SSHd does not load on boot, I have to connect to the console and start it with /usr/sbin/sshd
I also am not able to connect to the hosts using ipv6 even when the addresses are specified in listen-address. when I run netstat -pnl|grep ssh, the address listed is only the first 2 numbers of the last hextet
set service ssh listen address 10.255.255.233
set service ssh listen address fd00:feed:beef:3::233
set service ssh port 22
sudo netstat -pnl|grep ssh
tcp 0 0 10.255.255.233:22 0.0.0.0:* LISTEN 5259/sshd
tcp6 0 0 fd00:feed:beef:3::23:22 :::* LISTEN 5259/sshd
netstat
