I recently migrated to 1.5-stream-2025-Q1 from 1.5-rolling-202502220006. I had to slightly modify the syslog config when I moved to the stream release, but on both versions, the syslog seems to still log info level, even though I stated level warning. I was under the impression that if a level is specified, then logging for anything more verbose is not done, is this a correct assumption? I have rebooted a few times too.
vyos@vyos:~$ show system image
Name Default boot Running
1.5-stream-2025-Q1 Yes Yes
vyos@vyos:~$ configure
vyos@vyos# show system syslog
global {
facility all {
level warning
marker {
interval 86400
vyos@vyos# exit
exit
vyos@vyos:~$ monitor log
Mar 12 14:30:01 DhcpLFC[3440]: INFO [DhcpLFC.140310957201856] LFC_ROTATING LFC rotating files
Mar 12 14:30:01 DhcpLFC[3440]: INFO [DhcpLFC.140310957201856] LFC_TERMINATE LFC finished processing
