Hi. I’m not sure if I’ve encountered a bug or just a missetup by me.
I have multiple bridge interfaces with STP enabled, connecting two physical links with multiple VIFs:
bridge br100 {
address 192.xx/24
description xx
priority 10000
stp true
bridge br101 {
address 10.xx/24
description xx
priority 10000
stp true
ethernet eth5 {
duplex auto
hw-id xx
smp-affinity auto
speed auto
vif 100 {
bridge-group {
bridge br100
vif 101 {
bridge-group {
bridge br101
ethernet eth6 {
duplex auto
hw-id xx
smp-affinity auto
speed auto
vif 100 {
bridge-group {
bridge br100
vif 101 {
bridge-group {
bridge br101
each of the ports eth5, eth6 is connected to a switch (Cisco SF300) with MSTP and one instance per VLAN, priorities on all of them 28672. The switches are connected together with a single trunk link. Edge ports are enabled on all access ports and disabled on the two ports connected to the vyos. The goal is to disable the inter-switch link by default, and enable it if either uplink to vyos dies.
This all works if the inter-switch link is disconnected, but as soon as it’s connected (after the forwarding delay) there is a loop on all VLANs.
The problem as I see it is, the switches arent detecting the root bridge on vyos:
|Bridge ID:|28672-08:d0:9f:af:96:85|
|Root Bridge ID:|28672-08:d0:9f:af:96:85|
The root bridge should be the bridges on vyos, which is 10000. So the switches can’t see it as far as I can see.
Originally I tried to create a bridge of the physical eth’s first, then vifs on that bridge (that would be simpler), but there’s no configuration command to add vif’s on a bridge.
I’d be happy if anyone could contribute any troubleshooting ideas.
