fixed public IP 207.148.116.a
Spoke1 is connected to a 1:1-NAT firewall through eth0 with the inside IP 10.65.138.33, and a fixed public IP 8.222.135.b NATed by the firewall.
Spoke2 is connected to the ISP through GigabitEthernet0/0/0 with an inside DHCP IP of 100.85.31.228 in this case. The public IP 103.252.202.c is one of the IPs in the ISP’s CGNAT pool.
DMVPN tunnel interface
  • HUB
    tun645170: 10.254.0.1/29
  • Spoke1
    tun645170: 10.254.0.2/29
  • Spoke2
    tun645170: 10.254.0.6/29
Platform and version
HUB is running VyOS with version VyOS 1.5-stream-2025-Q1
Spoke1 is running VyOS with version VyOS 1.4.0
Spoke2 is running Cisco IOS XE Software, Version 16.09.02
Phenomenon
Wait for the DMVPN and IPSEC to be established.
HUB ←→ Spoke1 can ping each other successfully.
HUB ←→ Spoke2 can ping each other successfully.
Spoke1 and Spoke2 CANNOT ping each other.
checked the NHRP table on each device, found that in Spoke1’s NHRP table, NBMA-Address of Spoke2 was not correct (it’s Spoke1 itself)
  • NHRP table on HUB (correct)
xxxxxx@hub:~$ show nhrp tunnel
Status: ok
Interface    Type     Protocol-Address    Alias-Address    Flags    NBMA-Address     NBMA-NAT-OA-Address    Expires-In
tun645170    local    10.254.0.7/32       10.254.0.1       up
tun645170    local    10.254.0.1/32                        up
tun645170    dynamic  10.254.0.6/32                        used up  103.252.202.c    100.85.31.228          6:46
tun645170    dynamic  10.254.0.2/32                        up       8.222.135.b      10.65.138.33           115:58
xxxxxx@hub:~$
  • NHRP table on Spoke1 (not correct)
xxxxxx@spoke1:~$ show nhrp tunnel
Status: ok
tun645170    local   10.254.0.7/32       10.254.0.2       up
tun645170    local   10.254.0.2/32                        up
tun645170    cached  10.254.0.6/32                        up       8.222.135.b     100.85.31.228          7:25
tun645170    static  10.254.0.1/29                        used up  207.148.116.a
xxxxxx@spoke1:~$
Here’s the problem: the NBMA-Address of 10.254.0.6/32 should be the same as the HUB’s 103.252.202.c, but actually, it is the NATed public IP address of itself
  • NHRP table on Spoke2 (correct)
spoke2#show dmvpn detail
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
        N - NATed, L - Local, X - No Socket
        T1 - Route Installed, T2 - Nexthop-override
        C - CTS Capable, I2 - Temporary
        # Ent --> Number of NHRP entries with same NBMA peer
        NHS Status: E --> Expecting Replies, R --> Responding, W --> Waiting
        UpDn Time --> Up or Down Time for a Tunnel
Interface Tunnel645170 is up/up, Addr. is 10.254.0.6, VRF ""
   Tunnel Src./Dest. addr: 100.85.31.228/Multipoint, Tunnel VRF ""
   Protocol/Transport: "multi-GRE/IP", Protect "ipsec-transport-aes256"
   Interface State Control: Disabled
   nhrp event-publisher : Disabled
IPv4 NHS:
10.254.0.1  RE NBMA Address: 207.148.116.a  priority = 0 cluster = 0
