I have 2 Vyos routers and running vrrp. I have several VIFs and they work fine. However, I just created a new VIF with VRRP and it is visible on router 2 but not on router 1. By this, I mean show vrrp does not list the vrrp on router 1 as shown in the run show vrrp pasted below.
router 1 config:
vif 60
address 100.64.60.254/24
description test
vrrp {
vrrp-group 1 {
advertise-interval 1
preempt true
preempt-delay 20
priority 120
virtual-address 100.64.60.1
router 2 config:
vif 60
address 100.64.60.253/24
description test
vrrp {
vrrp-group 1 {
preempt true
preempt-delay 20
priority 120
router 1 - show vrrp:
run show vrrp
RFC Addr Last Sync
Interface Group State Compliant Owner Transition Group
bond0.10 1 MASTER no no 21w5d11h24m3s
bond0.20 1 MASTER no no 21w5d11h24m3s
bond0.21 1 MASTER no no 21w5d11h24m3s
bond0.40 1 MASTER no no 7w4d22h25m59s
bond0.80 1 MASTER no no 21w5d11h24m3s
bond0.90 1 MASTER no no 21w5d11h24m3s
bond0.110 1 MASTER no no 10w1d4h35m17s
bond0.200 1 MASTER no no 21w5d11h24m3s
bond0.210 1 MASTER no no 21w5d11h24m3s
router 2 - show vrrp
run show vrrp
RFC Addr Last Sync
bond0.10 1 BACKUP no no 7m51s
bond0.20 1 BACKUP no no 7m51s
bond0.21 1 BACKUP no no 7m51s
bond0.40 1 BACKUP no no 7m51s
bond0.60 1 MASTER no no 7m51s
bond0.80 1 BACKUP no no 7m51s
bond0.90 1 BACKUP no no 7m51s
bond0.110 1 BACKUP no no 7m51s
bond0.200 1 BACKUP no no 7m51s
bond0.210 1 BACKUP no no 7m51s
I have a server on the network and can ping both 100.64.60.254 and 100.64.60.253. I can also ping on out to the internet and the traffic flows through router 2.
If I disable the vif on router 2, then from the server, I can ping the interface address on router 1 (100.64.60.254) but nothing else.
I have restarted VRRP but that didn’t do anything. My next step is to probably reboot router 1 and if that doesn’t help, remove and reconfigure the interfaces.
Anybody have any insight or suggestions?
