I’m trying to get a suricata container running using the directions here: Vyos firewall artificial intelligence support - Talks - VyOS Forums
Its failing to start. I cannot remove the external container storage overlay now. I get a “container not empty” when trying to force remove it. Using command “sudo podman container rm <container_id> -f”,
Below is the container config I’m using:
set container name suricata allow-host-networks
set container name suricata arguments '-q 1'
set container name suricata cap-add 'net-admin'
set container name suricata cap-add 'sys-admin'
set container name suricata image 'jasonish/suricata:6.0.18'
set container name suricata memory '8192'
set container name suricata volume ETC destination '/etc/suricata'
set container name suricata volume ETC source '/config/suricata/etc'
set container name suricata volume LOGS destination '/var/log/suricata'
set container name suricata volume LOGS source '/config/suricata/logs'
set container name suricata volume RULES destination '/var/lib/suricata'
set container name suricata volume RULES source '/config/suricata/rules'
I’ve created the directories under /config and have made the listed /config/suricata/etc/suricata.yaml config changes. Suricata fails to start and I’m not finding any specific logs as to why yet.
I am using zones in my FW config, not sure if that breaks the ACL entries in the linked help above.
thanks for any help
