Hello all, My appologies for my lack of experience with the edgerouter brand. I may confuse the names of the software packages being used by the edgerouter for it’s routing functionality. I believe that vyatta is the software router that the edgrouter pro series uses at least. If not then please find and replace the ‘vyatta’ with whatever does.
First my hardware setup.
I have an edge pro (unning v1.9.7+hotfix.3) connected to a meraki mx84 using an sfp cable from port #7 on the edgrouter to port #12 on the meraki.
I have the meraki configured to use ip 10.192.192.193 on port #12 and the edgerouter configured to use 10.192.192.194 on port # 7. Both are static ips.
I have a static route on the meraki that points 192.168.2.1 at 10.192.192.194 as the next hop.
On the edge router I have configured the web interface to point 10.64.0.0/16 to next hop via 10.192.192.193.
However I cannot ping a known host even with no firewalling between the two networks.
I have reduced my issue down to the following:
When I configure the routes via the web interface or using the vyatta command line tools the routes are defined in the kernel as such:
ubnt@ubnt# configure
set protocols static route 10.64.0.0/16 next-hop 10.192.192.193
commit
save
exit
ubnt@ubnt# ip route show table main
default via 172.3.1.105 dev eth0 proto zebra
10.64.0.0/16 dev eth7 proto zebra
10.192.192.192/28 dev eth7 proto zebra
10.192.192.194 dev eth7 proto kernel scope link
172.3.1.104/29 dev eth0 proto kernel scope link
192.168.1.0/24 dev eth1 proto kernel scope link src 192.168.1.1
192.168.2.0/24 dev eth2 proto kernel scope link src 192.168.2.1
However when I use the command: “ip route add” the route table looks like:
ubnt@ubnt# ip route add 10.192.192.192/28 dev eth7
ubnt@ubnt# ip route add 10.64.0.0/16 via 10.192.192.193 dev eth7
10.192.192.192/28 dev eth7 scope link
When the 10.64.0.0/16 route is configured in the kernel and not via vyatta I am able to ping a host on the 10.64.0.0/16 network from the 192.168.2.0/24 network.
If I use the route created by vyatta you can see that the kernel does not know about the next hop gateway and the ping does not work. The packets incorrectly seem to be routed to the default gateway.
Why doesn’t vyatta correctly add the next hop gateway to the route in the edgerouter kernel route table?
Here you can see I have left the static route in the kernel for 10.64.0.0/16 and created a new route for 10.128.0.0/16 using vyatta configure command. I can ping addresses in the 10.64.0.0/16 range from 192.168.2.0/24 but I cannot ping addresses in the 10.128.0.0/16 range.
ubnt@ubnt:~$ ip route show
10.128.0.0/16 dev eth7 proto zebra
ubnt@ubnt:~$ show ip route
Codes: K - kernel, C - connected, S - static, R - RIP, B - BGP
O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
- selected route, * - FIB route, p - stale info
IP Route Table for VRF “default”
S *> 0.0.0.0/0 [1/0] via 172.3.1.105, eth0
K * 10.64.0.0/16 [0/0] via 10.192.192.193 inactive
S *> 10.128.0.0/16 [1/0] via 10.192.192.193 (recursive is directly connected, eth7) )
K *> 10.192.192.192/28 [0/0] is directly connected, eth7
C *> 10.192.192.194/32 is directly connected, eth7
C *> 127.0.0.0/8 is directly connected, lo
C *> 172.3.1.104/29 is directly connected, eth0
Any ideas would be helpful. Thank you!
