Hi All,
i have setup my public key in vyos and verified i can connect no problems without a password and run commands no problem
but whenever i try to run a command remotely, im getting Invalid command and im not sure why?
PS C:\Users\sas_2\Documents\Developer\talos> ssh vyos@217.123.123.123 “show ip bgp”
Invalid command: [show]PS C:\Users\sas_2\Documents\Developer\talos> ssh vyos@217.123.123.123
Welcome to VyOS!Check out project news at https://blog.vyos.io
and feel free to report bugs at https://vyos.devYou can change this banner using “set system login banner post-login” command.
VyOS is a free software distribution that includes multiple components,
you can check individual component licenses under /usr/share/doc/*/copyright
Last login: Mon Jul 3 11:20:04 2023 from 192.168.251.169vyos@vyos:~$ show ip bgp
BGP table version is 77, local router ID is 192.168.251.254, vrf id 0
Default local pref 100, local AS 65000
Nexthop codes: @NNN nexthop’s vrf id, < announce-nh-self
RPKI validation codes: V valid, I invalid, N Not foundNetwork Next Hop Metric LocPrf Weight Path*>i192.168.251.251/32
192.168.251.101 100 0 i
*=i 192.168.251.102 100 0 i
*=i 192.168.251.103 100 0 i
*>i217.123.123.124/32 192.168.251.104 100 0 i
*=i 192.168.251.105 100 0 i
*=i 192.168.251.106 100 0 i
*>i217.123.123.125/32 192.168.251.106 100 0 iDisplayed 3 routes and 7 total paths
vyos@vyos:~$
