Hey folks!
I’m using VyOS since a while now and started using Github Copilot, when I noticed that the SSL handshake gets stuck from any clients behind SNAT.
When requesting the endpoint directly from the router, it just works; same as with an OpenWRT based router.
I’m wondering if this is a VyOS bug or I have something strange in my configuration.
It’s fairy basic, a PPPoE for my local ISP upstream, SNAT for IPv4 and a prefix delegation for IPv6 (attached at the bottom).
Here’s a traffic capture I have from running curl -v -XPOST https://copilot-proxy.githubusercontent.com/v1/engines/copilot-code on one of the client hosts:
xvzf@apu6b4:~$ tcpdump -i any -vv host 20.250.85.194 | grep -v eth3
tcpdump: data link type LINUX_SLL2
tcpdump: listening on any, link-type LINUX_SLL2 (Linux cooked v2), snapshot length 262144 bytes
192.168.0.104.50369 > 20.250.85.194.https: Flags [S], cksum 0xfd03 (correct), seq 1561756951, win 65535, options [mss 1460,nop,wscale 6,nop,nop,TS val 2652161900 ecr 0,sackOK,eol], length 0
15:51:05.153387 br0 In IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 64)
15:51:05.153636 pppoe0 Out IP (tos 0x0, ttl 63, id 0, offset 0, flags [DF], proto TCP (6), length 64)
p579dc6b4.dip0.t-ipconnect.de.50369 > 20.250.85.194.https: Flags [S], cksum 0x9fc2 (correct), seq 1561756951, win 65535, options [mss 1460,nop,wscale 6,nop,nop,TS val 2652161900 ecr 0,sackOK,eol], length 0
15:51:05.169419 pppoe0 In IP (tos 0x0, ttl 49, id 0, offset 0, flags [DF], proto TCP (6), length 60)
20.250.85.194.https > p579dc6b4.dip0.t-ipconnect.de.50369: Flags [S.], cksum 0x45ba (correct), seq 3797559195, ack 1561756952, win 65160, options [mss 1440,sackOK,TS val 2181095567 ecr 2652161900,nop,wscale 7], length 0
15:51:05.169616 br0 Out IP (tos 0x0, ttl 48, id 0, offset 0, flags [DF], proto TCP (6), length 60)
20.250.85.194.https > 192.168.0.104.50369: Flags [S.], cksum 0xa2fb (correct), seq 3797559195, ack 1561756952, win 65160, options [mss 1440,sackOK,TS val 2181095567 ecr 2652161900,nop,wscale 7], length 0
192.168.0.104.50369 > 20.250.85.194.https: Flags [.], cksum 0xc820 (correct), seq 1, ack 1, win 2052, options [nop,nop,TS val 2652161924 ecr 2181095567], length 0
15:51:05.174529 br0 In IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 52)
15:51:05.174738 pppoe0 Out IP (tos 0x0, ttl 63, id 0, offset 0, flags [DF], proto TCP (6), length 52)
p579dc6b4.dip0.t-ipconnect.de.50369 > 20.250.85.194.https: Flags [.], cksum 0x6adf (correct), seq 1, ack 1, win 2052, options [nop,nop,TS val 2652161924 ecr 2181095567], length 0
192.168.0.104.50369 > 20.250.85.194.https: Flags [P.], cksum 0xc18a (correct), seq 1:346, ack 1, win 2052, options [nop,nop,TS val 2652161929 ecr 2181095567], length 345
15:51:05.180398 br0 In IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 397)
15:51:05.180604 pppoe0 Out IP (tos 0x0, ttl 63, id 0, offset 0, flags [DF], proto TCP (6), length 397)
p579dc6b4.dip0.t-ipconnect.de.50369 > 20.250.85.194.https: Flags [P.], cksum 0x6449 (correct), seq 1:346, ack 1, win 2052, options [nop,nop,TS val 2652161929 ecr 2181095567], length 345
15:51:05.195859 pppoe0 In IP (tos 0x0, ttl 49, id 39376, offset 0, flags [DF], proto TCP (6), length 52)
20.250.85.194.https > p579dc6b4.dip0.t-ipconnect.de.50369: Flags [.], cksum 0x6f70 (correct), seq 1, ack 346, win 507, options [nop,nop,TS val 2181095593 ecr 2652161929], length 0
15:51:05.196052 br0 Out IP (tos 0x0, ttl 48, id 39376, offset 0, flags [DF], proto TCP (6), length 52)
20.250.85.194.https > 192.168.0.104.50369: Flags [.], cksum 0xccb1 (correct), seq 1, ack 346, win 507, options [nop,nop,TS val 2181095593 ecr 2652161929], length 0