Type:Spoke, Total NBMA Peers (v4/v6): 5
# Ent  Peer NBMA Addr Peer Tunnel Add State  UpDn Tm Attrb    Target Network
    1 207.148.116.a        10.254.0.1    UP 02:30:04     S      10.254.0.1/32
    1 8.222.135.b          10.254.0.2    UP 17:37:25    DN      10.254.0.2/32
               Claimed Addr. 10.65.138.33
    1 100.85.31.228        10.254.0.6    UP 02:30:19   DLX      10.254.0.6/32
Crypto Session Details:
Interface: Tunnel645170
Session: [0x7F782B37E0]
  Session ID: 76
  IKEv2 SA: local 100.85.31.228/4500 remote 207.148.116.a /4500 Active
          Capabilities:DN connid:8 lifetime:02:53:47
  Crypto Session Status: UP-ACTIVE
  fvrf: (none), Phase1_id: 207.148.116.a
  IPSEC FLOW: permit 47 host 100.85.31.228 host 207.148.116.a
        Active SAs: 2, origin: crypto map
        Inbound:  #pkts dec'ed 20366 drop 0 life (KB/Sec) 4607807/962
        Outbound: #pkts enc'ed 10231 drop 0 life (KB/Sec) 4607870/962
   Outbound SPI : 0xC5BCDA0F, transform : esp-256-aes esp-sha-hmac
    Socket State: Open
Session: [0x7F782B3AE0]
  Session ID: 88
  IKEv2 SA: local 100.85.31.228/4500 remote 8.222.135.b /4500 Active
          Capabilities:DN connid:9 lifetime:06:12:13
  fvrf: (none), Phase1_id: 10.65.138.33
  IPSEC FLOW: permit 47 host 100.85.31.228 host 8.222.135.b
        Inbound:  #pkts dec'ed 0 drop 0 life (KB/Sec) 4608000/1126
        Outbound: #pkts enc'ed 77 drop 0 life (KB/Sec) 4607999/1126
   Outbound SPI : 0xCA1C038A, transform : esp-256-aes esp-sha-hmac
    Socket State: Open
Pending DMVPN Sessions:
spoke2#
  • vpn ipsec table on HUB (correct)
xxxxxxx@hub:~$ show vpn ipsec sa
Connection    State    Uptime    Bytes In/Out    Packets In/Out    Remote address    Remote ID              Proposal
dmvpn         up       35m41s    18K/59K         240/519           8.222.135.b       10.65.138.33           AES_CBC_256/HMAC_SHA1_96/MODP_1024
dmvpn         up       49s       540B/1K         5/17              103.252.202.c     gateway.sg.home.ipsec  AES_CBC_256/HMAC_SHA1_96/MODP_1024
xxxxxxx@hub:~$
  • vpn ipsec table on Spoke1 (not correct)
xxxxxx@spoke1:~$ show vpn ipsec sa
dmvpn         up       1m10s     0B/0B           0/0               103.252.202.c     gateway.sg.home.ipsec  AES_CBC_256/HMAC_SHA1_96/MODP_1024
dmvpn         up       37m27s    0B/2M           0/21K             8.222.135.b       10.65.138.33           AES_CBC_256/HMAC_SHA1_96/MODP_1024
dmvpn         up       37m27s    2M/0B           21K/0             8.222.135.b       10.65.138.33           AES_CBC_256/HMAC_SHA1_96/MODP_1024
dmvpn         up       38m3s     63K/19K         553/256           207.148.116.a     207.148.116.a          AES_CBC_256/HMAC_SHA1_96/MODP_1024
xxxxxx@spoke1:~$
Here’s another problem: because the DMVPN did not obtain the correct NBMA-Address of Spoke2 and used its own NATed IP address instead, IPSec ended up establishing the connection with Spoke1 itself.
