Syslog error messages?
I keep getting the following syslog messages. Any idea what this means?
I can confirm my NTP server is reachable within VRF, same as syslog server and I have added “set vrf bind-to-all”
Apr 17 06:51:25  systemd-tmpfiles[3883]: [/usr/lib/tmpfiles.d/resource-agents.conf:1] Duplicate line for path "/run/resource-agents", ignoring.
Apr 17 06:51:25  rsyslogd: omfwd/udp: socket 8: sendto() error: Network is unreachable [v8.1901.0 try https://www.rsyslog.com/e/2354 ]
Apr 17 06:51:25  rsyslogd: omfwd: socket 8: error 101 sending via udp: Network is unreachable [v8.1901.0 try https://www.rsyslog.com/e/2354 ]
Apr 17 06:51:25  rsyslogd: action 'action-2-builtin:omfwd' suspended (module 'builtin:omfwd'), retry 0. There should be messages before this one giving the reason for suspension. [v8.1901.0 try https://www.rsyslog.com/e/2007 ]
Seems like packets send from syslog deamon do not come from mentioned VRF, but some global VRF instead
In VyOS syslog is always in default VRF. There is no configuration option for that.
You can make it manually. Don’t configure syslog server in VyOS and add in vyos-postconfig-bootup.script this lines:
echo '*.notice;local7.debug action(type="omfwd" Target="<your_syslog_server>" Port="514" Protocol="udp" Device="<your_vrf_from_vyos_config>")' >> /etc/rsyslog.d/vyos-rsyslog.conf
service rsyslog restart
*.notice;local7.debug means:
 facility all {
     level notice
 facility protocols {
     level debug
Tested on 1.3.
I have an interface, on a VRF, that is directly connected to the syslog server.
I also have an interface, Global VRF, that is not connected directly to the syslog server and I route the traffic to Syslog server via that interface using static route. So, there is reachability via Global table.
I can also see some syslog messages on my syslog server, so vyos can send it there.
These log messages I posted is just a bit noisy.