15:51:05.198145 pppoe0 In IP (tos 0x0, ttl 49, id 39379, offset 0, flags [DF], proto TCP (6), length 729)
20.250.85.194.https > p579dc6b4.dip0.t-ipconnect.de.50369: Flags [P.], cksum 0x058b (correct), seq 2897:3574, ack 346, win 507, options [nop,nop,TS val 2181095596 ecr 2652161929], length 677
15:51:05.198349 br0 Out IP (tos 0x0, ttl 48, id 39379, offset 0, flags [DF], proto TCP (6), length 729)
20.250.85.194.https > 192.168.0.104.50369: Flags [P.], cksum 0x62cc (correct), seq 2897:3574, ack 346, win 507, options [nop,nop,TS val 2181095596 ecr 2652161929], length 677
192.168.0.104.50369 > 20.250.85.194.https: Flags [.], cksum 0x6349 (correct), seq 346, ack 1, win 2052, options [nop,nop,TS val 2652161950 ecr 2181095593,nop,nop,sack 1 {2897:3574}], length 0
15:51:05.200615 br0 In IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 64)
15:51:05.200818 pppoe0 Out IP (tos 0x0, ttl 63, id 0, offset 0, flags [DF], proto TCP (6), length 64)
p579dc6b4.dip0.t-ipconnect.de.50369 > 20.250.85.194.https: Flags [.], cksum 0x0608 (correct), seq 346, ack 1, win 2052, options [nop,nop,TS val 2652161950 ecr 2181095593,nop,nop,sack 1 {2897:3574}], length 0
15:51:06.190967 pppoe0 In IP (tos 0x0, ttl 49, id 39383, offset 0, flags [DF], proto TCP (6), length 52)
20.250.85.194.https > p579dc6b4.dip0.t-ipconnect.de.50369: Flags [F.], cksum 0x5d82 (correct), seq 3574, ack 346, win 507, options [nop,nop,TS val 2181096588 ecr 2652161950], length 0
15:51:06.191162 br0 Out IP (tos 0x0, ttl 48, id 39383, offset 0, flags [DF], proto TCP (6), length 52)
20.250.85.194.https > 192.168.0.104.50369: Flags [F.], cksum 0xbac3 (correct), seq 3574, ack 346, win 507, options [nop,nop,TS val 2181096588 ecr 2652161950], length 0
192.168.0.104.50369 > 20.250.85.194.https: Flags [.], cksum 0x5efe (correct), seq 346, ack 1, win 2052, options [nop,nop,TS val 2652163048 ecr 2181095593,nop,nop,sack 1 {2897:3575}], length 0
15:51:06.299722 br0 In IP (tos 0x0, ttl 64, id 0, offset 0, flags [DF], proto TCP (6), length 64)
15:51:06.299927 pppoe0 Out IP (tos 0x0, ttl 63, id 0, offset 0, flags [DF], proto TCP (6), length 64)
interface pppoe0 {
bridge br0 {
address 192.168.0.1/24
address fd00:b4d:c0fe::1/64
description lan
disable-link-detect
member {
interface eth2 {
interface eth3.100 {
description WAN
hw-id 00:0d:b9:60:37:20
vif 7 {
description WAN_dtag.vlan7
hw-id 00:0d:b9:60:37:21
ethernet eth2 {
hw-id 00:0d:b9:60:37:22
ethernet eth3 {
hw-id 00:0d:b9:60:37:23
vif 100 {
description lan
loopback lo {
pppoe pppoe0 {
authentication {
password <redacted>
user <redacted>
description dtag.pppoe
dhcpv6-options {
pd 0 {
interface br0 {
address 1
sla-id 0
length 56
ipv6 {
address {
autoconf
mtu 1492
no-peer-dns
source-interface eth0.7
nat {
rule 100 {
outbound-interface pppoe0
address 192.168.0.0/16
translation {
address masquerade
service {
dhcp-server {
listen-address 192.168.0.1
shared-network-name LAN {
authoritative
subnet 192.168.0.0/24 {
default-router 192.168.0.1
domain-name oasis.local
lease 86400
name-server 192.168.0.1
range 0 {
start 192.168.0.100
stop 192.168.0.254
dns {
forwarding {
allow-from 0.0.0.0/0
allow-from ::/0
cache-size 0
listen-address fd00:b4d:c0fe::1
name-server 2606:4700:4700::1111
name-server 2606:4700:4700::1001
name-server 1.0.0.1
lldp {
interface all {
ntp {
allow-client {
address 0.0.0.0/0
address ::/0
server time1.vyos.net {
server time2.vyos.net {
server time3.vyos.net {
router-advert {
interface br0 {
link-mtu 1492
name-server fd00:b4d:c0fe::1
prefix ::/64 {
preferred-lifetime 3600
valid-lifetime 172800
ssh {
port 22