  • crypto session on Spoke2 (correct)
spoke2# show crypto session
Crypto session current status
Profile: ikev2-nat-any
Session status: UP-ACTIVE
Peer: 8.222.135.b  port 4500
  Session ID: 88
Peer: 207.148.116.a  port 4500
  Session ID: 76
spoke2#
Configurations
  • HUB
         address dhcp
     tunnel tun645170 {
         address 10.254.0.1/29
         enable-multicast
         encapsulation gre
         mtu 1472
         parameters {
             ip {
                 key 645170
         source-interface eth0
 protocols {
     nhrp {
         tunnel tun645170 {
             multicast dynamic
             redirect
             shortcut
 vpn {
     ipsec {
         esp-group transport-aes256-sha1 {
             lifetime 3600
             mode transport
             pfs dh-group2
             proposal 1 {
                 encryption aes256
                 hash sha1
         ike-group ikev2-aes256-sha1 {
             close-action none
             dead-peer-detection {
                 action clear
                 interval 10
                 timeout 50
             ikev2-reauth
             key-exchange ikev2
             lifetime 28800
             proposal 1 {
                 dh-group 2
                 encryption aes256
                 hash sha1
         interface eth0
         log {
             level 1
             subsystem mgr
             subsystem ike
             subsystem chd
             subsystem knl
             subsystem net
             subsystem dmn
         options {
             disable-route-autoinstall
         profile sg-dmvpn {
             authentication {
                 mode pre-shared-secret
                 pre-shared-secret xxxxxxxx
             bind {
                 tunnel tun645170
  • Spoke1
         address dhcp
         description [WAN]8.222.135.b
         hw-id 00:16:3e:10:17:57
         offload {
             gro
             gso
     tunnel tun645170 {
         address 10.254.0.2/29
         enable-multicast
         encapsulation gre
         mtu 1472
         parameters {
             ip {
                 key 645170
 protocols {
     nhrp {
         tunnel tun645170 {
             map 10.254.0.1/29 {
                 nbma-address 207.148.116.a
                 register
             multicast nhs
             redirect
             shortcut
 vpn {
     ipsec {
             lifetime 3600
             mode transport
             pfs dh-group2
             proposal 1 {
                 encryption aes256
                 hash sha1
             close-action none
                 action clear
                 interval 10
             key-exchange ikev2
             lifetime 28800
             proposal 1 {
                 dh-group 2
                 encryption aes256
                 hash sha1
         interface eth0
         log {
             level 1
             subsystem mgr
             subsystem ike
             subsystem chd
             subsystem knl
             subsystem net
             subsystem dmn
         options {
         profile sg-dmvpn {
             authentication {
             bind {
                 tunnel tun645170
  • Spoke2
Current configuration : 12635 bytes
! Last configuration change at 18:58:50 SIN Sat Nov 8 2025 by wolf
! NVRAM config last updated at 18:24:21 SIN Thu Nov 6 2025 by wolf
version 16.9
crypto ikev2 proposal AES256-SHA1-MODP1024
 encryption aes-cbc-256
 integrity sha1
 group 2
crypto ikev2 proposal AES256-SHA256-MODP1024
 integrity sha256
 group 2
crypto ikev2 policy AES256-SHA1-MODP1024
crypto ikev2 policy sg-dmvpn
crypto ikev2 keyring sg-dmvpn
 peer hub-sg-vultr
  pre-shared-key xxxxxxxx
 peer spoke-sg-ali
  address 8.222.135.b
crypto ikev2 profile ikev2-nat-any
 match identity remote any
 identity local fqdn gateway.sg.home.ipsec
 authentication remote pre-share
 authentication local pre-share
 keyring local sg-dmvpn
 lifetime 28800
 no lifetime certificate
 dpd 10 3 periodic
 nat keepalive 5
 nat force-encap
crypto ipsec transform-set TRANSPORT-ESP-AES256-SHA1 esp-aes 256 esp-sha-hmac
 mode transport
crypto ipsec df-bit clear
crypto ipsec profile ipsec-transport-aes256
 set transform-set TRANSPORT-ESP-AES256-SHA1
 set pfs group2
interface Tunnel645170
 ip address 10.254.0.6 255.255.255.248
 no ip redirects
 ip nhrp network-id 645170
 ip nhrp nhs 10.254.0.1 nbma 207.148.116.a  multicast
 ip nhrp redirect
 ip ospf network broadcast
 tunnel source GigabitEthernet0/0/0
 tunnel mode gre multipoint
 tunnel key 645170
 tunnel protection ipsec profile ipsec-transport-aes256 ikev2-profile ikev2-nat-any
interface GigabitEthernet0/0/0
 description WAN
 ip dhcp client default-router distance 10
 ip address dhcp
 ip nat outside
 negotiation auto
At the end
I’m not sure whether this issue is a bug or a misconfiguration on my part. It has been bothering me for several days. If anyone has experienced something similar, I would really appreciate your guidance.
