SSH in VRF fails after reboot
Running 1.4-rolling-202101120217
Have a mgmt vrf configured with a vif attached. Setup ssh with port 22 and vrf mgmt. After doing a commit, I can access the router without issue. Doing a reboot then trying to access router gives a connection refused.
Added the vrf bind-all option and still cannot access after a commit or reboot.
Delete the ssh vrf item, commit, add ssh vrf, commit and now I can access again.
Known bug that I just did not find in a search or new?
Actually, in order to regain ssh access, the entire “service ssh” section hsa to be deleted then re added.
It’s a bug in the render() function it seems, tracked via ⚓ T3212 SSH: configuration directory is not always created on boot
Thank you…
Anything I can do to help test, let me know.
This one will be fixed in the 1.3 beta version from tomorrow - easy fix, nasty error.
I can confirm that this is fixed.
