SSH connection refused
Hi
I’m trying to get ssh running on my vyos router. But everytime i try to connect, i get an connection refused error.
The first problem was i wasn’t able to bind the ssh service to an vif interface. So i have to set
sudo sysctl -w net.ipv4.ip_nonlocal_bind=1
After that i was able to set the address to this interface eth3.1606 and the ssh service was comming up and is listening on this address…
vyos@VyOS-SPOKE-01:~$ netstat -tulpn | grep 22
(No info could be read for “-p”: geteuid()=1003 but you should be root.)
tcp 0 0 10.2.140.1:22 0.0.0.0:* LISTEN -
Interface Configuration:
And then if i’m trying to get a connection on this interface i will get a connection refused.
With tcpdump port 22 i don’t see any connections :frowning:
Edit: i’m currently running 1.3-rolling-202004220702
Maybe anyone of you have a hint for me :smiley:
Kind regards
Kevin
set service ssh listen-address <IPOFYOURVIF> works just fine for me.
@pirateghost Thank you for your reply!
Something i forget to say is that i also use vrf…
set interfaces ethernet eth1 vif 600 address '10.2.140.1/24'
set interfaces ethernet eth1 vif 600 description 'mgmt-network'
set interfaces ethernet eth1 vif 600 vrf 'Mgmt'
Just now i tried to remove the vrf option and it works!
But maybe you or someone else have an idea why this is not working with the vrf option?
I think i have to route/forward the incoming traffic in interface eth1.600 to the SSH Daemon or something like this…
Or is there a way in SSH to listen on an interface which is in a diffrent routing table?
Sorry, I am not familiar with VRF
Try this one:
set vrf bind-to-all
Hi @g.skupien
Thank you very much for your reply!
Now it works :slight_smile: great!
I overread this in the documentation :stuck_out_tongue:
But one more thing, you need to set this
Binding to Non-local IP addresses in Linux permanently
Create the file:
sudo vi /etc/sysctl.d/99-custom.conf
Add the following lines:
## allow System Services to start and bind to non local IP ##
Apply it:
sudo sysctl -f /etc/sysctl.d/99-custom.conf
Copied from:
https://www.cyberciti.biz/faq/linux-bind-ip-that-doesnt-exist-with-net-ipv4-ip_nonlocal_bind/
Maybe the documentation should be expanded with this…
Kind regards
Kevin