Feel free to leave any comment; it will be helpful to me. Kindly let me know if you need something!
Thank you!
Regards,
Nicolas
update:
tried to upgrade to VyOS 1.5-stream-2025-Q2, wasn’t resolve the problem.
i got some logs by running the command “monitor log nhrp” on both HUB and Spoke1
  • Logs from Spoke1
xxxxxxxx@spoke1:~$ monitor log nhrp
Nov 11 01:09:24 opennhrp[129238]: NL-ARP(tun645170) who-has 10.254.0.6
Nov 11 01:09:24 opennhrp[129238]: NL-ARP(tun645170) 10.254.0.6 is-at 207.148.116.a
Nov 11 01:09:24 opennhrp[129238]: Adding incomplete 10.254.0.6/32 dev tun645170
Nov 11 01:09:24 opennhrp[129238]: Sending Resolution Request to 10.254.0.6
Nov 11 01:09:24 opennhrp[129238]: Sending packet 1, from: 10.254.0.2 (nbma 10.65.138.33), to: 10.254.0.6 (nbma 207.148.116.a)
Nov 11 01:09:24 opennhrp[129238]: Traffic Indication from proto src 10.254.0.1; about packet to 10.254.0.6
Nov 11 01:09:24 opennhrp[129238]: Received Resolution Reply 10.254.0.6/32 is at proto 10.254.0.6 nbma 100.85.31.228 (code 0)
Nov 11 01:09:24 opennhrp[129238]: NAT detected: really at proto 10.254.0.2 nbma 8.222.135.b
Nov 11 01:09:24 opennhrp-script.py[138387]: Running script with arguments: ['/etc/opennhrp/opennhrp-script.py', 'peer-up'], environment: environ({'NHRP_TYPE': 'cached', 'NHRP_SRCADDR': '10.254.0.2', 'NHRP_SRCNBMA': '10.65.138.33', 'NHRP_DESTADDR': '10.254.0.6', 'NHRP_DESTPREFIX': '32', 'NHRP_DESTNBMA': '8.222.135.b', 'NHRP_DESTMTU': '9972', 'NHRP_DESTNBMA_NAT_OA': '100.85.31.228', 'NHRP_INTERFACE': 'tun645170', 'NHRP_GRE_KEY': '645170', 'LC_CTYPE': 'C.UTF-8'})
Nov 11 01:09:24 opennhrp-script.py[138387]: Peer UP event for spoke using IKE profile dmvpn-sg-dmvpn-tun645170
Nov 11 01:09:24 opennhrp-script.py[138387]: NBMA addresses: local 10.65.138.33, remote 8.222.135.b
Nov 11 01:09:24 opennhrp-script.py[138387]: Adding route from 10.65.138.33 to 8.222.135.b with MTU 9972
Nov 11 01:09:25 opennhrp-script.py[138387]: Terminating IKE connection dmvpn-sg-dmvpn-tun645170 between 10.65.138.33 and 8.222.135.b
Nov 11 01:09:25 opennhrp-script.py[138387]: Resolving IKE unique ids for: conn: dmvpn-sg-dmvpn-tun645170, src_nbma: 10.65.138.33, dst_nbma: 8.222.135.b
Nov 11 01:09:25 opennhrp-script.py[138387]: No active sessions found for IKE profile dmvpn-sg-dmvpn-tun645170, local NBMA 10.65.138.33, remote NBMA 8.222.135.b
Nov 11 01:09:25 opennhrp-script.py[138387]: Trying to initiate connection. Name: dmvpn-sg-dmvpn-tun645170, child sa: dmvpn, src_addr: 10.65.138.33, dst_addr: 8.222.135.b
Nov 11 01:09:25 opennhrp[129238]: [10.254.0.6] Peer up script: success
Nov 11 01:09:25 opennhrp[129238]: NL-ARP(tun645170) 10.254.0.6 is-at 8.222.135.b
here’s the problem, the last line in the log:
why opennhrp thought 10.254.0.6 is-at 8.222.135.b
actually from line “Nov 11 01:09:24 opennhrp-script.py[138387]” opennhrp ran the script “opennhrp-script.py” and pass the parameter: ‘NHRP_DESTNBMA’: ‘8.222.135.b’ was wrong already.
  • Logs from HUB
Nov 11 01:09:14 opennhrp[183768]: Multicast from 10.254.0.1 to 224.0.0.5
Nov 11 01:09:24 opennhrp[183768]: Multicast from 10.254.0.1 to 224.0.0.5
Nov 11 01:09:24 opennhrp[183768]: Forwarding packet from nbma src 10.65.138.33, proto src 10.254.0.2 to proto dst 10.254.0.6, hop count 16
Nov 11 01:09:24 opennhrp[183768]: Sending packet 1, from: 10.254.0.2 (nbma 10.65.138.33), to: 10.254.0.6 (nbma 103.252.202.c)
Nov 11 01:09:24 opennhrp[183768]: Sending Traffic Indication about packet from 10.254.0.2 to 10.254.0.6 (to 10.254.0.2/8.222.135.b)
Nov 11 01:09:24 opennhrp[183768]: Sending packet 8, from: 10.254.0.1 (nbma 207.148.116.30), to: 10.254.0.2 (nbma 8.222.135.b)
Nov 11 01:09:25 opennhrp[183768]: NL-ARP(tun645170) who-has 10.254.0.6
Nov 11 01:09:25 opennhrp[183768]: NL-ARP(tun645170) 10.254.0.6 is-at 103.252.202.c
Nov 11 01:09:34 opennhrp[183768]: Multicast from 10.254.0.1 to 224.0.0.5
Nov 11 01:09:44 opennhrp[183768]: Multicast from 10.254.0.1 to 224.0.0.5
Nov 11 01:09:54 opennhrp[183768]: Multicast from 10.254.0.1 to 224.0.0.5
Nov 11 01:09:55 opennhrp[183768]: NL-ARP(tun645170) who-has 10.254.0.6
Nov 11 01:09:55 opennhrp[183768]: NL-ARP(tun645170) 10.254.0.6 is-at 103.252.202.c
Nov 11 01:10:04 opennhrp[183768]: Multicast from 10.254.0.1 to 224.0.0.5
Nov 11 01:10:14 opennhrp[183768]: Multicast from 10.254.0.1 to 224.0.0.5
Nov 11 01:10:22 opennhrp[183768]: NL-ARP(tun645170) who-has 10.254.0.6
Nov 11 01:10:22 opennhrp[183768]: NL-ARP(tun645170) 10.254.0.6 is-at 103.252.202.c
Nov 11 01:10:24 opennhrp[183768]: Multicast from 10.254.0.1 to 224.0.0.5
Nov 11 01:10:34 opennhrp[183768]: Multicast from 10.254.0.1 to 224.0.0.5
Nov 11 01:10:44 opennhrp[183768]: Multicast from 10.254.0.1 to 224.0.0.5
from the log we can see the hub has responded with the correct NBMA-Address for Spoke2
I’ve no idea about this, totally.
opennhrp has passed the wrong arguments ‘NHRP_DESTNBMA’: ‘8.222.135.b’ to the script “opennhrp-script.py”, and it incorrectly established the ipsec connection with itself.
the key is, why opennhrp takes the wrong NBMA-Address, even the hub responded with the correct one?
Finally, I found that it is an OpenNHRP issue, guess Cisco has upgraded their DMVPN protocol, appended more CIE to the CIE list.
Anyway now I still need the DMVPN by OpenNHRP, so I created a bug fix merge request to the original repo
awolfnet / OpenNHRP - Code / Commit [d6325d]
We do not plan to use OpenNHRP in the future, as we encountered numerous bugs in it. We migrated to FRR NHRP in rolling and VyOS Stream 2025.11. There are some differences in using NHRP. You can find more information about it in our documentation.
